Question about LG VX8300 Cellular Phone
Car kit mode???
My phone is stuck on "car kit" mode. i cant hear anything on my phone. how can i fix this problem??
  • 15 more comments
  • mrsgraves3 Sep 27, 2007
    thanks but its fixed now. When it goes in car kit mode you hold down the * button and its going to vibrate and then your phone should go back to normal. i had taken it to the verizon store and thats how they fixed mine.
  • JoePz Nov 22, 2007
    My lg vx8300 is stuck on car kit mode. How do I turn it off?
  • Anonymous Apr 07, 2008
    My LG VX8300 cell phone is stuck in car kit mode. I have tried almost everything without any luck. HELP!
  • goose1223 Apr 28, 2008
    It is stuck in Car Kit mode, I can't hear anything when I call someone and the other person can't hear me, I can still send and recieve texts, but the vibrate mode also doesnt work....
  • Anonymous Jun 03, 2008
  • Anonymous Aug 17, 2008
  • Anonymous Aug 24, 2008
    phone is in car kit mode how do i get it workin and wat button i press to get it out of it
  • Anonymous Sep 06, 2008
  • Anonymous Sep 10, 2008
    my phone is stuck on car kit mode
  • feb2003 Dec 16, 2008
    Thank you so much. I dropped my phone in the sink while it was on and it went into car kit mode (at first I couldn't use any of the buttons). After using a hairdryer on it's warm and cold setting and throwing it around the room a little (only into soft objects like the bed), it still wasn't working. I came to this solution (of using a toothbrush on the charger port), and though I didn't have any contact cleaner, I just used the toothbrush while the phone was off, powered back up, and it was no longer in car kit mode! Thanks so much!
  • mwelsh5150 Dec 30, 2008
    I have the same problem. My phone got semi-wet(not soaked) and it kept working but then i noticed it in "car kit" mode and I can't get it out of that mode. I just tried the suggestion of holding down the star key and that did nothing for me.
  • beltranguill Jan 13, 2009
    phone stuck on car kit mode. held down the * key but that did not work
  • Anonymous Jan 17, 2009
    my phone is stuck on car kit.I tried to hold the * button but it isnt working HELP ME PLEASE!!
    my phone is stuck on car kit mode. I cant change it i tried every solution on this website PLEASE HELP ME!!!!!
  • haleywalker Mar 24, 2009
    My phone is stuck in Car Kit Mode....what do I do? I tred urning it off and taking the battery out but no luck.
  • Anonymous Apr 01, 2009
    My phone went to a -car kit mode- I can not disable
  • frazier114
    frazier114 Jan 30, 2013
    it has gotten wet the plug where the charger goes needs to be cleaned
  • 31 Answers
The Car Kit message is usually caused by corrosion in your charging port. Yes, holding * may revive the phone, but your best bet is to get some contact cleaner and a toothbrush and clean out your charging port.
Posted on May 06, 2008
I also had 'car kit' appear on my cell phone and i took a cue tip with alcohol and cleaned the slot where you insert your charger and then i took a little brush and cleaned it. I turned the phone on and there was sound. It works now.
Posted on Jan 12, 2009
    New Friend:
In the charge port, make sure none of the pins are contacting each other, if any of the last three pins on the right are touching, it will go into car kit, this is how I fixed mine.
Posted on Jul 29, 2010
  • melmnm14 Nov 29, 2010
    thankyou so very much, this helped! I stuck a booby pin in the charging port for about 30 seconds running it back and forth and the car kit mode disapeared. Thankyou thankyou!
SOURCE:
LX VX5300 stuck on car kit
I have the same phone. I have had that same problem before. What i did to fix it was to take a blowdryer (on the cool setting -not warm or hot) and take the battery out and blow the phone with it. The reason it says carkit is because moisture got into the phone somehow. Mine first started saying carkit when my friend dunked my phone in a cup of water. I hope this helps you with your phone. Also if the blowdryer doesnt work then try using a can of pressurized air.
Dec 10, 2008 | LG VX5300 Cellular Phone
Car kit
you somehow got it wet. bring it to your provider and they'll tell you the same.
Oct 26, 2008 | LG VX8300 Cellular Phone
LG5000 cell phone mode
try to turn off computer,remove battery and turn it back on
Oct 10, 2008 | Cell Phones
Car kit
My cellphone is stuck in car kit mode and i cannot hear anyone calling me but i can text people. How do i get this feature off!
Sep 05, 2008 | LG VX8300 Cellular Phone
Problem
Take the phone and have the speaker replaced.
May 29, 2008 | Sony Ericsson K800i Cellular Phone
Problem with Sony Ericsson k800
take the phone to a mobile service center and have them repaced your speaker this will correct the issue that you are having with your phone.
Car kit mode
Car kit mode is usually caused by debris in the phone's cable connector (at the bottom of the phone). The debris causes two or more contacts to be electrically connected to each other, causing the phone to think it's connected to a car kit. Remove the battery from the phone and clean the cable connector contacts with some rubbing alcohol and the corner of a towel. Also, try using an opened paperclip to scrape the contacts in the connector, this will remove any corrosion that may have built up.
Feb 17, 2008 | LG VX8300 Cellular Phone
Dropped cell and people cant hear me
I had the same problem as the person in the original posting -- I dropped my phone after which callers could no longer here me.  So I tried dropping the phone again, as the original poster suggested, and afterwards the problem was solved.
Nov 19, 2007 | LG VERIZON VX5200 Hands-Free Headset...
Car kit
there is internal damage an easy fix is to plug it into the car charger and it will only work on the charger you should have let the phone sit out and dry with the battery detatched. my phone did the same thing about 3 months ago. if that doesn't work you'll need a new phone
Feb 23, 2007 | LG VERIZON VX5200 Hands-Free Headset...
"Car Kit"
this model do that when it get wet if that the case there is nothing to do but chage the board, go to the celu store they have jonk to fix these for about $25.00 more or less..good luck
Aug 06, 2006 | LG VX6000
LG VX8300 Cellular Phone Logo
6,020 people viewed this question
Top LG Cell Phones Experts
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
