Question about JVC LT-32X887 32 in. HDTV LCD Television
Need code to unlock tv - JVC LT-32X887 32 in. HDTV LCD Television
What is the probability for switching sim in Samsung Corby tv
Hi, If you need to switch the SIM card in your Samsung Corby TV mobile you may need to check whether your mobile is network restricted. If it is free from network restriction you can use any international GSM SIM to it. If it is network restricted You need to unlock it before using any other GSM SIM to it. These are the two probabilities in switching a SIM to your Samsung Corby TV mobile phone. If your mobile is network restricted, You can unlock it safer and easier using unlock code. You can get the unlock code from www.wickedunlock.com/samsung-corby-tv/rs11wp9/ at affordable cost.
STEPS FOR UNLOCKING SAMSUNG CORBY TV
Method 1:
1 - Switch ON your Samsung Corby TV with a NOT ACCEPTED SIM Card.
2 - Samsung Corby TV will ask for "Password".
3 - Enter the Unlock Code.
OR (if the Samsung Corby TV shows "Insert Correct SIM Card")
Method 2:
2 - Don't bother about what's being displayed on your Samsung Corby TV.
3 - Compose : #0111*CODE#.
Oct 05, 2012 | Cell Phones
Parental control code had been changed, don't know what it is now
Hello
Try the following to unlock your Jensen TV.
1. Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
2. Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
3. Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
4. Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
5. Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired.
OK.
Mar 14, 2011 | Jensen 143307 Remote Control
I need codes to unlock sanyo tv with uet 606
Please follow this guide to unlock your tv :
www.ehow.com/how_4488981_unlock-tv.html
Regards, Jay_NBHV765C
Mar 05, 2010 | RCA Universal Remote Control
Tv baier three digit code
on your remote press pp 3 times, this should unlock the tv. if you want to cancel the code select the SETUP FUNCTION menu then highlight LOCK, using VOL+ VOL- keys cancel the lock (NO) hope this helps.
Aug 24, 2009 | Televison & Video
Lock code how to un lock it
If you have a RCA Truflat TV/DVD combo try code 8888 to unlock parental control settings.
Apr 18, 2009 | RCA 20F610TD TruFlat TV/DVD
Need help unlocking the tv parental code
Enter 8888 as the password & then push ok.
Apr 10, 2009 | RCA 27F530T 27" TV
I need code for this model to unlock this tv please
This might reset password and maybe not Try this Press menu on TV and vol-on the remote handunit hold for 5sec.
Dec 31, 2008 | Mitsubishi VS-60703 60" Rear Projection...
Need codes to unlock the smart block on my phillips magnavox tv
do you have a 3 digit code for RCA TV for the philips universal remote?
Dec 30, 2008 | Televison & Video
Unlock Menu
I need a password to unlock my Mitsubishi TV Model # CS40707 Serial # 503994
Jan 02, 2008 | Mitsubishi CS-35707 35" TV
How to unlock my Panasonic CT-27SC14J
Long time not use my Panasonic CT- 27 L8G. Now I forget code. I need code to unlock my TV. Somebody help me, Please?!
Alex.
Nov 04, 2007 | Televison & Video
JVC LT-32X887 32 in. HDTV LCD Television Logo
18 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
