Question about Kodak ESP 9 All-In-One InkJet Printer
Screen is showing paper jam, software is showing error code 105-3515. Cartridge carrier won't move to center for checking seating of the cartridges. No paper found anywhere and I can't opt out to any discussion with the printer.
  • 2,113 Answers
Most printers have a hard reset method to restore factory settings and go through a diagnostic Power down then while powering up hold the power button while pressing another button (you'll have to look for a hard reset instructions)
Posted on Oct 15, 2013
Testimonial: "I'll give it a try! Thanks."
SOURCE: ESP 7 paper jam error
I had the same problem, but after pressing the OK button when the paper jam came up again I pressed the CANCEL button and was able to print my document. See if that works for you too.
Posted on Apr 12, 2009
SOURCE: error code 3528 keeps coming up,telling me to
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Posted on Jan 18, 2011
pineworks
  • 4041 Answers
SOURCE: printer error paper jam and no paper to be found!
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 30, 2010
SOURCE: kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
Posted on May 28, 2009
SOURCE: Kodak ESP 3250. Error 3527. I put new ink
Contact Kodak. I think it's the batch of printers that were made around this time. I just contacted them (mine is the same age and I'm getting the same error), and they are sending me a new printer.
Posted on Mar 09, 2011
A code 2200 is showing and my copier will not copy. How do I address code 2200?
The 2200 error code indicates that the scanner has stalled. It could be due to the cartridges or the encoder strip (transparent strip seated behind the cartridge carrier) has gotten loose from its position. Please follow the steps below to identify and fix the problem:
  1. Open the printer cover and remove the cartridges. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then slide the carrier to the center for the loading position.
  2. Check the encoder strip and make sure it is secured in its place.
  3. Close the printer cover.
  4. Re-brick your printer. Pull out the power supply (black box where the power cord is plugged in at the back of the printer) and put it back after 30 seconds.
  5. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  6. If no error appears, reinsert the other cartridge. Close the printer cover.
  7. Replace whichever cartridge is causing the error to appear with a new cartridge.
  8. If no error appears, try to print a document again to verify that the problem is fixed.
Feb 02, 2012 | Lexmark X7170 All-In-One InkJet Printer
Error message 0502 hardware ?
Re-position the Encoder Strip on your all in one Printer
To re-position the encoder strip, perform the following steps:
1. Remove the power cord from the unit.
2. Lift the lid of the unit, just below the scanner portion of the All-In-One, to expose the inside of the unit where the printer cartridges are located.
3. Gently slide the ink cartridge carrier to the middle of the printer.
4. Gently move the top part of the printer belt to the right.
5. Using an index finger, gently push encoder strip down and then back up to get it back into the slot located on the back of the ink cartridge carrier.
NOTE
NOTE: There is a small slot that the encoder strip fits into, which is going to be located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear and then forward to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the lid to the unit.
9. Re-connect the power supply to the All-In-One.
10. Press the Power button. If the encoder strip was re-seated correctly, the Hardware Error: 502 code will not appear.
See attached pictures, one for an out or place encoder strip, the other for a well placed strip.
Other faults that can bring up this error is a carriage rail that needs cleaning and oiling (so you might want to do that while your inside the thing), and also obstructions to the paper ways. Try removing paper jams, and put the printer upside down to shake loose anything that might jam the mechanism.
This was originally posted by member silly girl 5 years ago for this model printer. and same error code.
Feb 01, 2011 | Dell A940 All-In-One InkJet Printer
Error code 1200 is showing?? help!!
The error 1200 indicates that the cartridge carrier is stuck inside the printer. Please follow the steps given below:
1. Unplug all cables from the back of the printer.
2. Open the front cover and look above the steel rod. You should see a black belt with rubber teeth on it. (On some models, the cartridge access is very small, but the belt should still be visible.)
3. Take the top part of the belt and move it gently to the right. The cartridges should come towards the center.
4. If the cartridges will not move, tilt the printer on its back and try moving the belt again.
5. If it still will not move, try putting your finger inside the area where the cartridges are stuck (with the printer still on its back), and push them firmly against the cartridge carrier holder while you move the belt with your other hand.
6. Once the cartridges are in the middle, snap them firmly into the cartridge carrier. Note: Make sure that these cartridges are the correct models for your printer. Once the cartridges are seated properly, they should not become loose inside the carrier.
7. Plug all the connections back in and power the printer up.
8. Open the front cover again to see if the cartridges slide to the center.
You should then try to self-test the printer. The self-test allows us to rule out software and the cable by testing the hardware by itself. Please note that this is not a "fix," but rather a diagnostic test to determine if your hardware is at fault.
Please begin by disconnecting the power supply from the wall (not the back of the printer) for at least "30 seconds." Then plug the printer back in and follow these steps:
Next, try this printer self-test by following the steps given below:
1. Press the "Copy" button once.
2. Press the "Options" button 11 times until the screen reads "Maintenance."
3. Press the "Left Arrow(-)" button until the screen reads "Maintenance: Self Test."
4. Press "Select."
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 01, 2009 | Lexmark X4270 All-In-One InkJet Printer
Error E3 when no paper jam
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error.
The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix.
When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper is jammed,but there is no paper in the printer
first... off you printer and then pull the carrier until you reach the carrier of cartridge..and then replace the cartridge..
try to up it again..
May 13, 2009 | Canon PIXMA MP160 All-In-One Printer
Error 1200 indicates paper jamming. No paper is jammed however the cartridge carrier appears to be jammed on the left hand side. I have tried everything I can find but cannot release it. Even uninstalling...
4. Press "Select."
Apr 20, 2009 | Lexmark X4270 All-In-One InkJet Printer
ERROR 0502
NOTE
Dec 12, 2008 | Lexmark X6170 All-In-One InkJet Printer
Paper Jam wont clear and there is no paper in it
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} When printer does not have visible paper jam and printer is showing error paper jam
Check if the Encoder Strip is Broken or Missing
1.Power down the printer and unplug the power.
2.Slide the cartridge carrier inside the printer a couple of inches to the left.
3.Locate the encoder strip (Figure 1) on the right-side of the cartridge carrier encoder strip
Note:
The encoder strip is a plastic strip with small markings over its entire length. The strip may appear to be translucent.
Reposition the Encoder Strip
1. Remove the power cord from the printer.
2. Lift the scanner unit to expose the inside, where the printer cartridges are located.
5. Using an index finger, gently push encoder strip (Figure 1) down and then back up, to get it back into the slot located on the back of the ink cartridge carrier.
6. Gently press the strip first to the rear, and then forward, to ensure that it is seated correctly.
7. Manually move the ink cartridge carrier to the left, then to the right, to check the positioning of the encoder strip.
8. Once the encoder strip has been re-seated, close the scanner lid.
9. Re-connect the power cord to the printer.
Ensure the Paper Tray is Not Overfilled
Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray.
Aug 17, 2008 | Dell 924 All-in-One InkJet Printer
Dell 922 printer jam
Note:
Reseat the Dell Printer Power Adapter.
If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends.
Check with manufacturer if printer is still covered under warranty...
If yes then get it replaced.....or else get a new printer
Jul 31, 2008 | Dell 922 All-In-One InkJet Printer
Kodak ESP 9 All-In-One InkJet Printer Logo
459 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
