Question about Microsoft Streets and Trips 2013 B17-00563
Get the following error message: Your registry
Get the following error message: Your registry settings for this application were not copied correctly. To correct these settings run setup again for this application from the same location where you originally installed it
    Sergeant:
  • 216 Answers
If you are installing this on Windows 7 or 8 you will have to contact Microsoft directly. You can use Microsoft Technet or knowledge base to try to find a solution but I have found a bunch of this same error on their site and it appears to be a major problem.
I do know that the registry error is often a mistake and the program may run correctly after you reboot. This is a serious issue with Window 7.
Posted on Oct 18, 2013
3 Suggested Answers
SOURCE: office 2007 "Setup cannot continue becaue a required file is either corrupted or not available. Run setup again from the original source disc or download location" error
You may have registry bits or system32 files left over. Try using CCleaner. If worse comes to worse, reinstall windows XP, NOT Vista.
Posted on Sep 07, 2008
APremkumar
  • 564 Answers
SOURCE: not able to access MS office
http://support.microsoft.com/kb/933347
Here is what you need. Just click the Link Above. Please Rate My Response! Thanks!
PREM
Posted on Feb 28, 2009
Hp pavilion a1102n winxp home. Blue screen after win splash logo, flashes too fast to read. 2x256mb. Dial up modem. Tried: removing modem, removing front usb FireWire media card slots. Removing one or...
Dear,
I saw your video and check the blue screen error. It comes for a friction of second and disappears but i kept my media player in slow motion mode and checked it. This error belongs to a missing registry file.
PERFORM THIS PROCEDURE for recovery.
A Stop 0xc0000218 error message means that a necessary registry hive file could not be loaded. This error message can occur if the file is corrupt or missing. To resolve this issue, you can reinstall the operating system and restore the registry files from a backup. The registry files may have been corrupted because of hard disk corruption or some other hardware problem.
This error message can also occur if the driver has corrupted the registry data while loading into memory, or the memory where the registry is loading has a parity error. In the latter case, turn off the external cache and check the memory chips.
To resolve this issue, follow these steps:
  1. Start your computer by running the Recovery Console, run the chkdsk /p command on the drive, and then restart your computer. Test to determine whether the issue is resolved. If the issue is resolved, do not complete the remaining steps. If the issue is not resolved, go to step 2.
  2. When Windows loads, press SPACE BAR when the "Load Last Known Good" message appears.
  3. Complete a parallel installation, and restore the registry files from a tape backup. To do so:
    • Reinstall Windows in a separate folder.
    • Restore the damaged registry hive from backup. This procedure is specific to the backup application that you used to make a backup. Consult the documentation of your backup application or consult the vendor if you need assistance. Typically, this procedure requires you to restore a system state backup to an alternate location, and then copy the appropriate registry files to the %SYSTEMROOT%\System32\config folder of the damaged operating system.
    • If you do not have a tape backup, include the backup of network servers and production workstations.
    NOTE: If Windows is stored on a FAT partition, you can restore the files by using another computer and by copying the registry hive files to the %SYSTEMROOT%\System32\Config subfolder.
best of luck!
Mar 07, 2012 | HP Computers & Internet
Tip
Error messages when you try to install Windows XP Service Pack 3
When you try to install Windows XP Service Pack 3 (SP3), you may receive the following error message:
An internal error occurred
After you click OK in the error message, you receive the following error message:
Service Pack 3 installation did not complete
Additionally, you may see the following errors that are logged in the C :\Windows\Svcpack.log file: 165.672: An internal error occurred.
165.672: Service Pack 3 installation did not complete.
165.672: Update.exe extended error code = 0x1ffe054f
165.672: Update.exe return code was masked to 0x643 for MSI custom action compliance
Note Throughout this article, the C :\Windows folder represents the folder where Windows XP is typically installed.
CAUSE
The errors that are mentioned in the "Symptoms" section can occur because of files that are not trusted or because of corrupted registry keys. You can verify the cause by searching for related entries in the Svcpack.log file. Specific entries will identify specific causes of the issue, as noted in the following "Cause" sections.
Cause 1
Determine whether the following entries are logged in the Svcpack.log file: 142.391: CheckVLKForBlock: LIC.dll not trust verified
142.578: Trying CheckVLKForBlock again
142.594: CheckVLKForBlock: LIC.dll not trust verified
142.594: Error: CheckVLKForBlock failed
These entries indicate that the cause of the issue is the Licdll.dll file. The Licdll.dll file may have been altered, is corrupted, or is not trusted. The Licdll.dll file is located in the following folder:
C :\Windows\System32\
Cause 2
Determine whether the following entries are logged in the Svcpack.log file: 211.890: IsSPBetaKey:pLA->lpVtbl->GetProductID Failed: 0x80004005
213.125: Trying CheckVLKForBlock again
214.468: Error: CheckVLKForBlock failed
These entries indicate that incorrect product ID information in the registry is causing the issue.
Cause 3
Determine whether the following entries are logged in the Svcpack.log file: 299.031: Trying CheckVLKForBlock again
299.531: Error: CheckVLKForBlock failed
These entries indicate that corrupted or altered registry keys in preinstalled programs are causing the issue. Note One program that is known to cause this issue is Micrografx - Picture Publisher Professional 10. To work around this issue, see the "Workaround for Cause 3" section.
RESOLUTION
To resolve or to work around these causes, use the resolution or the workaround that corresponds to the cause.
Resolution for Cause 1
To resolve this issue, you must replace the current copy of the Licdll.dll file by using a copy from the original Windows XP media. To do this, follow these steps: 1. Insert the Windows XP CD into the CD drive.
2. Click Exit on the Setup Wizard as soon as it starts.
3. Click Start , and then click Run .
4. Copy and then paste (or type) the following command in the Open box, and then press ENTER:
explorer
5. Click My Computer .
6. Note the drive letter that contains the Windows XP CD.
7. Click Start , and then click Run .
8. Copy and then paste (or type) the following command in the Open box, and then press ENTER:
cmd
9. Type or copy and paste the following text into the Command Prompt window, and then press ENTER:
Expand CD_Drive_Letter :\i386\licdll.dl_ C :\Windows\system32\Licdll.dll
Note In the command in step 9, replace CD_Drive_Letter by using the actual drive letter for the drive that you noted in step 6.
10. To install Windows XP SP3, visit the following Microsoft Windows Update Web site:
http://windowsupdate.microsoft.com Resolution for Cause 2
To resolve this issue, you must replace the incorrect product ID registry entry with the correct product ID. To do this, follow the steps in the "Locate and note the product ID" and "Identify and change the product ID registry entry" sections.
1. Click Start , and then click Run .
2. Copy and then paste (or type) the following command in the Open box, and then press ENTER:
sysdm.cpl
3. On the General tab locate the product ID. The product ID is the 20 digit number that is located under the Registered to section.
4. Note the product ID for use in the "Identify and change the product ID registry entry" section. Identify and change the product ID registry entry
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 How to back up and restore the registry in Windows
regedit
3. Locate and then click the registry subkey that resembles the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\WPA\Key- XXXXXXXXXXXXXXXXXXXXX
Note The series of Xs represent a placeholder for a string of 21 characters.
4. There may be several subkeys that resemble the format in step 3. To determine the correct subkey, follow these steps: a. Click each subkey in the navigation pane.
b. In the details pane, compare the value of the string for the ProductID registry entry under the Data column to the number that you noted in step 4 in the "Locate and note the product ID" section.
c. The registry subkey whose ProductID registry entry value matches the number that you noted in the "Locate the product ID" section is the registry subkey that you want.
5. In the navigation pane, right-click the registry subkey that you identified in step 4c, and then click Export .
6. Save the registry subkey to the Desktop as temp.reg .
7. Right-click the temp.reg file on the Desktop, and then click Open With .
8. Click Notepad , and then click OK .
9. In the open temp.reg file, locate the following text:
[HKEY_LOCAL_MACHINE\SYSTEM\WPA\Key- XXXXXXXXXXXXXXXXXXXXX ]
10. Replace the text that is mentioned in step 9 by using the following text:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion]
11. Click File , click Save , and then exit Notepad.
12. Double-click the temp.reg file, click Yes in the dialog box when you are prompted to add the information to the registry, and then click OK .
13. To install Windows XP SP3, visit the following Microsoft Windows Update Web site:
http://windowsupdate.microsoft.com Resolution for Cause 3
To resolve this issue, you must delete the InprocServer32 registry subkey. To do this, follow these steps: 1. Click Start , and then click Run .
regedit
HKEY_CLASSES_ROOT\CLSID\{00020420-0000-0000-C000-000000000046}\InprocServer32
4. Click InprocServer32 . A string value with the name InprocServer32 is displayed in the details pane. Click this value.
5. On the Edit menu, click Delete , and then click Yes .
6. Exit Registry Editor.
7. To install Windows XP SP3, visit the following Microsoft Windows Update Web site:
on May 03, 2010 | Computers & Internet
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
When i open remote management showing a error message''error:1004'' please help me to solve this problem.
his problem can occur when you give the workbook a defined name and then copy the worksheet several times without first saving and closing the workbook, as in the following sample code: Sub CopySheetTest() Dim iTemp As Integer Dim oBook As Workbook Dim iCounter As Integer ' Create a new blank workbook: iTemp = Application.SheetsInNewWorkbook Application.SheetsInNewWorkbook = 1 Set oBook = Application.Workbooks.Add Application.SheetsInNewWorkbook = iTemp ' Add a defined name to the workbook ' that RefersTo a range: oBook.Names.Add Name:="tempRange", _ RefersTo:="=Sheet1!$A$1" ' Save the workbook: oBook.SaveAs "c:\test2.xls" ' Copy the sheet in a loop. Eventually, ' you get error 1004: Copy Method of ' Worksheet class failed. For iCounter = 1 To 275 oBook.Worksheets(1).Copy After:=oBook.Worksheets(1) Next End Sub
Nov 18, 2009 | Computers & Internet
Error reading event file
The EVT files include the event log messages as they are stored by the system. Each message is composed of an ID (that is, the message itself) and a number of insertion strings. The IDs are translated into strings through the use of messages DLLs.
All the application event logs messages DLLs are defined under the following registry keys:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ Application
All the system event logs messages DLLs are defined under the following registry keys:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ System
For example, the TCP/IP service's message DLL is defined under the following registry entry:
Key = HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ System\TcpIp Value = EventMessageFile REG_EXPAND_SZ %SystemRoot%\System32\ netevent.d
Therefore, all the TCP/IP event log messages are defined in the DLL netevent.dll.
When the user double-clicks an event for which the message DLL is not defined in the registry, the message string cannot be displayed and the following message is displayed: The description for Event ID (51) in Source (aservice) could not be found. It contains the following insertion string(s): ... Below is a description of a way to read the system event logs of a computer with WINS on a computer without WINS. This sample can be adapted for any application or system component.
WARNING: Using Registry Editor incorrectly can cause serious, system-wide problems that may require you to reinstall Windows NT to correct them. Microsoft cannot guarantee that any problems resulting from the use of Registry Editor can be solved. Use this tool at your own risk.
The following operations are required:
  1. On the computer with WINS, run REGEDIT and select the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\EventLog\ System\Wi
  2. On the Registry menu, click Export Registry File and select a file name (for example, Winsreg.reg).
  3. On the computer without WINS (for example, the one used to read the system event logs of the computer with WINS), run REGEDIT. On the Registry menu, click Import Registry File and select the file Winsreg.reg previously saved on the other computer.
  4. You should now have the following registry entry on the target computer (that is, the one without WINS):
    Key = HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\ EventLog\System\Wins Value = EventMessageFile REG_EXPAND_SZ %SystemRoot%\System32\ winsevnt.d
    You now need to copy the file defined in the EventMessageFile registry value in your System32 directory. If X: is mapped to \\wins_server\admins$, you can run the following command: copy x:\System32\winsevnt.dll %SystemRoot%\System32\winsevnt.dll
    Of course, the file may be copied somewhere else, but in this case you need to edit the EventMessageFile registry value manually so that it points to the directory with the DLL.
  5. Close all the instances of the Event Viewer and rerun the Event Viewer. You should now be able to dump all the WINS events.
Nov 14, 2009 | Cosmi Print Perfect Platinum
Sir i have downloaded a game from net i installed it and tried to open but it gives a message "this application was faiiled to start because mss32.dll file is missing" plse help me to start the game
Mss32.dll Error is a common Windows error message. Mss32.dll Error is usually caused by a missing system files, wrong system settings or a corrupted registry file. Use CTRL+ALT+DEL to get the task manager, if there is anything listed with [Not Responding] end task it. Next, run a registry scan to check for registry errors & other system problems. 96% of the time this will fix the cause of the error
It is best to clean your registry in order to optimize system performance & Fix the cause of many Windows Errors.
Apr 14, 2009 | Computers & Internet
Direct Printing
Solution Follow the steps below:
  1. Click Start , then Printers and Faxes .
  2. Right-click the system default printer and click Properties .
  3. On the General tab, right-click the default printer and click Copy .
  4. Click Cancel to exit.
  5. Click Start and then click Run .
  6. In the Run dialog box, type regedit and click OK . WARNING: Using Registry Editor incorrectly can cause serious problems that may require you to reinstall your operating system. Hewlett-Packard cannot guarantee that problems resulting from the incorrect use of the Registry Editor can be solved. Use Registry Editor at your own risk. It is strongly recommended that you make a backup copy of the Registry before you edit it. For information about how to edit the Registry, view the "Changing Keys And Values" help topic in Registry Editor (Regedit.exe) or the "Add and Delete Information in the Registry" and "Edit Registry Data" help topics in Regedit32.exe.
  7. In the Registry Editor window, click Edit , then click Find... , and search for the following key: HKEY_CURRENT_USER\Software\Hewlett-Packard\DigitalImaging\hpfccopy .
  8. Double-click Printer in the right pane.
  9. In the Edit String window, paste the printer name as it appears in the Registry under Value data (for example, hp photosmart 8400 series) .
  10. Click OK and close the Registry Editor.
  11. Press Copy on the scanner. The default printer connected to the system should normally print the scanned document.
Cause This issue occurs when the default printer or the list of printers is not recognized on the hpfccopy function in the Current User section of the Registry.
Mar 27, 2008 | HP Scanjet 4370
Microsoft Streets and Trips 2013 B17-00563 Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
