Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
When driving my backhoe it shacks and makes a grinding sound
  • 51 Answers
Check all fluid levels, engine, transmission, differentials, etc, also do a complete look over the machine to see it something is not jammed up! Have someone drive it forward or backwards, while your standing beside it and narrow down where the noise is coming from. And go from there.
Posted on Nov 18, 2013
I have installed a new starter on my 580C backhoe When I turn the starter switch it will not engage wheel and just akes a whirring sound Have taken it out and reinstalled it but get the same results
I can talk to you in automotive terms, I know nothing about a backhoe.
I can usually lay the starter motor on the ground, hook up jumper cables properly from starter to battery, at the least, it should kick out the starter drive gear and spin. If it doesn't kick out the drive gear, starter is faulty. I don't know if starter solenoid sits on top of starter motor? I replace as an assembly. Did you check flywheel teeth? I've never worked on a backhoe.
Feb 25, 2017 | Cars & Trucks
On a case 580k 4x4 backhoe is 4th gear set up different then 1st 2nd 3rd tractor won't move in lower gears made no noises or grinding .
Hi Bill:
I'd check with my local Case dealer. We have several pieces of Case equipment with hydostatic drives.
If I remember correctly, high gear on a standard transmission is a 1:1 ratio in that the power is on a straight through shaft.
My suspicion would be that a shifter link ay have become dis-connected.
Here's a link that may assist.
https://www.google.ca/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=1987+case+backhoe+580k+4x4+transmission+diagram
Cheers
Apr 04, 2016 | Cars & Trucks
My CR-V 97 produces metal grinding sound at the rear part after driving for almost 5 minutes at a speed of 60km/h. When I reduce the speed to 20km/h, the grinding sound stops. When I jacked all the four...
my guess is the wheel bearing. jack the rear tire off the ground and try shacking the tire. if you have any play your bearing could be bad.did you hear a hum from the same wheel. wheel bearings will hum before they start grinding
Jan 22, 2015 | Cars & Trucks
97 wrangler wont drive forward in 2wd. just makes a loud grinding noise but will drive in reverse
sounds like rear end is coming apart
google wrangler forums and post there
Feb 03, 2013 | 1997 Jeep Wrangler
I have a 98 ford taurus, when i drive it, the
SOUND LIKE THE TRANSAXLE DRIVE CHAIN AND DRIVE SPROCKET BEARINGS IS SHOT.
Sep 16, 2009 | 1998 Ford Taurus
Washer is making a grinding sound when draining water.
hi, this grinding sound is coming from the pump. the pump device seems to have a broken impeller that is located inside the pump. You will not be able to replace this internal part. This device is fixed and you will have to replace the entire pump assembly.
This will happen if some debris or coins make it threw the pump housing. these debris will settle in the pump housing near the impeller and it will grind while in operation or, draining procedure. the solid debris will eventually damage the impeller and break it off the drive bolt. this will all happen in time but, it usually starts with the minor grinding sound.
May 16, 2009 | Kenmore Washing Machines
Terrible shacking in front end
take car to a mechanic,suspect drive shaft plus it could be a host of other things get it looked at by a professional before you kill someone
Dec 27, 2008 | 2001 Oldsmobile Alero
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
74 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
