Powerspec 9201 Im trying to reset the bios to default so i can disable the raid. I want to use a regular SDD hard drive and my windows but i cant find a way to do it. Please help
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 105 Answers
With your computer unplugged and all devices unplugged, open the case and find the button cell battery. To remove, simply depress the tab holding it in and the battery should pop out. Leave out for a few minutes and put battery back in by pushing on it with gentle pressure, it should make a click sound. Then hook it all back up and go in to bios and activate the raid function.
Posted on Oct 16, 2013
5 Suggested Answers
  • 19 Answers
SOURCE: How can I set up my Samsung SSD 256 GB hard drives
First of all, does the Motherboard support RAID? If so, you may need to get into the RAID BIOS and set it up. Make sure there's no critical data on the drive(s) you are mirroring or striping! Some systems have a GUI RAID utility as well for setting up the drive(s). Depending on the size of the drive(s) you're using it can take a while for the setup to complete.
Posted on Jun 20, 2009
  • 73 Answers
SOURCE: Dell optiplex will not recognize hard drive
Is it SATA or IDE? Have you tried another cable? If it's IDE, have you checked the jumper settings (usually Cable Select is easiest)?
Posted on Feb 19, 2010
  • 61 Answers
SOURCE: compaq SR1650NX HARD DRIVE MESSED UP RECOVERY DISK
Are you trying to set up a raid configuration? If not I would reformat using the 98 disk and reinstall. (You may be able to skip installing 98, try installing xp first and it should ask for the disk containing the software (win98) that qualifies for the upgrade.
Posted on Jul 12, 2010
  • 551 Answers
SOURCE: Hello
First things first. I believe your computer has a recovery disk. Which is applicable to Vista. If you want to downgrade the operating system from Vista to XP you need to check your hardware settings. Now for this problem, my suggestion is try replacing your hard drive. Because as far as I know the hardwares installed in your motherboard is ok. But your hard drive is not in good shape. After replacing your hard drive perform your installation of XP. And then observe.
If problem still occurs, please let us know.
Posted on Aug 03, 2010
Having trouble booting two Raid-0 discs on Asrock Z77 Ex4 UEFI
RAID implementations will vary from controller to controller, and even from bios to bios revision or version for the same controllers.
You should "image" the raid on the old board, then delete the raid on the old system.
In the new system, you need to treat these drives like they are new, blank hard disks. Any partitions will need to be removed, and the RAID created on the new board. Once this is done, you can use your partition imaging software to drop the data back onto the new RAID partition. Seagate I believe has imaging software available in Seatools, or you can use something like Acronis True Image or GHOST.
May 16, 2012 | Computers & Internet
Ibm thinkpad a31p hard drive not found
Thi sis an issue about the hard disk itself .. depending on how was formatted.. or the way was connected. you need to go to bios settings and select the hard disk in the devices .. and if there is an ahci function on . you have to disable it . cause without driver will not see the hard disk .. This is nto an issue if you install a windows 7 but for widows xp .. to work and to use it in this way ..(with the sata raid or sata achi ..) you need to run a 3rd party driver when installing the operation system .. or ....
the quick way .. go to bios by pressing F2 on start .. and in there ..disable teh raid or achi for the hard disk (must be in the ide/sata feature.. where you see the devices for ide.. you have a sata .. setting feature too .. Just select it ..and let it run in compatible mode or non raid . or disable achi ..or sata as ide or native .. depending on the BIOS edition it may refer to the same thing in different ways .. The idea is to disable any function for the hard disk that might require a driver to be installed in order to work ..
after that will boot just right if you have an os on it .. or will be needed another installing from a live disk ..(boot-able disk )
Also check the hard disk options ..and see that some have a second setting for a usb ..and remove it and leave the hdd 0 as primary ) ..This is not the boot priority .. but the actual device ..
]Anyway if you set what I said .. and make a factory default before.. (set it to the factory settings first and after that remove the achi or raid settings ..and save with F10 ) ..and will work .
try it and let me know how it worked out..
Jan 29, 2012 | IBM ThinkPad A31 Notebook
BIOS cant display(in BIOS option no data write there), and i cant chang my BIOS setting. now i cant formeting my leptop, & any operating system i cant install. at pesent o/system is win7...
to get into bios hit f-2 at start up go to bios and restore it to default setting
if you have a sata hard disk then disable it in bios setting
or RAID Auto/Ahci to RAID Auto/ATA
then reboot from installation disk hope this helps and remember to vote
Nov 29, 2010 | Computers & Internet
Hd dead, tried both usb flash drive and a usb
you need to reinstall the operation system ..and do it from a bootable disk ,,,if during the install it is saying that a hdd was not find in the system ..this is a issue of teh bios setting s incase of a sata hdd..go to bios and default it to factory optimal defaults ..save changes with F10..than go back and see into the devices..or advanced..where the Hdd and cd /dvd (in main or advanced ) drive is listed (on bios) there must be a function named ACHI ..this is now ebnabled as default ..but to run will need a raid driver ..so ..disable it ..Im not sure probably will list auto ..try both ways ..it is related with the bus of the hdd..and needs to be disabled (the ACHI) in order to be seen directly ..as a Sata -ide Bus..
after that ..save with F10 again and install ...it will do now ..with any OK you need I will go for XP..
Jun 03, 2010 | Compaq Presario 700 470024-192 Notebook
GA-8I915G duo boot priorties , need CD First NOT RAID!!!
disable all drives from booting in bios except CD. After first reboot when reinstalling enable the other drives. This should work without a problem
Jan 19, 2010 | Computers & Internet
I just bought a new powerspec g207. When I try
this computer has two hard drives which are raided together to become one. you must first run the RAID drivers disk before trying to install 7.
Jan 16, 2010 | Computers & Internet
I have a Biostar M7VIG-400 motherboard, and I can't install my windows xp, i tried replacing the memory, power supply the DVD/CD drive and even my XP Installation Disc... i need help... tnx
I believe that you have to have a problem in the computer Bios. Some bios versions have a built in anti-virus option that I believe keeps viruses from writing to the boot sector of the hard drive. This can foul the Windows setup process. I would try going into system bios and writing down the current settings on each page. Then reset the bios to the default settings. If you see a virus option disable it. I would also disable the smart drive option on your hard drives. I've seen some of the video settings in the bios interfer with Windows setup but not until later on in the installation hardware detection phase so I don't think that is the immediate problem. I don't know if you're trying to use any kind of raid configuration but if you're not make sure the hard drive or IDE is set to auto configuration mode. I think your failure is due to the setup not recognizing the hard drives properly or being able to write to them properly.
Nov 06, 2009 | Biostar M7VIG400 Motherboard
Bios in my other computer is not fully acpi compliant (blue screen)what can i do ?
This error is typically related to the OS attempting to access the hard drive during install or startup.
So, it sounds like you've got some hardware like a RAID controller that is causing the problems. If you're attempting to install to a single hard drive, disable the RAID controller. If you've just installed some type of hardware, try removing it.
If you don't have a RAID controller, update your Bios from the manufacturer and see how that works for you
Oct 25, 2009 | Microsoft Windows 2000 Professional for PC
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
