Question about Fisher and Paykel IWL12 Top Load Washer
Washer shut down midway through cycle, will not power back up
    Master:
  • 492 Answers
Sometimes things can get out of sync. Try unplugging the machine for a few hours to rest the code on the board.
Posted on Oct 15, 2013
Testimonial: "Thanks I'll give it a try"
Hotpoint wma48 shuts down anywhere during cycle
which suggests possible the faulty door lock has been fitted with another faulty door lock. this has happened to me on two or three occasions in different situations.
May 23, 2016 | Hotpoint Washing Machines
Washer just shuts down
If the washer is turning off mid cycle then the problem most likely has something to do with the draining or the filling.
First check the drain hose is not to far down the standpipe. If it is to far down then the water might siphon out during fill. The water would fill and drain at the same time. One cycle I would like you to try is the "Rinse Only" cycle. This is a simple, short cycle that should just fill once, drain and spin. If the washer will do this then the major components are most likely okay.
Make sure the water drains out and let me know if the drain pump is the source of the noise you hear.
Oct 19, 2012 | Washing Machines
The washer cuts off midway through cycle and will not start again after pushing start button. It will, however start after a few minutes of wait time.
That is usually an indication of a thermo-switch reaching it upper level. Cuts off everything until things cool down.
Jun 07, 2011 | Dryers
My LG washer powers off completely after running through a cycle. The only way to get it to turn back on is to either unplug it from the wall or flip the breaker. It doesnt seem to be throwing the...
I had the same problem with my LG washer today. I found another post that said to hold down the start pause button 5 seconds, plug back in so you have power, run on drain/spin at highest spin speed. I did it and so far after each load it has not shut down.
Jan 26, 2011 | LG WM-2277HW Front Load Washer
My washing machine does not complete full cycle it washes and then shuts down at rinse cycle. When advanced over first issue it will complete the cycle.
Your problem is going to get worse, really soon. The DC motor on the bottom of the washer needs to be replaced. The windings inside the motor have shorted together and cause it to draw too much power, shutting down the washer. The motor is expensive, home warranty covered mine.
Oct 08, 2010 | Fisher and Paykel GWL11 Top Load Washer
Shutting down on rinse cycle
Hi this could means that you may need to replace the washing machine bearings. Once the bearings are bad, the motor overheats and it will automatically shut down after the first rinse.
Timonty from WashingMachineAdvisor.com
Jul 28, 2008 | Kenmore 44072 Front Load Washer
Kenmore Elite HE3t
The machine control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check Wire harness connections between the Drive Motor/Tachometer and the Motor Controller, and between the Motor Controller and the Machine Control
• The Drive Motor has failed
• The Motor Controller has failed
Jun 14, 2008 | Kenmore Elite 45986 Front Load Washer
My Canon A75's lens got stuck midway while shutting off, and now I can't switch it on
Usually, this indicates some obstruction (sand, grit, a piece of plastic) has jammed your camera gears sys. send it to me and I will e-mail you an estimate N/C. www.flcamerarepair.com
May 06, 2008 | Canon PowerShot A75 Digital Camera
Fisher and Paykel IWL12 Top Load Washer Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
