Question about Emerson Smartset Clock Radio
Low battery radios cks3095 041707
My projector is not projecting and is flashing low battery. Will replacing the battery fix this problem
Pf 254 projector stopped working. How do I fix it?
The main power supply regulator section fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Mar 29, 2015 | Paul Frank Projection Clock Radio Model:...
Temp and lamp lights flashing
can you let the projector work well
if the projector projects the image,
does the projector light?
if the projector work well ,but the indicator lights flashing,that means the projector is ok ,
you only need to reset the timer of lamp and to reset the timer of the filter,
menu-setting-advance-reset-the timer of the lamp
menu-setting-advance-reset-the timer of the filter
Apr 28, 2014 | 3M S15i 165Watt 2000Hrs HSCR Projector...
Red warning light
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
Have a 50 inch samsung projection tv model hlt5075sx/xaa lamp code bp9601653ap132w turn tv on lamp stays on for approx 20 seconds then 3 blinking lights on right bottom side start blinking if it is the...
The blinking lights will be flashing a code.....
Can you please indicate the sequence of the flashing lights, as this will determine what needs to be done to fix your fault.
Cheers,
Jun 16, 2011 | Samsung - Projection TV replacement lamp...
Projector shuts off within 30 seconds of power on
is the led lit on the top of the projector? what colors?
green is ok.
red flashing in sequence:
2 times- lamp hours exceed 200 hrs. replace lamp.
3 times- lamp failure. replace lamp.
4 times- fans not working. remove obstruction or replace fan.
5 times- temp too high. clean thoroughly.
solid red- undiagnosed error by projector. possible power supply or ballast.
also make sure the lamp door switch is working.
Aug 07, 2009 | InFocus LP 820 Multimedia Projector
Time projection repeatedly either fails to turn on/off/lock
You have to change the internal battery. The type of battery is a CR2430. This battery has only a three year life span in ideal conditions. If you have had power outages or left the Clock/ Radio unplugged for long periods of time the battery life shortens. You can find the battery is most electronic stores and in large drugstores and supermarkets. Fry's electronics, Radio shack.You must unplug the radio from the plug and let the microprocessor discharge and reset itself. This will take about a hour. After you let it discharge, you can put the new battery in the Clock/Radio and check to see if the problem is fixed.If this does not fix the problem, you have a damaged microprocessor and will have to buy a new clock/radio. Emerson does not provide out warranty service for this product. I hope this information help you with your problem.
Apr 05, 2009 | Emerson Smartset Clock Radio
Screen flashing
What I have done in the past is to change to project to high power mode for some time and then change it back to low power mode after 20-30 mins. This fixes the flashing light issue, at least temporarily.
Mar 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
Flashing red light
sounds like a flaky power supply or lamp ballast
Jun 01, 2008 | Radio Shack Cinego D-1000 Multimedia...
Emerson Smartset Clock Radio Logo
43 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
