Question about Craftsman Air Tools & Compressors
WhaT SIZE breaker and wire do I need for a 40amp 230 volt motor and what type of receptacle do I need
  • 2,113 Answers
You need a double breaker in Canada/USA 2 wire and a ground at #8 AWG Your local electrical supply often has a list or graphic of the different plugs that must be used for specific voltages and currents. You just have to choose either a twist style or a push in style.
Posted on Oct 15, 2013
4 Suggested Answers
darjr
  • 378 Answers
SOURCE: wiring installation for ss5l5 IR 5hp 60 gallon compressor
A #10AWG wire can be use and 40Amp breaker can be use also. Your 5hp/230V/1/60hz motor amp is 30A.
Posted on Jun 01, 2009
  • 98 Answers
SOURCE: how to wire it up
if the unit has a starter on it there will be 2 terminals at the top of the starter connect the incoming wires two these terminals making sure that the 2 wires do not touch each other. If unit has only a pressure switch the wires should be tied to the terminals marked line , 1 wire per terminal please.
Posted on Jul 21, 2009
buffalonyman
  • 1865 Answers
SOURCE: need wiring diagram for a ge triclad motor
Not all motors are dual voltage, the motor must state on th ename plate that it is dual voltage and can operate on 115
Posted on Oct 23, 2009
230 volt welder
Breaker must be 50A and the size wire should be a 8/3.
Feb 23, 2014 | Welding Tools
T-30 wiring changing from 460 volts to 230 volt 3 phase
There are several items that will need to be changed or replaced. First rewire motor. Remove weather head cover. On the motor will be a tag that shows how to wire for 460 volts and 230 volts.Check the tag and present wiring to make sure they match. Then look at the 230 wiring and change wiring per motor tag. Again check the motor tag to see max amps at 460 volts and 230 volts. 230 volts will be higher than 460 volts. Check the starter (if so equiped) to see how many amps its rated for. You will probably have to replace the starter. Make sure it has a 230 volt coil. Next size the overload heaters for your amperage. This conversion is not a simple task unless you're familiar with electrical . Good luck!!!
Next the starter coil will need to be replaced with a 230 volt coil
Nov 27, 2011 | Ingersoll Air Tools & Compressors
I believe I might need to change my (20 amp) breaker switch that is running on 10-2 wire which supplies power to my Rheem Classic 10 Seer. I'm not sure if I need to have 220V of power on a 30amp...
Hello, the unit runs on 220 volts that's why # 10 wire must be used. The best bet is to use a 40amp breaker for 220 volts, gives the circuit more protection.
Sep 04, 2011 | Heating & Cooling
I just installed Hayward 1.5HP inground and it tells me that if i use the 115v to use a 30 amp breaker - and when i left the 230V button positioning inside the back of the pump and connected with a 14 ...
double the amps, 230 runs cooler (my fav) . 1.5 is 9.6 amps at 230 volt. you will need to set the motor to run on on the lower voltage this is why you are having problems.. also the motor is thermally protected . this why it will run for awhile and shot off .. remember to prime the pump after any pump repair !!!! . jay the pool pump repair guy in longwood florida
Jun 05, 2011 | Hayward 1.5hp Pool Pump Motor Motor A O...
I have a new ingersol rand 80 gal 7.5hp air compressor 230volt single phase and was wondering what size breaker it needs to be put on
Your owners manual spec sheet should give you that answer. However since that unit at max loads should pull 32 to 35 amps I recommend 1.5 times max amps. So approximately a 50 amp breaker. This all based on standard wire size and length of wire run. Also when checking your voltage at load you should be showing 235 to 240 volts.
Jan 09, 2011 | Ingersoll Rand - Rand Type - 30...
Need to know wire size to wire.
12 GA
12/3
You should have instructions?
By Code a separate circuit and breaker-- 20 amp
Dec 21, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
I have a ingersoll rand 30, srats for 20seconds then trips breaker,,,runs great when running
Sounds like the unit is pulling to many amps during start up. Possibilities are: breaker under sized, wire under sized, to long of a run of wire from breaker for wire size,Tank check valve bad. I would check the amps during start up and while running and compare to motor name plate information. Remember at start up the motor may pull 1.5 to 2 times the rated amps on the name plate. Also if this unit has a magnetic starter wire connections may be loose or overloads to small.
Dec 07, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Lincoln mig welder 180, 230 volt 20 Amp Input. BUT! Manual says use ''Super Lag 40 amp Double Breaker, Plug on Welder Is Nema 6-50 ( 50 Amp ) Wleder cord is 12awg. What wire should be used to wire it up in...
Inspector is correct! In wall or conduit wiring awg will always be greater than "open air" wiring. IE: the size of wire coming from your pole ... it's smaller than from your service riser into your meter. Code allows the cord to heat up... open air will cool it down.
Dec 13, 2009 | Lincoln Welding Tools
I have a 2hp compressor motor that keeps tripping the breaker after about 5 minutes of use. i have changed the caps but it keeps popping the starter cap. is the motor just bad?
Our 2 HP Speedaire horizontal tank compressor is rated 115 / 230 volts at 24 / 12 amps, respectively. This means at 115 volts, a 30 amp circuit breaker is the bare minimum. That also means that the wiring should be #10 copper wires for short runs, but the next size up; #8 copper wires would be better connected to a 40 amp circuit breaker. Running at 230 drops the amperage requirement by half, to 12. A #14 copper wire is minimum for short runs with a double pole 15 amp circuit breaker, but #12 copper wires connected to a double pole 20 amp circuit breaker would be better choice.
If the compressor is cord connected (or even directly wired) with the minimum sized wires, it will likely a voltage drop problem unless very close to the panel. This problem is more pronounced as the distance between the circuit breaker and motor increases, or when smaller wires are in the circuit. All the voltage at the circuit breaker does not reach the motor, as it is lost as heat; so the compressor only sees 90 to 105 volts instead of the 115 volts it expects.
If the cords, connections, etc are getting hot, it is a tell tale sign of under-sized wires and /or poor connections. Once you solve these problems, the compressor should run "as advertised " because motors usually don't "go bad" but fail all at once. Unless you have a bearing problem - or there is a problem with the load itself (compressor).
I hope this helped.
Nov 12, 2009 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Air Tools & Compressors Logo
26 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
