Question about Generac 5978 GP7500E GP Series 7500 Watt Portable Generator CSA Compliant Canada
Air blocked will not start - Generac 5978 GP7500E GP Series 7500 Watt Portable Generator CSA Compliant Canada
    Problem Solver:
  • 19 Answers
Check the air filter.
Posted on Oct 21, 2013
My hot air furnace keeps having blow back
If this is not an air circulation problem, or a blocked or partially blocked flue. (or exhaust )
It is probably not starting to burn the fuel immediately, when it starts to come out. This slight hesitation in ignition is causing a larger amount of fuel to start to burn when it first comes on. If this problem is getting worse, the ignightor needs to be adjusted or replaced immediately. This is a small type of explosion that is getting larger.
Feb 02, 2015 | Heating & Cooling
ASTA12JEC Fujitsu Air Conditioning unit. Dear sir or madam. My air conditioning unit is no longer responding to remote control but stays on. It used to work fine then one day it stopped responding.
Start by replacing the batteries to your remote control and make sure there is nothing blocking the IR receiver on the unit itself. If that is blocked by something hanging on it or tape over it from something hanging on it previously.
Jan 31, 2015 | Fujitsu Heating & Cooling
Quantum 4hp powerpro
you have a blocked primer passage take off filter huosing blow dirt out of passage and out of prmerball it might be bad enough to rebuild carb
Jul 05, 2014 | Garden
Opel Corsa - 1.6 - Sail - delayed start
could be a blocked air vacuum line you should see a thin air line coming from the intake and go to the cam cover top check this line as they do block up after awhile and it will cause this problem. also if this is blocked you need to clean out the intake top as this is were it clogging up as well.
Nov 30, 2012 | Opel Corsa Cars & Trucks
Ok i just bought a 02 yz250f ran great for a while then started fouling plugh now it wont run at all ive done everything i can think of spark plug oil gas oil filter air filter etc still nothin it started...
That's a 2 stroker, the problem with two stroke is usually air tightness.
There must be no air leaks from the engine block to the piston block. Check if there is a suspected air leak around the base of the piston block, engine block( carburetor inlet side ), and reed valve. You could see a leak if there is some 2T oil coming out from those areas.
Check also the reed valve that usually breaks down in two stroke engine, the flaps should seat tightly without any leaks.
Check all of that and tell me afterwards what happen.
Hope that helps you out.
Thanks for using FixYa!
Jul 07, 2011 | 2008 Yamaha yZ250F
Furnace pumps oil in and then starts to fire up but only for a few seconds then it stops and starts pumping oil in again,fires up and goes out and keeps going like this
Air in oil line or an air leak at an oil line fitting, low oil level in tank, blocked oil filter oil blocked oil pump strained, bad oil nozzle.
Jan 17, 2011 | Heating & Cooling
What causes freezer to ice up and the refridgerator not get real cold, with all vents unblocked.
((((( In Lamens Terms ))))) The evaperator gets so cold it frosts up. This is caused because freon is compressed and shot out into the evaperator making it cold. There is a fan circulating the air over the evaperator to cool the air in the freezer. As this continues, so much frost can start to block the air flow. (( so what they did, is put a heater in there with a timer so it would defrost the evaperator every 8 to 10 hrs, so the air would keep flowing )) Now if the heater quits working then it will frost and creat a block of ice. The block of ice, blocks the air flow and the air quits getting colder. Also after time the compressor will over heat and shut down untill it cools or burns up.
Jan 12, 2010 | Refrigerators
My IR 2340 air compressor wonr drain with the auto
its most likley to be blocked with muck take it off and give it a good clean
Oct 22, 2009 | Ingersoll Rand 2340/2475 Electric Air...
What the original Key block in the engine? for WV p-variant 95
electronic blocking,you need to have your new key coded to the immobiliser,dealer or somebody with vag-tacho ......
Jan 05, 2009 | 1995 Volkswagen Passat
Generac 5978 GP7500E GP Series 7500 Watt Portable Generator CSA Compliant Canada Logo
Top Generac Electrical Supplies Experts
 Kenneth
Kenneth
Ottoniel
JOHN LAPIER
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
