Cover open message and there are no covers open
On my Samsung CLP550N I keep getting a message cover open, and none are open!
  • echristie1 May 02, 2009
    Hi, thanks for this, but this was one of the first things we checked.
    We opened each door, closed it firmly, turned on the machine and still
    the orange light with the message "covers open" appeared so as the try
    to get it by process of elimination, but no luck. Other ideas would be
    appreciated.
    Scholar:
  • 136 Answers
On Many of these printers, when you recieve this message chances are you either have a "BENT" limit switch sensor or the Tap on the Cover is "Broken or Broke off",
First Step open each cover and close them again sometimes the limit switch isn't being hit correctly by the door Tab
Second- as you open the covers their are tabs that must hit these sensors- make sure their not broken or bent.
Start their and tell me if these resolves the problem chance are the tabs are not hitting the switches correctly and not telling the samsung printer that the covers are closed.
Posted on May 01, 2009
How do I eliminate an erroneous "cover open" error message?
Make sure the printer cover is pushing the cover switch correctly. Also, try spraying the cover switch with WD40. It can clean the contacts and get it working again. Otherwise, have a dealer do it for you.
Jul 16, 2015 | Samsung Sam4s ER-5200M Cash Register WITH...
My printer is giving message that you rear cover is open for that what to do?
SAMSUNG SCX 4521 PRINTER BACK SIDE COVER IS OPPEN SO PLEASE CLOSE THE BACK REAR COVER & CHECK THE PAPPER JAM IN REAR COVER & AFTER CLOSE THE REARE COVER THEN AFTER SEE THE ERROR YOU CHECK THE BACK COVER SENCER & SENCER PCB
May 01, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Getting "inner cover is open" message
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Dec 04, 2009 | Canon Pixma MP500 All-In-One InkJet...
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
Monitor shows nothing on screen, power button on solid, none of other buttons respond.
plz try by removing the connector of the monitor from the back of cpu while keeping your monitor power on. if you get any message in the monitor then your monitor is ok. then open your side cover and try by resiting the ram, you have to swithch off your pc before opening your side cover. If you dont get any thing in the monitor then *********** board is having problem
Apr 13, 2009 | Computers & Internet
MFC 9700 Drum replacement problem
In the box with new drum is manual how to reset this, however, will not show solution for this particular model. So you ned:
1. Open cover (as to replace drum or toner). On display you will get "Cover Open"
2. Press right arrow under LCD display.
3. Press 1 (digit one) on keypad.
4. Close the cover
Done.
Dec 29, 2008 | Brother MFC 9700 All-In-One Laser Printer
Samsung CLP-300 - Cover Open error message, but covers are closed
Front cover is on the right hand side, back is on the left hand side in the middle, and the top cover is like a little button on top. All the others are little openings.
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Turn power off and on again message
turned camera on and off as instructed and i keep getting that same message. lense cover does not open.
Oct 13, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
HP Deskjet 5150 - top cover open
I had the same problem, and the cause turned out to be the cover switch not being fully pushed in. On the underside right edge of the top cover, there's a little triangular protrusion that pushes down a black rectangular button (the cover switch) when the cover is closed. The problem occurs because the flimsy top cover is made of plastic and flexes slightly when you close it. This means that sometimes, the right edge of the cover won't seat properly even though it appears as if the cover is closed all the way. When this happens, the triangular protrusion isn't fully pressing the switch down.
To test if this is this is happening, send a print job to the printer and wait for the "top cover is open" error message to appear. Next, open the top cover door and locate the cover switch. It's a little black button in a rectangular hole at the right edge of the doorway near the ink cartridges. Take a pen or a car key and use it to push the cover switch down. You can also use your fingertip to do this if it's skinny enough. If you keep the cover switch pressed down, the power button should start blinking to indicate a print job is coming through. If the print job actually starts printing, then you know the problem was the cover switch.
In my case, all I had to do the fix the problem was close the cover and make sure it was fully seated by firmly pressing down the right edge of the cover until I heard a plasticky "click" noise. After that, the problem went away.
Hope this helps.
Jul 23, 2008 | HP DeskJet 5150 InkJet Printer
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
345 people viewed this question
jasbo
jasbo
