Question about Ricoh Priport VT6000 Copier
Drum will not go clear in for a ricoh priport 4542
4 Suggested Answers
  • 86 Answers
SOURCE: Ricoh priport jp1210
Press Clear mode > 1 0 7 > and press and hold the Stop button for 3 seconds.
Good luck and please rate me, thanks.
Posted on Jan 22, 2009
newport74
  • 58 Answers
SOURCE: paper jam message, remove the paper from drum
Try cleaning the feed rollers with soap and water and a damp cloth and see if your situation improves. sounds like the machine is missfeeding but your description was a little vague.
If it does improve youll need new rollers.
Also try flipping the paper over to see if improves.
Lastly does the paper size displayed on the screen match what is actually loaded? if not... correct as nessesary
Good luck
Posted on Apr 19, 2010
SOURCE: ricoh priport jp 1010 error code E 02 explain this
when powering on, ricoh priport jp 1050 indicated 02
pls help how can solv
Posted on May 08, 2013
Ricoh VT6000 lcd is on but no commands will respond. Have tried everything in the manuals. What's next ?
Ricoh VT6000 and postscript controller cpif-26 ' Adobe Community ...
https://forums.adobe.com/thread/1718082?start=0...0
Adobe Systems
Feb 27, 2015 - 2 posts - ‎1 author
Have printer Ricoh VT6000 - very old but good and still working, have ... But there isno drivers for CPIF controller and also for printer for new windosw 7 for example. ... Canyou advice what to do to install those printer and controller on win xp? ... Dov Isaacs Feb 27, 2015 9:23 AM (in response to witer30).
[PDF]UC5Operators 1-5.PM6
rfg-esource.ricoh-usa.com/stellent/groups/public/.../rfg000936.pdf
or transmitted in any form, including but not limited to electronic, photocopying, mechanical ... holders. Ricoh and PriPort are registered trademarks of Ricoh Japan. ....VT6000/5390/1295/CP390/3400DNP/SD600. ZipRIP Pro A ... Once the UC5 has been installed, you will need to install a GDI printer driver. Please follow the
Jan 18, 2016 | Ricoh Priport VT6000 Copier
What does error code E-06 mean on a ricoh priport duplicator mean?
It's a main motor error. Check the sensors at the back when you remove the drum. Check to see if the sensors are in place.
Jan 21, 2015 | Ricoh Office Equipment & Supplies
Jam on ricoh priport jp5000
Page 190 of the manual has some places to check:
http://www.manualslib.com/manual/140763/Ricoh-Priport-Jp5000.html?page=190#manual
Dec 14, 2013 | Office Equipment & Supplies
Ricoh priport vt 3800
when it print remove some of letter
Jun 11, 2013 | Office Equipment & Supplies
Ricoh priport jp 1010 error code E 02 explain this code to me.
Jun 10, 2011 | Ricoh Office Equipment & Supplies
Ricoh DX4640PD priport machine with SC556 code - what is this, I can't get past it to open the drum unit or anything? Thanks
And how about error code SC553?i try log in test mode and use program clear mermory.the machine still code SC553
Apr 04, 2011 | Ricoh Priport VT6000 Copier
Error message E02
Ricoh Priport VT-2100/2130/2150/2300/2500/6000
E 01 Malfunction in cutter section: The cutter motor does not reach both right and left cutter position detecting switches within 2 seconds 1) Drive wire cut
2) Drive section malfunction
3) No power supply E 02 Malfunction in the paper table drive section: The lower limit sensor or the paper table height sensor is not turned off even though the paper table UP or Down signal is applied 1) Drive worm gear broken
2) Mounting screw of the worm gear broken
3) No power supply
Apr 01, 2010 | Ricoh Priport VT6000 Copier
Need a troubleshooting guide for a Priport VT6000.
ther are none, but if you describe your problem maybe i can walk you through it
Oct 01, 2009 | Ricoh Priport VT6000 Copier
Paper Sticking to the drum
Check in what condition separators drum.
Sep 06, 2009 | Riso RZ220 Duplicator
Dec 21, 2008 | Ricoh Priport VT6000 Copier
19 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
