Question about Swintec 7040 Typewriter
I have a plastic on my print wheel do i remove it
  • 46 Answers
Your description of plastic is not clear. If you mean the plastic case it comes in, then remove the printwheel from the case. Other than that the printwheel should be just the plastic fingers on a hub. You can see a sample on the www.swintec.com website. Hope this helps.
Posted on Oct 24, 2013
IBM Wheelwriter 6 typewriter. The print wheel does not move when typing and acts as if in stencil mode
From your posting it sounds like you have cracked plastic print solenoid cap. We sell them for 20.00 with instructions.
DickyO
216-269-3918
Apr 29, 2014 | IBM Wheelwriter 6 Typewriter
I brought a swintec 7040 and on my print wheel there is a plastic on it do i remove
If the plastic is packaging, do remove it. The printwheel should be inserted as a black hub with black hard plastic fingers. The hub snaps into place on the hub wheel either by you snapping it into place or by you sliding it into a slot and pushing a lever to put the printwheel carrier into home position. You can see a sample of the printwheel on www.swintec.com.
Oct 15, 2013 | Brother ML-100 Typewriter
The paper will not feed at the moment of printing so disconnected printer on doing so to remove it from the office a small white plastic wheel dropped out Is this fixable or is the printer naff
Yes the printer is fixable, the while plastic wheel which dropped down was the rollers wheel which can be fixed by a technician. And the problem with paper not feeding is due to dirt in the roller or paper jammed inside. Hope this helps.
Please rate if the solution was helpful, thanks!
Jul 14, 2011 | Lexmark Office Equipment & Supplies
I don't know how to remove the print wheel.This is an Olympia Standard Electric typewriter, part of a word processor system. I need to order a new print wheel, but can't get the old one out. I...
Assuming this is an older oly you need the upper clear plastic portion of the printwheel case. Insert it onto the case, it unlatches the wheel.
DickyO
May 24, 2011 | Office Equipment & Supplies
I have a bosch ergomaxx 2000w which I need to strip down and clean. Ive found 6 torx screws bit still can't remove the coloured plastic cover. How do I remove it?
Got the same !
Remove both back wheels (just pull gently with a screwdriver), then with a big screwdriver pull the cover while pulling plastic locks in the side holes (under the wheels) whith a small screwdriver.
Jan 16, 2010 | Bosch Vacuums
MY PRINTER WORKED FINE LAST TIME I USED IT... NOW WHEN I PUT PAPER IN AND START TO PRINT IT PULLS IT DOWN LIKE NORMAL THEN LIKE STARTS EATING IT. THEN IT SAYS PLEASE LOAD PAPER AND I HAVE TO PULL THE PAPER...
you have a small piece object stuck inside the printer wheels. turn off (unplug) printer. then get a small piece of plastic. I use half of a thin plastic binder or any thin plastic you can find about the thickness of 2 sheets of paper. must be rigid plastic not flimsy. ((Even a pice of cardboard same thickness (2sheets) of paer will do the trick)) insert this from the back of printer where paper goes in and you should see the jam come out at the bottom of the printer. be very careful(gentle) as these wheels can become dislodged or break if you are very rough with them. once removed you may also want to turn pringter upside down (again carefully) they are light but just be careful. this may help to remove debris. Once cleared and printeing properly... always remove paper when not in use and cover top of printer with a towel. This will prevent pet hair etc from getting into the wheels (feeder of printer and extend the life of your printer. Although they seem to be cheaper to buy a new one when the ink runs out sometimes LOL :)
Hope this helps
Roty :)
Jul 10, 2009 | Lexmark X3550 All-In-One Printer
Part broke off and I can not identify it
I have my MFC-235C (same but for LCD screen and card reader) dismantled on my table right now.
On the bottom of the printer , after I have removed the printer tray there is, from 3/4 of the way to the back of the printer, to the back of the printer, a base sheet of gray plastic.
This is shaped in a wide "V" with the apex towards the back of the printer.
In the apex of the "V" is a white plastic coomponent with 2 hooks towards the front and a flap towards the back.
It is fixed between the two grey wheels and appears to just clip onto the outsides of the black plastic fins that are on each side of the white plastic gear-wheel that is in the centre of the apex on the printer base.
You may find it easier to see how to replace it from the back of the printer. There is a shield there that is removable in case of paper jams.
The white plastic appears to have some sort of "spring" occuring. But I cant see if that is built into the white plastic component or something external.
DIAGRAM OF BASE OF PRINTER: "V" marks location
front
oooooooooooooooooo
o o
o o
o o
o o o o
o V o
o o
oooooooooooooooooo
back
Oct 23, 2008 | Brother Multi-Function Center MFC-240C...
Jams coming out of cassette at U-Turn, Black Guide has spring on it
Remove the peice as shown in the photo below to reveal the feed wheel beneath.
Open the top cover and remove the screw just to the left of the white/clear section shown in the photo below.
The smoked plastic peice will unclip from the fron end by grasping the inner most edge and gently rocking up and inward. This will reveal the entire feed wheel.
Clean the entire wheel in the above photo with a damp (Not soaking, just damp) cloth. The wheel will turn making a clicking sound (top inward) allowing you to clean it entirely. Also clean the obligue roller (1st part removed) with a damp cloth and blowing out.
Reassemble as you just took it apart. Pay close attention to the smoked plastic peice that it gets front clipped properly back into place. Don't force it. It will all go back together relatively easy.
That should help eliminate a lot of your jamming issues.
Hope the above helps you. :)
Aug 25, 2008 | HP LaserJet 4L Printer
Paper feed
Feed roller is dirty or worn thin, wipe rubber roller with damp cloth.
Nov 03, 2007 | Kodak EASYSHARE Printer Dock Thermal Photo
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Swintec 7040 Typewriter Logo
55 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
