Question about Brother ML-100 Typewriter
I brought a swintec 7040 and on my print wheel there is a plastic on it do i remove
  • 46 Answers
If the plastic is packaging, do remove it. The printwheel should be inserted as a black hub with black hard plastic fingers. The hub snaps into place on the hub wheel either by you snapping it into place or by you sliding it into a slot and pushing a lever to put the printwheel carrier into home position. You can see a sample of the printwheel on www.swintec.com.
Posted on Oct 24, 2013
I'm typing words, but the typewriter is typing jibberish, how do i fix?
make sure the lang button is set for the print wheel try pressing lang and typing
Feb 29, 2016 | Swintec 7040 Typewriter
Swintec 7040
If you mean that it types the wrong letters check the pitch slide switch on the left of the ketboard. it should be in 10 or 12 not in PS.
DickyO
Nov 25, 2013 | Swintec 7040 Typewriter
How to reset the swintec 7040 back to factory settings
Turn off, hold down on the MR (margin release key) and turn on, machine will print some numbers and then print lines of types, let it print a couple lines then turn off and turn on.
Oct 23, 2013 | Swintec 7040 NEW Electronic Business...
I have a plastic on my print wheel do i remove it
Your description of plastic is not clear. If you mean the plastic case it comes in, then remove the printwheel from the case. Other than that the printwheel should be just the plastic fingers on a hub. You can see a sample on the www.swintec.com website. Hope this helps.
Oct 15, 2013 | Swintec 7040 Typewriter
Memory on Swintec 7040 is irratic. Copy is correct but tabs move around.
Spray a little WD40 on the silver shaft that the carrier slides on.
DickyO
Sep 17, 2012 | Swintec 7040 Typewriter
How do I change the code associated with the printwheel on a swintec 4040. I changed the wheel but now the keys are not synced with the new wheel.
make sure the slide switches are all in the proper settings, turn the machine off then back on, the print should be ok
Apr 28, 2010 | Swintec 7040 Typewriter
Swintec 7040 typewriter - what is the code key and mode key for
The code key works with all the keys in the top row to set up those functions, bold, underlind, KDII, etc. The function allows you to type on the display befor printing.
DickyO
Apr 23, 2010 | Swintec 7040 Typewriter
Typewriter Print Wheel
Depending on which printer you have there should be a red or black lever beside the print solonoid, push to the rear and the P/W should lock into position.
DickyO
Jul 13, 2009 | Swintec 7040 Typewriter
Swintec 7000 Typing Problem
Try Code comma, peroid or slash one of them will get you out of the overstrike ribbon mode.
DickyO
Jul 08, 2009 | Swintec 7040 Typewriter
First check check the pitch selector switch to be sure it is not in proportional spacing. if it isn't push down on it and see if it goes away, if is goes away the keyboard needs repaired.
DickyO
Feb 21, 2008 | Swintec 7040 Typewriter
Brother ML-100 Typewriter Logo
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
