Question about Polaroid i1237 Digital Camera
Flash bulb Can the flash be replaced in this camera? If so, any suggestions on where to find one? Thank you for your time.
    Scholar:
  • 106 Answers
These cameras are not made to be user serviceable. Replacing the flash, while probably possible, would require dismantling the entire camera.
Posted on Oct 16, 2013
My flash has stopped working! still pops upjust wont go off! camera hasnt been dropped etc.
Unfortunately it sounds as if your flash bulb has burnt out. Although flash bulbs are made to last a very long time, this happens occasionally, just like the lights in your home go out sometimes before their expected end-of-life time and have to be replaced. Repair shouldn't be too very expensive, but instead I would suggest putting the money that you would spend for a repair towards getting a full powered external flash, such as the SB-600. This will allow you much more flexibility with your flash pictures, and will increase your flash picture quality considerably.
Dec 17, 2010 | Nikon D60 Digital Camera
Flash does not fire consistently
Have you tried replacing the bulb at all or check to see if it may be loose or not have a good connection which may cause it to work sometimes but not all of the time
Jun 29, 2008 | Metz Mecablitz 60CT4 TTL Flash
Flash
HI,
Most likely your flash bulb burned out or was damaged. If you feel comfortable opening your camera you can buy a flash module on the internet or ebay for around $20-$25 and install it yourself. If you do so, be VERY careful NOT TO TOUCH the capacitor as those things can store a massive amount of voltage even when the battery is removed and the camera has been off for some time.
If you don't feel comfortable opening your camera and trying to replace it yourself, my suggestion would be to get it repaired or replace it if it is still under warranty.
Goodluck..
May 14, 2008 | Canon PowerShot SD850 IS Digital Camera
Flash of my Canon PowerShot SD1100 IS not working at all
Has the camera been dropped at all? It may need a new bulb. Most camera stores replace them rather cheap.. But if you want to do it yourself..
How to Replace Your Digital Camera Flash Bulb Like any light bulb, your camera flash bulb can blow at any time. The rest of your camera might be state of the art, but the flash bulb itself is relying on some pretty old fashioned technology. Unlike a light bulb, however, replacing a flash bulb can be a little difficult. Depending on the type of camera or flash you have, some dissection might be required.
Step 1: Choosing the Bulb There are literally dozens of different shapes, sizes and connectors used for camera flash bulbs. These will typically vary depending on the manufacturer. However, be warned, many manufacturers will use different types of bulbs in different cameras. Just because you have a Fuji camera, for example, doesn't mean you can buy any Fuji flash bulb.
Step 2: Safety First Camera manufacturers will never advise you to replace the camera bulb yourself unless you know exactly what you are doing. This is because your camera's flash uses very high voltages. A capacitor will be charged up in order to fire the flash. This capacitor can stay charged for months, if not years. If you're not confident doing this job yourself, then you will need to take it to a camera repair shop.
Sometimes if the camera is too old, you might consider using it as an excuse to upgrade it for a newer model rather than repairing it.
Step 3: Dismantling the Camera Now, you will need to dismantle the camera carefully so that you have access to the flash bulb itself. This may be time consuming and nerve-wracking. One false move could end up breaking the delicate plastic case of your camera.
Once the camera is dismantled, you should then discharge the capacitor safely so that you can continue to work on the camera.
Step 4: Removing the Old Bulb Most bulbs are soldered directly onto the circuit board. In this case, you will need to use a soldering iron to heat up the solder at the back of the bulb and carefully pull it away from the board. This can be difficult, as you need three hands to do it properly. With the old bulb removed, try to clean up the solder pads as much as possible so that the new bulb can fit properly.
Step 5: Replacing the Bulb Push the legs of the replacement flash bulb in position through the holes in the circuit board. Then, using a soldering iron and some solder, fix it in place. Be as accurate as possible to prevent shorting out the circuit. With the bulb in place, cut back the legs of the flash bulb so that it doesn't stick out too far from the board.
Step 6: Reassembly With the replacement flash bulb fitted in the digital camera, you will then need to reassemble your camera. This will be easier if you kept all of the screws in a safe place.This is the one occasion where it's a good idea to assemble before testing simply because of the high voltages involved.
Step 7: Testing Now, put the battery back in the battery and try taking a photo with the flash. Check whether it works; if not, you will need to investigate the cause of the problem
Nov 03, 2010 | Canon PowerShot SD1100 IS Digital Camera
Easyshare Z8612 IS Digital Camera: My flash bulb has blown and I need to know how to ...
May 17, 2010 | Kodak Easyshare Z8612 IS Digital Camera
Nikon Speedlight SB-20 makes sparking noises
bulb is gone replace the flash bulb near by service centre
Jun 15, 2017 | Nikon Cameras
How to replace bulb in flash for a Kodak z710
Dec 31, 2009 | Cameras
The flash made a pop noise like the bulb failed. The camera works, but no flash. Are parts available or who can repair the camera? Thank you.
Hi Dear,
Yes your are correct in saying that the flash made a pop noise like a bulb failed.
The flash of a camera also consist of a bulb which when triggered give live for a very short span of time.
In your case as observed from your sayings, the flash bulb have failed. It is not a big issue.
As a camera is a delicate object. I would suggest you to take your camera to the authorized service station only and get the bulb replaced by the expert hands only.
Hope this will work out for you. If there are any more queries in this regard we would love to hear form you. We will be obliged to solve your issue.
Have a nice day.
Nov 11, 2009 | HP R967 Digital Camera
Nikon D50 -flash won't fire
Try pushing the flash forward just a tiny bit. this model of Nikon has a built in problem with the flash popping up too hard. You can also try to "soften" the pop-up action with your finger instead of just letting it snap up into position.
Sep 12, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Lumix DMC-FZ7 won't flash
Thank you anyway, but I am going on tomorrow to buy a new camera.
Searching the web now for the best kind and in my price range.
Thank you again.
Jun 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Polaroid i1237 Digital Camera Logo
26 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
