Oce 7055 Copies come out blank
I have just replaced the toner and waste bag, but the sheet still comes out blank with only about 2 inches in the middle have some contents.
5 Suggested Answers
Joed911
  • 4338 Answers
SOURCE: Where do dispose of full toner waste bags?
It depends on where you live.
Do a Google search for " what's the best way to dispose of full toner waste bags?" And add your city,or state on the same line. It will return a list of places to recycle the toner.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on May 27, 2009
Joed911
  • 4338 Answers
SOURCE: 0501 error on a Oce' 7055
1)0501 is low toner concentration problem
fill new toner and then off and on main switch many time
2)check toner motor.
Thanks, Joe
Posted on Jun 18, 2009
  • 100 Answers
SOURCE: COPIES FROM PANASONIC FP7722 ARE JUST BLOTCHY GRAY
yep!
we can say it is common error/malfunction for these series of fp-77xx
it is also called as quarc error
you may fix it by manually adding some toner at the developing unit
or by pressing USER PRESET + 11 + 1 to perform manual add toner maybe up to 5x until you see some improvement.
Posted on Mar 23, 2010
IPMAN
  • 23 Answers
SOURCE: have oce 7055 but its
Restart the printer and put it to the calibration mode. Hope this will help
Posted on Aug 26, 2011
Why are the copies in an oce 7055 copier coming out very dark
The Electrostatics Control is not cleaning up excess toner from your printer drum probably a pro help is required try this - remove the toner and shake it laterally fix it back and check - also at the contrast setting and adjust if required
Jun 28, 2015 | Office Equipment & Supplies
MY BROTHER PRINTER DCP-7055 EORRER REPLACE TONER
This came from the Brother HelpDesk, yes they rang me and it worked.
Cover open Press Clear "Replace Drum?" (ignore this and quickly...) Press Start (blank screen, quickly...) Press Up arrows then switch to down arrow to 00 Press OK
Mar 09, 2012 | Office Equipment & Supplies
Have oce 7055 but its keps saying out of toner even after it has been replaced.
Aug 26, 2011 | Office Equipment & Supplies
WHAT DOES CODE C7990 MEAN ON A COPYSTAR CS-1820
Waste toner reservoir overflow
problem (when the total number of
copies is 100 thousand sheets or
more)
• After E31 is displayed, 1,000 sheets
are copied. Or waste toner exceeds
5 g.
Defective waste
toner sensor or
engine PWB.
Shake the process unit from side to side
and turn the power switch off and then on.
If the problem cannot be solved, replace
the process unit.
After replacing the process unit, turn the
power switch off and then on. If the problem
cannot be solved, replace the waste
toner sensor or the engine PWB.
Mar 30, 2011 | Copystar CS-2030 Copier
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
KYOCERA 1016MFPo ERROR call 7980
Contents: Waste toner reservoir overflow
copies is less than 100 thousand
sheets)
5 g.
Causes: Defective waste
toner sensor or
engine PWB.
Check procedures/corrective measures: Shake the process unit from side to side
the process unit.
Nov 23, 2010 | Kyocera FS-1118MFP Laser Printer
Thanks, Joe
Jun 18, 2009 | Office Equipment & Supplies
Thanks, Joe
May 26, 2009 | Ricoh Aficio CL3500N Laser Printer
Canon Copier Model C122F - error light flashing
A common mistake is that people think that the waste toner needs to be emptied and instead the toner needs to be replaced --- and vice versa. Check to make sure that the toner bottle is not empty. Also, if you made copies that took ( used ) more toner then the machine was able to replenish, the machine has not had a chance to catch up. Place a white sheet of paper on the platen glass and make blank white copies. You may only be able to get 1-2 copies at first but as the device catches up with the toner replenish you should be able to make more. The blank copies you make -- do NOT put that paper right back into the machine. Lay it flat and let it cool, this will help prevent unwanted jamming due to heat build up in the paper. IF you have good amount of new toner in the machine, gently tap the front line ( or rear line) that feeds the used toner into the waste bottle. Sometimes the waste toner will clog and back up into the machine giving false 'waste toner full' message.
Jan 04, 2009 | Canon Office Equipment & Supplies
Waste Toner for GP200 series
The waste toner is collected inside the drum cartridge. It can be emptied by removing the drum cartridge assy and opening the opaque window and emptying into a large bag. The lines on your copies are probably a symptom of the drum being worn out, so replacement is probably a better option. The drum is good for 60,000 copies.
Jul 17, 2008 | Canon IMAGERUNNER 6570 Copier
jasbo
jasbo
