Question about Nikon Eclipse E400 Microscope
What type of lamp should I order to replace the one which burned out for the pointer?
Burned out lamp RCA DLP TV Mod # HD50LPW165YX4 lamp type B
you can get the replacement lamp cartridge from the following link which also has installation instructions. Your model uses the 265866 lamp assembly.
http://www.tvrepairworld.com/rca_dlp_lamps
Aug 04, 2012 | RCA Televison & Video
Do I need to order the housing with the lamp after burn-out?
you can order just the bulb then install that in your housing. Being careful not to touch the new bulb with your bare hands as the oils from your finger tips will cause the lamp to fail prematurely.
Feb 07, 2012 | Mitsubishi WD-60735 Projection Television
How to find out lamphour in PLC-XT11
hi
do the follwing setting on your projector to reset the lamp hour
1.Turn projector on, press MENU button and ON-SCREEN MENU will appear. Press POINT LEFT/RIGHT button to move a red frame pointer to SETTING Menu icon
2 Press POINT DOWN button to move a red frame pointer to "Lamp counter reset" and then press SELECT button. The message "Lamp replace counter reset?" is displayed. Move
the pointer to [Yes] and then press SELECT button.
3.Another confirmation dialog box appears and select [Yes] to reset Lamp Replace Counter.
ok
Feb 02, 2011 | Sanyo PLC-XT11 Multimedia Projector
Canon LV-S3 how to check hours on the lamp? do I have to have unit hooked up to an input source?
Be sure to reset the lamp replace counter after Lamp Assembly is replaced. When the lamp replace counter is reset, the LAMP REPLACE Indicator stops lighting.
Note : Do not reset the Lamp Replace Counter until after the projection lamp is replaced.
1. Turn projector on, press MENU button to display the On-Screen Menu. Press Point left or right button(s) to move the red frame pointer to the Setting Menu icon.
2. Press Point down button to move the red frame pointer to "Lamp counter reset" and then press SET button. The message " Lamp replace counter reset? " is displayed.
Move the pointer to [Yes] and then press SET button.
3. Another confirmation dialog box appears and select [Yes] to
reset the lamp replace counter.
This projector uses a high-pressure lamp which must be handled carefully and properly. Improper handling may result in accidents, injury, or create a fire hazard.
 Lamp life may differ from lamp to lamp and according to the environment of use. There is no guarantee of the same lifetime for each lamp. Some lamps may fail or terminate their life in a shorter period of time than other similar lamps.
 If the projector indicates that the lamp should be replaced, i.e., if the LAMP REPLACE INDICATOR lights up, replace the lamp with a new one IMMEDIATELY after the projector has cooled down.
( Follow carefully the instructions in the LAMP REPLACEMENT section of this manual. ) Continuous use of the lamp with the LAMP REPLACE INDICATOR lighted may increase the risk of lamp explosion.
 A Lamp may explode as a result of vibration, shock or degradation as a result of hours of use as its lifetime draws to an end. Risk of explosion may differ according to the environment or conditions in which the projector and
lamp are being used.
IF A LAMP EXPLODES, THE FOLLOWING SAFETY PRECAUTIONS SHOULD BE TAKEN.
If a lamp explodes, disconnect the projector's AC plug from the AC outlet immediately. Contact an authorized service station for a checkup of the unit and replacement of the lamp. Additionally, check carefully to ensure that
there are no broken shards or pieces of glass around the projector or coming out from the cooling air circulation holes. Any broken shards found should be cleaned up carefully. No one should check the inside of the projector
except those who are authorized trained technicians and who are familiar with projector service. Inappropriate attempts to service the unit by anyone, especially those who are not appropriately trained to do so, may result in an
accident or injury caused by pieces of broken glass.
Dec 24, 2010 | Canon LV S3 Lamp
I'm looking for the pig tail or the part where the wire hooks on to the lamp
I think you have to replace the whole lamp socket as the wires are permanently attached to it. I found the sockets online with Google searching for "Socket XX" where XX is the type of lamp specified on the units. They are not expensive BUT the vendors have a minimum so I had to order 6 of them and also some spare lamps to meet the minimum. The wires of the socket you get will have to be trimmed like the original ones for length. These sockets like to burn up. Getting the screws into the socket in the lamp holder I remember is a bit frustrating.
Dec 23, 2010 | Chauvet (2) Chauvet Intimidator Scan Led...
Red lamp light is blinking. Replaced lamp and light is still blinking.
The lamp still does not light up after the new lamp installed? Or the lamp is working but the Red lamp still blinking? Reset the lamp timer after the lamp is installed?
Description of product:
Replacement RPTV projector lamp HITACHI 50C10
Supplied equipment: gloves, filter
Lamplife (hours): 5000
Performance (W): 100
Lamp type: UHP
Changing the lamp:
1. Turn off the projector and unplug it. Let the projector cool for at least 45 minutes. The hot lamp can burn you!
2. Find the lamp cover on the projector and remove it by loosening the screws on it.
3. Use a proper screwdriver to loosen the screws which secure the lamp inside the projector.
4. Grasp the lamp by its wire handrail or handle plate and carefully remove it.
5. At this point, always clean the projector and replace the air filter which provides air to the lamp.
6. Install the new lamp according to the aforementioned instructions in the reverse order.
7. Turn on the projector and turn the lamp operation counter to zero.
Changing a bare lamp without module:
4. Grasp the lamp by its wire handrail and carefully remove it.
6. Remove all impurities from the lamp module. If it is damaged, or if the connectors are oxidized, order a new complete module - you will thereby prevent and potential damage to the lamp or to the projector!
7. Examine and remeber in detail the method by which the lamp is fastened in the module, and the method of clamping the connectors - or mark the original connection.
8. If one of the connector parts is firmly fastened to the lamp, it will be necessary to disconnect it. Plug the cable eye to the end of the connector. The cable eye is included with the lamp.
9. Carefully remove the old lamp from the module. Wear a glove when installing the new lamp. The glove is included with the lamp. Never touch the lamp with your bare hand!
10. Insert the new lamp into the module and tighten the connectors.
11. Install the new lamp according to the aforementioned instructions in Numbers 1 to 5 in the reverse order.
12. Turn on the projector and turn the lamp operation counter to zero.
Reset the lamp counter hours of operation for the projector HITACHI 50C10
1. Turn on the projector
2. Press the "RESET" button on the remote controller for at least 3 seconds and the dialogue window will appear
3. Select the "RESET" function
4. The counter is at zero
Product websites:
www.hitachi.com
Dec 03, 2010 | Hitachi 50C10 LCD TV
Lamp replaced 1.5 years ago, now the picture goes out but comes back on every few minutes, as if it gets to hot and needs to cool down. Fan comes on.
Lamps only last for 5,000 hrs -8,000 Playing hrs
It means every hour you Play TV Lamp burns up the hours, so after 5,000hrs on most Lamp needs replacing, some Lamps dont even last this long DLPs are not like Projection you can play them 24-7 and Tubes will remain good, But Lamps are like a light bulb they all burn out after so many hours.
Best thing is to turn TV off if you are not watching it, in order to Save Hours burt on Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Replace the Lamp.
Mar 05, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
Light bulb burning out.
My guess is you didnt get the correct value lamp for your application. Sears doesnt have the proper lamp for your machine - of you didnt want to get it from them?
Try again at Sears or RepairClinic.com for the proper lamp.
I hope this helps you
a
Oct 02, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Lamp life indicator reset
Click Sanyo Support to download Instruction Manual copy and check page 39 for details about Lamp Reset procedure.
Apr 30, 2009 | Sanyo PLC-XT16 Multimedia Projector
Error 50.6 in hp laserjet 9500hdn
  • HP II/III series most likely cause is the ac power module is defective. Order the HP II/III Service 50 Error Repair Kit. If the quartz fuser lamp is burned out, order the replacement fuser on specials page. Slight possibility of loose connector on DC controller. See tweaking page DC controller could also be defective, but this is very rare.
  • HP IIP/IIP+/IIIP most likely cause is burned out quartz lamp. Order the HP IIP/IIIP 50 Service Error Repair Kit. Could also be a failure of the power supply.
  • HP 4/4+/5 most likely cause is burned out quartz lamp. Order the HP 4 Service 50 Error Repair Kit. Could also be a failure of the power supply.
  • HP 4L/4P/5L/5P/6L/6P most likely cause is a bad ceramic heating element.
  • All other printers most likely cause is burned out quartz lamp. In rare instances the ac power supply has failed. Even rarer, the DC controller is defective
Jan 22, 2009 | Office Equipment & Supplies
Nikon Eclipse E400 Microscope Logo
156 people viewed this question
Top Nikon Science & Laboratory Experts
matt
matt
Don A
Don A
Are you a Nikon Science and Laboratory Expert? Answer questions, earn points and help others
