Question about Drills
Drill overheat when drilling in hard oak wood my drill bit overheats. Will a bar of soap on the drill bit help?
    Genius:
  • 1,114 Answers
Soap might work. Some use candle wax, bees wax, WD 40. I've prayed silicone on the drill bit. Using moderate pressure and low speed definitely helps, and it is essential to clear out the hole of chips frequently. So drilling in increments works. You drill a little, lift the bit up out of the hole to clear the chips. Also the type of bit used is a factor in drilling efficiency: wood boring bits are a good choice. Forstner bits are excellent, and spade bits are just OK. Hope this helps....
Posted on Mar 30, 2014
2 Suggested Answers
  • 597 Answers
SOURCE: HAve clausing 1650. Large Drill bits overheat and
You should use a honing type of oil when drilling with large bits. There is a tremendous amount of friction and the oil keeps the bits cooler when cutting.
Posted on Nov 15, 2009
Which drill bit should I prefer to drill a log of wood?
You can use a spade bit, hole saw or forstner bit in order to drill into a piece of log. I was also looking for the best drill bit to be drilled on a piece of wood, then one of my friends recommended me to check Best Forstner Bits to get an idea about making the choice of an appropriate drill bit. You can also do the same, if you are confused of making the right choice!
Apr 16, 2018 | Drills
Want to install on wood beam, what size drill bit needed for included wood screws
Look at the wood screw threads and hold a drill bit against it. Choose a drill bit that is smaller in diameter than the threads on the screw. Works for any size wood screw.
Mar 11, 2016 | Drills
I am trying to drill through old encyclopedias, but the drill bits keep snapping in the pages. What type of drill bit can I put on an hand-held drill that will get through the books without breaking?
rx-dk-diy054036_wood-drill-bits_s4x3_lg.jpgI've used 'regular' high speed drill bits for paper, and wood boring bits. I think the wood bits work better, but whatever bit is used the drill flutes have to be cleared out of material. This is done by drilling a little bit at a time and then lifting the drill out of the hole to clear the hole and the drill of shavings. This is essential to do to minimize heat buildup and binding of the drill bit. The drill bit should not break if you take it nice and easy, and drill in small increments .
Dec 17, 2013 | Hinge European Drilling Tool 35mm Cup ...
How do i use a spade bit?
I'm assuming you mean a spade drill bit?
For best results, try clamping a block of hardwood to the back side of the stock before drilling. When the bit approaches the end of the cut, it will be far less likely to blow through with another piece of wood to drill. However, if the stock placed on the back side is softer than the workpiece, or if it is not securely clamped to the workpiece, tear out can still occur.
To use a spade drill bit, mark the center point of the hole to be drilled on the wood, and install the shank of the bit into the drill. Align the point of the pilot tip of the spade drill bit with the mark on the wood, and adjust the angle of the handheld drill so that the shank of the bit is square to the surface of the wood. (Of course, if you're using a drill press, the bit's angle should already be square to the surface of the wood, unless your drill table is not square to the motor).
Depress the trigger of your drill slightly to engage the motor and turn the bit slowly. Hold the drill as still as possible so that the pilot point stays aligned with the mark on the wood. Because pilot tips can often "walk" away from the intended center point of the hole, some woodworkers will pre-drill the pilot hole using a small-diameter twist drill bit that is less likely to walk, and then proceed with the spade drill bit's pilot tip into the pre-drilled pilot hole.
Once the pilot tip is in place and engaged with the wood, increase the speed and proceed to drill the large diameter hole with the spade drill bit. Continue drilling until you reach the opposite side of the wood and the bit pokes out through the completed hole. Slow the speed of the motor, and pull the drill bit out of the completed hole.
For more details, check out my source: (link)
Mar 23, 2013 | YouTube Videos
Drilling wood on a craftsman 10" drill press
There are several possibilities. I am assuming that by "hang up" you mean that the motor still runs, but the arbor, chuck, and bit all stall. I also assume that you are running the bit up and down to clear out the wood shavings from the bit out of the hole, you are using the correct amount of downward force, and that the bit is sharp. I would first check to see that there is proper tension on the drive belt. You can add a belt spray designed to increase friction for better running. I would also gear down the drill press even more to increase torque (I know you say you are running at the correct speed, but try a reduced speed). Another method is to use an auger bit or a forstner bit without pilot holes. If you are using a spade bit, you might try no pilot hole, and drill at a faster speed. I have a junk 10" drill press and have no trouble drilling 1" holes in oak.
Sep 14, 2017 | Craftsman Drills
I want to remove a wood floor from a semi trailer so i can salvage the metal. the floor is 2x8 oak with rusty nail heads. the trailer is 53 ft long
generally they CUT the floor with a worm drive saw but this wood is extremely HARD and will burn up a saw blade and a saw, you might try drilling the screw heads off to remove the wood
Jan 06, 2012 | Tools & Hardware - Others
What speed would i need to set my cordless drill at to put hole in wall
Your drill will drill a hole at any speed, the drill bit needs to be sharp to drill the mateirial.The type of wall material is important.Drywall is soft but a masonry bit should be used.A masonry bit has a flat bar accross the point and slower speeds are best.Wood walls / studs you need wood bits that are sharper and medium to high speeds are used.Concrete or Block walls again require Masonry bits.If very hard concrete as in foundation walls or filled block the use of a Hammer drill will work much faster.Good Luck
Jul 29, 2011 | Drills
When running a 3" screw
You need to drill a pilot hole in order to allow the screw to sink into hard woods. This is done by taking a drill bit slightly smaller the width size of the screw and drilling into the wood in the location of the place you would like the screw to go. Then sink your screw into this hole. You should be able to sink your screw with no problems.
May 16, 2011 | Drills
I am using a powerbase xtreme cordless drill diver kit and cannot fit the wood drill bits onto the drill. I have tryed fiddling with the settings and such but cannot find a way. Please help
Refer to the picture shown in the link below--- http://mydeco.com/p/powerbase-xtreme-cordless-hammer-drill-kit-18v/GB000024EPS6TLCLTKLEGSM4VU6S7ICXK7PGDYPU/
The very left-hand end of the drill is the drill chuck. There are three "jaws" protruding from the left-most end. To open the jaws grasp the large black collar with one hand and the the smaller silver collar just behind it with the other hand. Twist these two collars in opposite directions. You have to twist pretty hard. If they won't move, then try the other direction. Once they start to move they will move easily and you will see that the the three jaws begin to separate. Keep going until the jaws have separated enough to insert the wood drill bit, insert the bit, then tighten - good and tight! Good luck.
Aug 17, 2010 | Garden
I have a dewalt 18v cordless hammer drill but for some reason while drilling the drill does not spin as fast as it used to batteries are fine just the drill any ideas
depends on where you drilling- wood - no hammer option needed- fast, metal- no hammer option needed- also fast, but it is concrete- sorry- hammer option needed so it will always drill slower, and drain your batteries way faster (have a spare one ready).Speaking about drilling - don't drill for too long with no breaks to cool them down, always keep an eye on gun's and battery's temperature- even if it is new Lithium NANO, do not let them overheat.
BTW- what model is yours? Is It SDS hammer drill sort of DC212KL?
May 19, 2010 | Dewalt 18 Volt Compact Drill Kit
Drills Logo
112 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
