Question about Canon PowerShot G10 Digital Camera
Problems with the images, get stripes and also in daylight shooting the images are too light nearly white. Can't understand.. It just happened without a reason.
  • 136 Answers
It's lens problem, get it to the service center.
Posted on Oct 16, 2013
HI, I set my camera for Tungston bulbs which I use to shoot art. The images come out very brown. I can fix them in Photoshop but why is this happening?
try taking the shots with the camera set to daylight and or on auto colour balance.
daylight is 5600. k or if you like rather blue tungsten light is normally 3200 k. k stands for kelvin as in colour temperature. many digital cameras will sort out the colour for you but make sure that you are not using a mixture of light as this will confuse the colour saturation and give you all sorts of colour problems. what are you trying to photograph anyway. the back ground area must be lit for detail or you will get a blue noisy mess that tends to mess up the over all exposure. you need defused light for the best easy results. tell me more so i can understand your problem better
Apr 09, 2011 | Canon Rebel XT / EOS 350D Digital Camera
How do you disconnect the daylight, lights?
This is hard to explain without pics, but I will give it a shot: Just under the the steering wheel is the DRL (daytime running lamps) with a big white connector inserted into the backside of it. This connector has many wires. You need to locate the black/yellow wire. Cut the wire, and insert a swtich in between the two cut ends to enable/disable the DRL. This link has a great how-to instruction
Procedure:
Cut the Pin 12 Black/Yellow Stripe wire to disable the DRL "circuit"
operation. A switch can be installed inline between the two separate Black/Yellow Stripe wires for manual DRL operation if desired.
I just did mine over Christmas and it works with no problems.
Mar 16, 2010 | 2001 Toyota 4Runner
Canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear..
canon powershot A470 problem when i click photo then white image come? but when i use it night it is normal. but during daylight or with sunlight.. white image appear....and every time i take a picture there's a horizontal line appears in the picture..
Dec 21, 2009 | Canon PowerShot A470 Digital Camera
Light or white picture when shot on a broad daylight or on a well-lighted area
Are you in any other mode besides automatic when this happens. If you're not sure, check that the rotator dial is set to the first little red camera right next to the blue arrow (this is the automatic position). If you're in this position then it's unlikely that overexposure will occur unless you're also encountering mechanical failure of a stuck shutter.
May 27, 2009 | Canon PowerShot A460 Digital Camera
Displays green color image/screen
When did you get this message? It seems like you have set the White Balance of the camera wrong. Set it to Auto White Balance to eliminate this problem. Use Daylight White Balance when shooting in bright daylight so as to eliminate any color cast in the image.
Feb 04, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Wude light "band" or stripe at the top of each image
yoav_etiel,
Try to reset the camera first, second don't operate the camera (on) without the lens attached, the shutter can get damaged. If you purchaed this camrea recently (new) it can be serviced, within a year it can be sent to Nikon for evaluation. If it is used or past the maufacturers warranty find a reputable shop to look at it.
randy320sgi
Jan 07, 2009 | Nikon D300 Body Only Digital Camera
Flash blows out the image!!!
hi ,
it could be possible that the light sensor (the device under the red transparent plastic) in front of the flash is already failing. to test,set the camera mode to auto then cover the sensor with your hand and do some test shots, the images should be overexposed if the sensor is covered, then shoot some photos without covering the sensor, the images should be properly exposed , otherwise it might already be a light sensor failure .
Sep 30, 2008 | Nikon Speedlight SB-800 TTL Flash
OVer exposure
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
CASIO Exilim EX-z77 曝光過度 plz use google translate
www.mydc.com.tw
Jul 07, 2008 | Casio Exilim EX-S600 Digital Camera
Lumix TZ3 zebra stripes in daylight pictures
hello sodaclub, this fault is normally caused from to much light entering through the lens, the shutter is not closing or working at all.
Jun 24, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera overexposes on daylight and recorded images have hoizontal striping
I would take it off of automatic mode and adjust it manually.
The Samsung camera I have doesn't work very well in automatic mode under indoor conditions. It will work in automatic under outdoor conditions.
Hope that helps.
Mar 24, 2008 | Samsung Digimax L60 Digital Camera
Canon PowerShot G10 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
