Filter cap stuck onb my hotpoint bwd129 and now grip is broken from trying to unprise it. Any ideas how to get it open ? Wanted to get filter open as machine not spinning properly and smelling awful.
I had same problem, broke the grip on the filter cap. This is how I was able to get around the problem. Gently tapped in a screw sideways into the opening, the screw was slightly bigger than the opening. Then with a pliers I was able to grip and turn, the screw fell out a few times but got there in the end, ordered new filter cap. Job done! Filter cap stuck onb my hotpoint bwd129 and now - 44c18079-c40a-4483-9213-a549616208cf.png
Posted on Feb 03, 2014
    Master:
  • 492 Answers
Well this a job for a technician not a home fix sorry.....
Posted on Oct 15, 2013
4 Suggested Answers
bluegreenash
  • 661 Answers
SOURCE: Inside of Washer Smells
often in washing machines there is a drain trap which needs cleaning out from time to time, (usually accessible from the front behind a removable facia) The manual should tell you how to clean this. you need to drain the water first (as there is often a little water still in the system). if you look on the program dial there is often an item that has an arrow pointing down, this should be the drain program, after this is done you can remove the draining cover and clean the workings inside, hopefullt this will solve your problem :)
Posted on Sep 27, 2007
  • 3 Answers
SOURCE: if filter cap is broken how do i open it on my bosch washing mach
I had the same problem. If it's stuck you may want a tool. I ended up using a pair of pliers on this plug. You may want to use a pair of vice-grip locking pliers and put a piece of thick metal on each side so you don't break the plug any worse (about 1/2" X 2" plate). MAKE SURE YOU TURN COUNTER CLOCKWISE! Wiggle it back and forth as you may have a wire or hairpin half in and half out of the pump filter area. It takes 2 full turns to get past the threads in order for the plug to come out. I had an underwire from a bra that gave me the worst problem. I worked on it for almost an hour. I have found change, jewelry, hairpins, BBs, small rocks, and a 4" long underwire from a bra. Please rate my solution if this gives you enough details to complete your task. THANKS!!
Posted on Apr 16, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint bwd129 how can i open the filter at
If you have located the fliter, then grasp the filter cover, and twist and turn to the left to remove the filter
Please rate my solution.
Thanks.
Posted on Jul 21, 2009
Hi, filter grip on my hotpoint bwd129 has snapped off trying to open it. Any ideas how I can now get it off? The machine was not spinning properly & started to smell awful. Thanks
You where headed in the right direction-something is stuck and is burning up the belt-check appaliance pro on line for filter lid-then drill it and drive a striaght blade screw driver into it cheers Denny
Oct 15, 2013 | Hotpoint Ultima WF860 Front Load Washer
Bwd129 not draining
if your dishwasher is stopping on the drain cycle and not draining it could be a problem with the timer not kicking in to drain mode. or if it completes the entire cycle and not draining it is your pump thats bad. hope this helps.
Feb 22, 2013 | Hotpoint Bwd12, Bwd129, Bwm129 Washing...
Hotpoint washer wt640 front filter cover stuck
We had to use brute force, pliers and lots of wiggling back and fore. When we eventually got it out, about a pounds worth of small change and lots of gunk blocking the way.
Spin now working, f05 gone. Very happy as hotpoint wanted 95 pounds for a call out.
Good luck all.
Jul 29, 2012 | Hotpoint Washing Machines
Fuel filter cap was stuck and I cracked it trying to get it off
Try gripping onto it with Vice Grips and turning it.
Apr 30, 2012 | 2006 Ford F-250 Super Duty
How do i open the filter as we have tried and it wont come out on our whirlpool AWM1203
I assume your talking about the drain filter. If you are you would open the small access panel located down the bottom of the unit and turn the filter to the left in counter clockwise direction. It is best to have a small pan and a shop vac in place to vacuum up the water that will come out of this area. Note sometimes when the filter is stuck you can use a screwdriver across the two tabs to turn the filter. If you have any further questions message me back. Thanks again Rick
Jul 02, 2011 | Whirlpool AWM5125/1 Front Load Washer
We have a washer dryer hotpoint bwd129. Can you
a washer dryer has a different approach to cleaning fluff. It has an internal flushing system.. only do routine check on pump filter.
Oct 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint bwd129 how can i open the filter at
Thanks.
Jul 21, 2009 | Washing Machines
Remove filter handle
Purchase a new fiter first, and then grip the broken part with a pair of grips or pliers, and remove filter, turning anti clockwise at the same time.
Thanks.
May 06, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
145 people viewed this question
Top Washing Machines Experts
