Question about AMD 2.4GHz CPU, Opteron 280 E6 Stepping (95Watt) (p/n X8044A)
Insufficient heatsink/fan for Opteron280 processor
I have a server system with a TYAN S2885ANRF(04MOAb ver) Motherboard that according to AMD has a insufficient heatsink/fan combination,of which the core cpu temp is too high (68C). AMD advised me to search for a better heatsink/fan combination for 2# AMD Opteron280 processors.
  • 385 Answers
Try here for them. or if in USA
Go to Ebay/usa
http://shop.ebay.co.uk/items/_W0QQ_nkwZheatsinksQ20andQ20fansQQ_armrsZ1QQ_fromZR40QQ_mdoZ
Regards
Richard.
Posted on Apr 24, 2009
Which fan/heatsinks can be used on an MS-7174 Ver 1 motherboard? It seems there needs to be clearance for some capacitors to fit beneath it.
Heatsinks are dependent on the type of processor that you have, I recommend that you call Microcenter or fry electronic
Apr 22, 2015 | MSI Computers & Internet
Need scsi/raid drivers on floppy to install winxp pro (at f6 prompt)
Hello the drivers can be downloaded here:
http://www.tyan.com/support_download_drivers.aspx?model=S.S2865
You need to unzip the file before you install the driver.
It should not be nessesary to install drivers before installing the windows system.
Check your bios boot settings to boot from the cdrom or dvd drive.
The cd or dvd drive must be the first boot device in order to boot from the windows disk.
Install windows with only one harddrive.
You can also add a harddrive later, when the installation is done and all drivers is installed.
Good luck
Jun 20, 2013 | Tyan Tomcat K8E Motherboard
Power shut down shortly after bios loads
Check the processor and heatsink/fan. If there is a bad contact between the heatsink and the processor, or the fan fails to turn the BIOS will shut the system down to protect the CPU from overheating. I hope this helps.
Mar 02, 2012 | ASUS M2N68-AM PLUS Motherboard w/ AMD...
Need a heatsink that will fit MSI 870-G45 Motherboard (Model # MS-7599). CPU is AMD Phenom II X4.
You can find heatsinks at the following link, you will need one that is compatible with
AM3 AMD 770 ATX AMD motherboards
If you look through each product, it will show you compatibility or you can filter search results.
http://www.newegg.com/Store/SubCategory.aspx?SubCategory=574&name=CPU-Fans-Heatsinks
Regards,
G33k
May 05, 2011 | AMD Computers & Internet
HEAT SINK FAN NOT WORKING
1.Replace the new fan.
(or)
you can cut the processor fan ,then put any small size 12V exahsting fan in that place.and stick it with the help of glue.you can put the power supplies as mentioned below:
Yellow color wire = 12V
Black color wire = Ground.
Thank u sir.... All the Best...
Apr 22, 2010 | AMD OPTERON 240 (SERVER) 1.4GHz CPU RETAIL...
Amd athlon heatsink
If you don't install the heat sink and fan carefully you could blow out your processor. Make sure you clean all the old heat sink paste from the processor and the heat sink. Then apply a thin layer of paste like "arctic silver" on the heat sink so that it makes full contact with the processor. I think you have a socket A processor...so do a google search for "installing a socket A processor" and you should have all the info you need. Good Luck...Hank
Jan 12, 2010 | EPoX EP-8KRA2+ Motherboard
CPU over emperature
It sounds like you have a couple of potential problems. First it could be the fan is not working due to failure or not being plugged in properly. Second is that you need to put Thermal Paste between the processor and the heatsink. If you have not done this before, I suggest seeking out a friend that has to help out. There is many kinds of thermal paste and not one is universal. Find out the one that the CPU manufacturer recommends.
May 30, 2009 | AMD Athlon 64 x2 3800 3800+, 2 GHz...
My computer shutdown after 1 or 2 hours
unplug & remove cover and clean dust,dirt out with compressed air plug back in and try. check all cooling fans and make sure they are running if not check connections or replace with new one
Dec 18, 2008 | Biostar MCP6P-M2 Motherboard - v6.0,...
Trobleshooting
I had the same issue with my AMD Athlon 3800+ dual core. I found that I wasn't getting enough airflow to keep the system and processor cool. You may want to check the heatsink and fan rating for your processor unless it was sold in a bundle. Also, On AMD's of such power, they tend to run hot if overclocked. Look into, if you haven't already 2 case fans to go along with the processor fans. I recommend a 90mm in front and a 80mm in the rear of the case. If this doesn't help, let me know.
Mar 16, 2008 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
Computers & Internet Logo
67 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
