Question about Hotpoint Ultima WF860 Front Load Washer
Hi, filter grip on my hotpoint bwd129 has snapped off trying to open it. Any ideas how I can now get it off? The machine was not spinning properly & started to smell awful. Thanks
    Master:
  • 818 Answers
You where headed in the right direction-something is stuck and is burning up the belt-check appaliance pro on line for filter lid-then drill it and drive a striaght blade screw driver into it cheers Denny
Posted on Oct 16, 2013
  • 1294 Answers
SOURCE: "Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Posted on Dec 02, 2007
  • 14 Answers
SOURCE: Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Posted on Dec 30, 2007
  • 1314 Answers
SOURCE: Hotpoint bwd129
o k find the acess panel in the front or back then follow this procudure most likely there is something jamming the pump look on the back and you might see an access panel remove it and you will see a large hose coming down from the tub.Now the washer will still be full of water.There are three ways to deal with this the best way is to get a shop vac.remove the drain hose from the stand pipe and vac the water out,the second is to get a pair of radiator hose clamps from the auto parts store and clamp the large hose as close to the tub as possible ,the third is you can get a bucket remove the drain hose from the stand pipe and getting as close to the floor as possible let the water drain in the bucket .after that put some towels around the pump.Remove the clamp and slide the large Rubber boot off the pump look in the pump for foreign objects jamming the impeller blades and for broken blades if broken replace the pump.feel in the boot for same as pump .Then reassemble if nothing found then go check drain hose.
Posted on Jan 17, 2008
SOURCE: hotpoint ultima wt960 washing machine noisy on spin
My WT960 was also very noisey on the spin cycle, but it had been like this since new, but became increasingly loud, to the point it sounded like it was going to explode. Boyfriend took machine apart to find the concrete weight had also loosened, bolts tightened, though awkward to get to. Now the machine spins ALOT silently than before!
Posted on Aug 10, 2008
SOURCE: There is a series of
hi there,
i had similar problem . there is a blockage in the fllter , probably a small sock. the filter is at bottom right hand at front of machine .
turn anticlockwise to open.
regards
big eck
Posted on Jan 31, 2009
Hotpoint BWD129 Spinning Difficulties
IF it sits and you can turn it later, the only thing that would cause that is something heating up and becoming seized. When it cools off it frees itself. I would check the bearings on the drum.
Mar 12, 2014 | Washing Machines
Filter cap stuck onb my hotpoint bwd129 and now grip is broken from trying to unprise it. Any ideas how to get it open ? Wanted to get filter open as machine not spinning properly and smelling awful.
I had same problem, broke the grip on the filter cap. This is how I was able to get around the problem. Gently tapped in a screw sideways into the opening, the screw was slightly bigger than the opening. Then with a pliers I was able to grip and turn, the screw fell out a few times but got there in the end, ordered new filter cap. Job done! 44c18079-c40a-4483-9213-a549616208cf.png
Oct 15, 2013 | Washing Machines
I have a Hotpoint BWd129 washer/dryer. When I
I have a similar Hotpoint model to this, that does something very similar now and again, usually when trying to set a delayed start.
The only way I have found to "fix" it is to turn the machine off for at least 5 minutes, and then try again.
Hope this helps.
Jan 13, 2010 | Zanussi WJD1257W Front Load Washer
We have a washer dryer hotpoint bwd129. Can you
a washer dryer has a different approach to cleaning fluff. It has an internal flushing system.. only do routine check on pump filter.
Oct 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint bwd129 how can i open the filter at
If you have located the fliter, then grasp the filter cover, and twist and turn to the left to remove the filter
Please rate my solution.
Thanks.
Jul 21, 2009 | Washing Machines
HOTPOINT BWD129
Please provide more details about your appliance. What brand and the age.
Nov 06, 2008 | Hotpoint WD52 Front Load Washer / Dryer
BWD129
hi steve.
this is all i could find.
see if this manual helps you out.this is a check list one.
http://laundry.manualsonline.com/manuals/mfg/hotpoint/bwd_129.html?p=17 .
or this link has more manuals.
hotpoint bwd129 manual Google Search
Dec 17, 2017 | Washing Machines
There is a series of lights flashing on my Hotpoint BWD129 washer/drier. The lights flashing are the 'door locked' light as well as the 'super wash' and '1200/600' lights. This coincides with the machine...
hi there,
regards
big eck
Aug 04, 2008 | Hotpoint Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
85 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
