Question about Ariens Garden
Not sure how the drive belt and pules go on? the one pulley came off. need the configuration of the belt?
    Master:
  • 492 Answers
Check YouTube for a video
Posted on Oct 18, 2013
2 Suggested Answers
  • 376 Answers
SOURCE: need to find illustration of mower deck drive belt
Posted on Jun 01, 2009
What is the fanbelt layout for a td27 terrano
Looking from radiator - Inside belt goes over fan, strait down, and up to top right hand gen.
Middle belt goes over fan straight down, then up to left pulley.
Front belt goes around bottom pulely (one with other two belts on) over to bottom right gen, up to spare pulley on right.
I hope this helps you
Allan
Mar 27, 2015 | Nissan Terrano Cars & Trucks
Knocking noise when printing
Check the following:
1. DC motor assembly.
Make sure all the motor plate mounting screws are tight.
2. Idler pulley - DC motor assembly.
Make sure the idler pulley is not binding on the pulley shaft. Check the pulley for wear. Check the idler pulley shaft on the motor mounting plate for damage or contamination.
3. Drive pulley.
Check the drive pulley for wear, binds or damage to the pulley or pulley shaft. Make sure the pulley turns freely on the pulley shaft.
4. Motor drive belt - tray drive belt.
Check the DC motor drive belt for damage. Make sure the belt is tracking correctly on the drive pulley, idler pulley, and motor pulley. Check the tray drive belt for damage. Make sure the belt is tracking correctly on
Dec 11, 2012 | Lexmark X646e Laser Printer
Serpentine belt configuration
Accessory Drive
Component Locations 3.0L (2V)
3dde941.jpg Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 19D784 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6A312 Crankshaft pulley 8 8A528 Water pump pulley
Component Locations 3.0L (4V)
Item Part Number Description 1 3A733 Power steering pump pulley 2 8620 Drive belt 3 19D784 A/C clutch pulley 4 6A312 Crankshaft pulley 5 6B209 Drive belt tensioner pulley 6 10344 Generator pulley
I posted the serp belt configuration for both engines. thanks
Sep 24, 2010 | 2003 Ford Taurus
How do you change a belt pulley?
If it is a idle pulley,just remove the center bolt,and it will come off.
Jul 25, 2010 | 2000 Pontiac Montana
Lookng for serpentine belt routing diagram for 1998 2.4 L sunfire
1998 Pontiac Sunfire Belt Routing Diagram
A drive belt routing diagram is needed when replacing a drive belt to help simplify the installation process. The problem arises as there are many different ways a drive belt can be configured. In this configuration the belt length will vary not allowing the belt to be installed. Also alternative configurations could turn a particular accessory the wrong direction, creating more problems. Always reinstall the drive belt in the exact configuration as the previous belt to prevent these problems. Always use high quality replacement products to avoid premature drive belt failure. If a multi rib drive belt fails it must be replaced immediately to avoid such situations such as engine overheating and loss of the power steering system. Whenever a belt replacement is required inspect the pulley condition to ensure there are no sharp edges on any of the pulleys, this will cause the belt to shred and fail. Confirm that all pulleys are free from debris such as small pebbles, these pebbles will cause the belt to pit and significantly impair the belt performance. The belt tensioner plays an important role to the drive belt performance, if this tensioner is weak it can allow the belt to lose tension allowing the belt to jump and skip. This condition will result in noises such as squeaking, chirping and ticking.
Hope helps (remember rated this help).
Jul 11, 2010 | 1998 Pontiac Sunfire
Belt diagram
Hope helps (remember rated this).
Jul 11, 2010 | 2004 Chevrolet Cavalier
I need the drive belt configuration for a 1988 Jeep Cherokee.
To replace belt, first loosen the pivot and slide bolt on the steering pump, then use the jack bolt below the pump to move it. Belt goes (ccw) around outside of ps pump, under idler pulley, over a/c compressorover alternator over fan pulley, over crank pulley over water pump and back to the ps pump. best bottom (grooved area) should match with any pulley with grooves, back of belt should contact smooth pulleys. 9example...grooved part contacts ps pulley, smooth back goes under idler pulley) When finished the water pump should spin ccw (I've seen them put on incorrectly so it turns backwards) Tighten jack bolt till the long strech of belt is giving about 1" deflection, then lock pivot and slide bolts down.
Nov 28, 2009 | 1988 Jeep Cherokee
I can't find the Auto-tensioner on my 99 accord. Does it have one? If not, how do i get the belts off?
I think this is right, but…
Find someone to help you if you can. To help hold the new belt in place when you are putting it on.
Make a diagram of the way the belt fits over and around the pulleys on your car. Don’t thing that you are going to remember where it goes.
Locate the drive belt auto-tensioner on the upper part of the engine (see pic). The tensioner is an idler pulley, since it does not drive any accessory on your vehicle. Its only function is to give the belt its proper tension.
Insert a long boxed-end wrench on the auto-tensioner pulley bolt of the appropriate size (probably 14mm) and slowly turn the idler pulley to release the tension on the drive belt (you are not removing the bolt; you are turning the tensioner so you can get the belt off while you have it turned under pressure). If you have a 2.4L engine model (2.3 Vtec should be similar), turn the pulley clockwise; if you have a 3.0L engine model, turn the pulley counterclockwise. Slide the belt off any pulley located on the upper part of the engine while you have the tensioner under pressure; then slowly release the tensioner pulley and remove the belt from the engine.
Check every pulley run by the drive belt and make sure they are free of dirt, debris and built-up material.
Compare the old belt to the new one and make sure it is of the same width and configuration.
Install the new belt beginning with the crankshaft pulley at the bottom and center of the engine and work your way up to the last pulley; follow your notes or the routing diagram on the engine compartment. If necessary, ask your helper to hold the belt stretched next to the last pulley on the upper part of the engine. Using the boxed-end wrench, slowly rotate the auto-tensioner pulley in the same direction you turned it to release the belt. Then slide the belt over the last pulley, and slowly release the auto-tensioner.
Make sure the belt is properly seated between the flanges of every accessory pulley.
Oct 30, 2009 | 1998 Honda Accord
Timing Belt Broken, need Diagram for setting Engine Timing timing belt lower puling
I purchased the timing belt and pulley kit for a 1999 zr2 complete instructions came with the pulley set (Dayco brand) also bought the Haynes manual for the escort and not very good directions in it. The one that came from Dayco were very good.
Jul 10, 2009 | 1999 Ford Escort
Cant find 97 ford taurus serpentine belt diagram
Drive Belt Replacement ani_caut.gif WARNING: IF EQUIPPED, DO NOT ALLOW DRIVE BELT TENSIONER (6B209) TO SNAP BACK AS DAMAGE TO DRIVE BELT TENSIONER OR PERSONAL INJURY COULD RESULT.
NOTE: Minor cracks in the V-grooved portion of the serpentine drive belt (8620) are considered normal and acceptable. If the drive belt has chunks missing from the ribs, the drive belt should be replaced.
NOTE: Conditions requiring drive belt replacement are excessive wear, rib chunk-out, severe glazing, frayed cords or other conditions. Replace any drive belt exhibiting any of these conditions.
NOTE: When installing drive belt on pulley, make sure that all V-grooves make proper contact with pulleys.
Drive Belt, Serpentine—Except SHO
Removal
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE THAT TOOL DOES NOT SLIP FROM DRIVE BELT TENSIONER OR PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 15 mm socket or wrench on bolt attaching drive belt tensioner pulley, rotate drive belt tensioner clockwise on 3.0L (2V) and 3.0L (2V) FF, rotate the drive belt tensioner counter clockwise on 3.0L (4V) to remove drive belt from pulleys. Make sure spring keeper engages into slot.
    Drive Belt Tensioner—3.0L (4V)
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner).
  1. Rotate drive belt tensioner as described under the removal procedure and install drive belt over drive belt tensioner pulley. Make sure that all V-grooves make proper contact with pulleys. Make sure spring keeper releases or improper belt tension will occur.
    Pulley, Routing—Accessory Drive Belt 3.0L (2V)/3.0L (2V) FF Engine
    Item Part Number Description 1 10300 Generator 2 6C348 Idler Pulley 3 3A674 Power Steering Pump 4 19703 A/C Compressor 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 8501 Water Pump 8 8620 Drive Belt
    Pulley, Routing—Accessory Drive Belt 3.0L (4V)
    Item Part Number Description 1 3A674 Power Steering Pump 2 8501 Water Pump 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10300 Generator
3.4L SHO Engine
Removal
  1. Remove the right front wheel and tire assembly. For additional information, refer to Section 04-04.
  1. Remove the inner fender splash shield.
  1. Remove the alternator shield.
  1. ani_caut.gif WARNING: USE CAUTION WHEN REMOVING OR INSTALLING DRIVE BELT TO MAKE SURE WRENCH DOES NOT SLIP FROMDRIVE BELT TENSIONER OR POSSIBLE PERSONAL INJURY AND/OR DAMAGE TO DRIVE BELT TENSIONER AND DRIVE BELT MAY OCCUR.
    Using a 3/8 inch ratchet on the lifting lug, rotate drive belt tensioner counterclockwise (upward) and engage spring keeper. Remove drive belt from drive belt tensioner.
  1. Lower vehicle.
  1. Remove drive belt.
Installation
  1. Install drive belt over all pulleys (except drive belt tensioner ).
  1. Raise vehicle on hoist.
  1. Rotate drive belt tensioner , as described under Removal procedure and install drive belt over drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys. Make sure the spring keeper is released or improper belt tension will occur.
  1. Install the alternator shield.
  1. Install the inner fender splash shield.
  1. Install the wheel and tire assembly. For additional information, refer to Section 04-04.
    Pulley Routing—Accessory Drive Belt, 3.4L SHO
    Item Part Number Description 1 3A733 Power Steering Pump Pulley 2 6B217 (RH) Idler Pulley 3 19703 A/C Compressor 4 8620 Drive Belt 5 6312 Crankshaft Pulley 6 6B209 Drive Belt Tensioner 7 10346 Generator 8 6B217 (LH) Idler Pulley 9 6B217 (Center) Idler Pulley
Drive Belt, Water Pump
Removal
  1. NOTE: If removal of the water pump drive pulley is required, refer to Section 03-03.
    Rotate drive belt tensioner clockwise by hand and remove drive belt from drive belt tensioner .
  1. Remove drive belt from water pump drive pulley and water pump pulley.
Installation
  1. Position drive belt onto water pump drive pulley and water pump pulley.
  1. Rotate drive belt tensioner clockwise by hand and install drive belt over top of drive belt tensioner pulley. Make sure all V-grooves make proper contact with pulleys.
    Pulley Routing—Water Pump Drive Belt
    Item Part Number Description 1 6B209 Drive Belt Tensioner 2 6A312 Crankshaft Pulley 3 8501 Water Pump 4 8620 Drive Belt
Jun 01, 2009 | 1997 Ford Taurus
Garden Logo
24 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
