Question about Sharp MX-2300N Color Copier
Where is the fuser unit located in Sharp MX-2300n
    Habit-Forming:
  • Sharp Expert
  • 190 Answers
Right side pull cover first and its o top and its hot
Posted on Jun 27, 2014
SOURCE: error code h5-01
Yes H5-01 is when it jams in the fuser 5 times in a row, check the fuser section for a jam, the paper jams up in there and does't trigger any sensors, once you have confirmed that its clear reset with sim code 14
Posted on Jun 01, 2008
  • 3 Answers
SOURCE: Sharp MX-2300N Maintenance required.code:TA
Maintenance TA is indicating the machine has reached its 100K scheduled service interval. It requires Transfer Belt Unit, Usually Black Drum & Developer, any feed rollers wornout replaced, any old firmware updated to latest version, and a general clean & check. It is reset in service mode once these parts are replaced.
Posted on Dec 26, 2008
007tech
  • 95 Answers
SOURCE: sharp mx-2300N printer error maintenance required
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Posted on Jan 15, 2010
  • 14 Answers
SOURCE: Sharp MX-2300N with error code H3-00. . how do I
Ensure you are in COPY mode
press # * C * ( one after the other, fairly quickly)
when the screen changes enter the number 14 on the keypad
press the B&W start button
press 1 for Yes when the question displays
press thw CA button
machine will re-boot and fault should clear. If it doesnt you need a service engineer. This is a fuser temperature fault
Posted on Mar 09, 2010
  • 22 Answers
SOURCE: Sharp MX 2300N - Toner
REPLACING THE WASTE TONER BOX
The waste toner box collects residual toner that is produced during printing. When the used toner box is full, the display
will show "Replace used toner container". Follow the procedure below to replace the used toner box.
Open the front cover.2
Release the used waste toner box.
The waste toner box will fall forward as shown.
Gently support the box with your hands as you let it fall forward
as far as it will go.
fmtx.png Remove the waste toner box.
Hold the box by both hands and lift it up slowly.
If the waste toner box falls too far forward, it will not be possible
to remove it. (Remove the box when it is at an angle of about
30 degrees.)
Install the new waste toner box.
Insert the box from above at a slant. (The direction opposite to
when you removed it.)
Push the waste toner box into the
machine.
Push the box in until it clicks into place.
Close the front cover
Hope this helps.
Posted on Feb 07, 2011
Testimonial: "Many thanks for your fast and accurate advice and solution. We have now ordered this unit and will install as you suggest."
What is sub code of fk1
FK1 refers to the maintenance life counter for the fuser unit.
The fuser rollers have a fixed life count & when that count is reached FK1 is displayed. If the rollers are worn they should be replaced but if they are ok you can reset the fuser maintenance counter in SIM 24-4 FUSER UNIT
Aug 08, 2014 | Sharp MX-2300N Color Copier
Sharp MX-2300N Maintenance Required: Code VC
Time for some scheduled maintenance! Call a local sharp dealer.
google sharp service locator, enter your model and your zip code to find a dealer near you.
Copier Collin Houston TX Copier and Imaging Expert
Jul 11, 2014 | Sharp MX-2300N Color Copier
How to install fuser in mx 2300n
3 blue screws and unlock the 2 grey lever and pull out
Feb 16, 2014 | Sharp MX-2300N Color Copier
Hi
Open door on right, should be to blue screws holding the fuser unit in, remove the screws, then pull out fuser using the grey handles at either end of the unit.
Cheers
Andy
SHARP MX 2300N Have cleaned the glass but still
Try cleaning the smaller part of the glass on the machine located to the left hand side of this machine!
Aug 25, 2011 | Sharp MX-2300N Color Copier
H5-01
There is a paper jam most probably in the fuser unit. This causes the heater lamps delay in heating the fuser roller at the required time.
Feb 21, 2011 | Sharp MX-2300N Color Copier
Code : H5-01
Check for paper jam in or by fuser unit. Remove paper. On the keypad press P * C * and SIM 14 to reset copier. If you get 5 jams at the fuser unit in a row it gives this code. If it keeps jaming double check for paper, my have a faulty sensor.
Aug 31, 2010 | Sharp MX-2300N Color Copier
MX-2300N Color Copier: I have a Sharp MX-2300N that has just suddenly sta...
yes open the front door remove the waste toner and you will see the 4 drum units each with a little green stick pointing out
pull this in and out a few times on each unit ...
hope this helps
May 18, 2010 | Sharp MX-2300N Color Copier
Sharp MX-2300N with error code H3-00. . how do I fix it?
press thw CA button
Mar 09, 2010 | Sharp MX-2300N Color Copier
Sharp MX-2300N Color Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
