Question about Toro Lawn Mower With Toro Power Tools
I've had problems with the Personal Pace for the past two summers. Mine is over five years old. I've replaced the blade driver (broken) and it worked fine for a bit, then it started grinding really loudly. I took it to the shop and mechanic replaced the pinion gears and greased the shaft. Grinding was still there. The PP pulled for about five minutes and stopped working. No more grinding noise, but no PP either. He claimed it needs a new transmission, but should last a year or two. I've had it with this mower. Any suggestions before I have to replace it? I live on a hill and can't use a push mower.
  • cabgrl Apr 24, 2009
    If I pull the transmission, whre do I start? I have schematics, but will I need to pull of the wheels and axle as well?
4 Suggested Answers
  • 81 Answers
SOURCE: Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Posted on Jun 19, 2009
kel1guy2002
  • 3740 Answers
SOURCE: mower will not start
Hi and welcome to FixYa. I am Kelly. Sounds like your in need of a serious carb cleaning session:
You engine parts manual is here: http://www.briggsandstratton.com/maint_repair/manual_and_more/docmanualdetails.aspx?showpdf=ms2143_B_LO.pdf
Now lets go through carb cleaning:
Before you start.... if you have a digital camera take "close up" PICTURES of the linkages and springs attaching to the carb. If this is your first time you will be so glad you did. You can always delete them later if you don't need them. :)
Here is what you need to do:
1. Fuel selector off
2. Remove float bowl mounting screws and nut
3. Localte the Air fuel Jet on the side of the carb and count the number of turns it takes to close the Jet adjustment until it is just snug.
4. Remove the Jet / Orifice in side of Carb (spring on screw stem)
5. Using a catch fuel container turn on the fuel selector. Fuel should flow at a good rate. GENTLY lift the float assy level and make sure fuel flow shuts off. When you drop the float again fuel should flow.
If you do not have fuel flow at this point the needle and seat will need to be inspected. Fuel selector OFF.
(The following procedure is to be done only if there is no fuel flow with fuel selector on.)
a. Remove the float pivot pin.
b. Drop the Float down (The needle will come off with the float. NOTE the position)
c. Inspect the tapered rubber of the needle valve It should be pointed. If it is not pointed then the rubber tip is stuck inside the seat.
d. Clean the seat hole ONLY if obstructed. (Easily damaged)
e. FUEL Selector on then off fuel should rapidly flow through the needle seat.
f. Renistall Float and needle making sure to get the pivot / hinge pin installed correctly
g. Fuel selector ON. Raise and lower float checking for free movement with fuel flow when lowered and stopped when the float is raised level.
6. If there still is no fuel flow at this point remove the fuel hose from the carb and check fuel flow. If no flow check that gas tank exit hole, fuel filter (if installed) and the selector valve assy for obstructions.
Reassemble connections.
FUEL FLOW IS GOOD
NOTE: If you have carb cleaner spray it into the side needle jet hole.
7. Install air fuel mixture needle jet in the side of the carb. Turn until closed and then back of the same number of turns it took to initially close it snug before removal.
8. BEFORE you install the float bowl inspect the bowl nut. There are holes in the side of the nut where it screws in to the bottom of the carb that must be clear. (could be no holes in yours)
9. Install Float bowl mounting screws and nut. Check for leaks.
10. Test engine.
That should do it.
NOTE: This engine was made with 2 different carbs. One had a choke the other had a primer bulb. If the primer bulb has a hole in it the engine will start then die after a few seconds.
Thanks for using FixYa.
Kelly
Posted on Apr 23, 2010
  • 4 Answers
SOURCE: Toro Personal Pace Mower won't start w/ electric starter
There are a couple of things you can check;
First, check to make sure the bendix is engaging. It is the gear that meshes with the fly wheel.
If it is, then try and see how fast the motor is spinning. Don't look at the blade though. It could be a faulty starter motor.
Make sure to also check the battery voltage with a volt meter. It should read at 12.0 or higher.
Posted on Mar 03, 2010
How do you take off blade holder on toro personal pace rear wheel drive
tHERS IS A BIG BOLT ON THE BOTTOM HOLDING IT ON, I JUST HAD MINE SHARPOENED AND AN OIL CHANGE FOR ONLY $35.00
Jul 29, 2016 | Toro Garden
I have a Toro mower made in 5/09 self propel system it grinds when you pull it in reverse. The selp propel is not working. The belt is on. and it seems to be only the left rear wheel? The cable is not...
Yes it is the transmission. A Mower shop will charge you about $225 to fix.. I order parts online and fixed mine for $90. Transmission consist of 3 gears which turns the rear wheels to self-propel.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 21, 2014 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro Personal Pace sounds like it is running at half power
got oil in it, or do you add oil. Left outside alot, fuel line clogged. Is the gas old. Check the blades and the exit portion of the clippings. Does it have a drive train for ease of moving. those can bog down a mower. good luck
Apr 30, 2013 | Toro Lawn Mower. 22 in. Personal Pace with...
Replace right rear hieght adjuster on a toro self pace mower
Remove wheel, remove screws mounting adjuster, straighten or replace.
Oct 02, 2012 | Toro 22 in. Personal Pace with Blade Stop...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
How do I replace the torsion spring in the handle of a Toro Personal Pace lawnmower?
Thanks so much Jamie. I had the top of the handle off but couldn't get any
further. I had to use a screwdriver on one side to get the brass bar out of the
plastic channel (I was afraid I would crack the plastic but didn't). I was able to remove the bar from the handle by myself with lots of effort ( BTW in your
solution did you mean your son pulled vertically up on the handle while you pushed vertically down on the bar?). I had one foot on one side of the handle and pulled up on the other side while pushing down on the bar. Isn't the web and Google amazing. The Toro sight didn't have a service manual. So I just typed "How to replace the torsion spring on a toro lawnmower" in Google an the question came up. I think Toro has a design issue with an overstress point on the spring. That part is on back order at the factory.
I did it.
May 01, 2012 | Toro Personal Pace CARB Walk Power Mower
Craftsman YT 3000 suddenly, without warning or unusual noise stopped going forward or backward
Sounds as if your drive belt has broken or slipped off pulleys.
Aug 06, 2017 | Garden
Is it possible to get an other dashboardcoverpanel,cause mine has a crack ( 1 cm wide) in the middle. i`ve got a ford ltd wagon,6,6 l engine and a blue intrior. also are mine left and right door armrest...
It may be possible, but difficult and expensive, to replace. Personally, I would get a dash mat instead.
You don't say what year this is. If it's less than five years old, the dealer should be able to order these. If it is 5-10 years old, maybe they are still available, maybe not.
Older than that, search the internet. Sometimes companies like Year One will have these.
Your other option is to go to an auto upholstery shop and ask them what they can do.
May 29, 2011 | Ford LTD Cars & Trucks
Toro model 20038 self propel problem
Try taking the back wheels off and lubricating the joint cogs and wheels with ,say, 3 in 1 oil . The dealer recommended doing this once every couple of years as preventative maintenance when I bought mine , and it has solved sticking problems for me .
Sep 12, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,201 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
