Question about Yamaha RX-V661 Receiver
My Yamaha RX-V661 powers on when I hit the power switch. After two seconds it goes to stand by.
    Genius:
  • Yamaha Master
  • 1,054 Answers
Try holding the 'straight' and 'audio select' buttons and press power. What does it say on the front panel? Should say some kind of protect: I, DC, PS. This will help narrow down where your problem is.
Posted on Oct 16, 2013
5 Suggested Answers
SOURCE: Yamaha RX-V661 polarity problem
There is no "fix" the mic is picking up a lack of bass based on room acoustics and is trying to help. There is nothing wrong. If you are using bi-pole or dipole speakers it will always show out of phase.
Posted on May 09, 2008
satavlad
  • 405 Answers
SOURCE: My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Posted on Nov 05, 2009
  • 141 Answers
SOURCE: Will not power up
Many receivers are built with relay protection on all speaker outputs. Very handy if there happens to be a questionable speaker or maybe a short circuit in the speaker wiring. What happens is the receiver checks each load on the speaker outputs and if it senses a problems it won't activate the relay to switch audio to the outputs.
Pull you system to pieces, speakerwise, and check if there is a broken or shorted connection. Repair the cable and switch the receiver back on to see if you've solved the problem. If it hasn't then a trip to your friendly repairman may be in order. An interal problem can cause similar clicking noises. But I wouldn't recommend poking around the innards if you are unsure of your abilities.
Posted on Apr 07, 2010
ginko
  • 19396 Answers
SOURCE: Hi, I have a Yamaha RX-A700, It has a flashing
Hi.
The receiver is in forced standby because an internal error has been detected. The condition occurs when there is an internal failure, a wiring related problem (e.g. bad cable), or a wrong voltage from power source is detected (e.g. power surge).
At user level troubleshooting consists in disconnecting power cord, waiting ten or twenty minutes and connecting back (power reset), or in checking cables connected to the unit, replacing cables and restarting the receiver with no cable connected.
If that does not help, then there is an internal failure.
In that case contact Yamaha at the number listed in the owners manual.
Regards.
Ginko.
Posted on Mar 08, 2011
Wrong remote
no but you can change the settings from the front panel of the unit.
Feb 12, 2014 | Yamaha RX-V661 Receiver
My Yamaha V-661 keeps switching off the moment I switch on the unit. Please help.
Hello Sramub hi, there are shorted parts inside your Yamaha, the shorted part is causing the unit not to power on. This feature of not powering on is the powers supply ability to prevent the unit for further damage. Visit your local Yamaha store, for service.
Nov 07, 2010 | Yamaha RX-V661 Receiver
I tried hooking up an old polk sub to my yamaha rx-v659 av receiver. smelled wires burning smell. before i could unplug it, receiver shut down. now it will power up for about 5 seconds and shut off. manual...
If a fuse was blown, it likely would have no power. However if the power board has overheated, the capacitors may have swelled up and burnt out and will only allow it to power on for a few seconds, then shut down. The capacitors can look swelled up or burnt or have burn marks on the power circuit board. You can test them with a continuity meter. Each component has a printed number of it's voltage and ohm resistance so you can test them.
Jul 26, 2010 | Yamaha RX-V661 Receiver
Will not power up
Apr 06, 2010 | Yamaha RX-V661 Receiver
I cannot make any changes to my Zone 2 -- cannot change the volume or change the setting from what Zone 1 is on. A blinking symbol that looks like a mushroom appears when you are trying to switch between...
Hi.
Looks like the the unit is locked to region 1.
The Yamaha receiver you listed is region free, therefore I assume you are talking about a different unit, in that case give model please.
If you have the problem with a Yamaha RX-V661, then simply disconnect power cord for ten minutes. And disconnect from power all devices connected to the receiver.
This should reset the system.
Let me know in case it does not work.
Regards.
Nov 17, 2009 | Yamaha RX-V661 Receiver
Nov 05, 2009 | Yamaha RX-V661 Receiver
Subwoofer plug broken?
Most likely the plug is ok but the level control for the subwoofer will need to be readjusted in the receiver, If the level cannot be raised making sure your source being used has subwoofer information, then there could be a problem in that circuit.
Jul 17, 2009 | Yamaha RX-V661 Receiver
Shuts off within seconds of turning on.
Sounds like the "crack!" was a capacitor that got fat and blew up.
Feb 28, 2009 | Yamaha RX-V661 Receiver
Feb 27, 2008 | Yamaha RX-V661 Receiver
NO VIDEO!!
cheak the out put on the cable box setting hdtv out put is it at 1080 i try 720 p ok
Jan 19, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V661 Receiver Logo
87 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
