Motor on my LG front loader has sparked its way to stop working , is this a costly fix or cheaper to buy a new machine ?
    Master:
  • 492 Answers
Could be a shorted motor. This is cheaper to I stall a new or rebuilt motor verses a new machine.
Posted on Oct 15, 2013
  • 6 Answers
SOURCE: lousy new samsung front loader washing machine won't drain.
blocked pump
Posted on Mar 09, 2009
taran_2005
  • 10515 Answers
SOURCE: Tromm LG front loader error code
Already answered by an expert :-
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Thanks.
Posted on Jun 17, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
  • 2976 Answers
SOURCE: Front loader washer machine not rotating.
Fisrt, see if you can rotate it by hand, BOTH directions. It should have some resistance. If you can spin it and when you stop pushing it will turn a full turn, your drum belt is too loose. If the belt is good and tight, it will spin less than one half rotation, there is probably something blocking one of the wheels that the drum rides on.
Posted on Nov 16, 2009
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
Lg 7.5 WD-8013F had sparks and stopped working
Where do sparks come from. Motor is in back.
Mar 10, 2017 | LG WD-80130F
Drum will not spin
did he run the diagnostics per the tech sheet within the machine?if it will do everything else but spin out,then the drain pump is plugged,as a plugged drain pump will shut down these front load units,you will need to remove hoses off pump and clean out pump and all hoses from tub to drain stand pipe,by running the diagnostics you can run each washer cycle and see what cycle isnt performing in a matter of 5 minutes versus 1 hour real wash time on some cycles
May 01, 2012 | Kenmore HE2 Plus Front Load Washer
WM0532HW LG front loader washing machine displays LE
LE codes are extensively covered in past Fix-Ya solutions, but are generally caused by only a handful of things. 1. the " Load Error " can be a very off balanced load. 2. excessive use of soap leads to too much suds, and thus drag on the inner tub. (use 1 tablespoon of HE soap max. per load) or 3. the Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty. Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000.
Feb 23, 2009 | LG WM-2277HW Front Load Washer
Le code on lg front loader thats
Jan 08, 2009 | LG WM-2277HW Front Load Washer
Frigidare front loader washer GLTF1040ASO
your bearings are shot your washer needs to be rebuilt but it is cheaper to buy a new washer
Dec 26, 2008 | Washing Machines
Question about which washer to buy
I just bought a new washer from Sears (Kenmore, front loading, huge & quiet--$850). You are not going to find a large washer, especially front loading for $399 or under. The new stuff has so many bells and whistles, never cheap to fix.
You can price shop for specifics at great websites like Sears, Home Depot, and Lowes. That will give you a better idea of what you can expect to get for the price you're willing to pay. You will probably be better off buying a good, used machine. Good luck to you.
Jun 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
LG Front Loader made a bang noise.
Door Eventually Opened. Checked all components and found that a thyristor on the main PCB had blown up. The main board is all encased in a epoxy resin so I am forced to buy a complete new unit instead of fixing it. The thyristor costs a couple of bucks but the complete board costs heaps. Who ever designed the system like this must have been in cahoots with the parts supply section. They obviuosly made sure of their future trade.
Jan 02, 2008 | Washing Machines
LE code on LG front loader
Switch off machine, unplug, turn the heat setting on the water down. Plug it back in and select your wash setting. Good luck.
Apr 16, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
