Emerson 32 in. Lc320em3fa. Whinning sound tv won't turn on
  • 2,113 Answers
The power supply section of the tv needs a voltage rectifier or diode or similar possibly there is a fuse inside but there must have been a reason for it blowing. Usually aging electrolytic capacitors are the cause
Posted on Oct 15, 2013
  • 56 Answers
SOURCE: remote control code for 32 inch lcd EMERSON TV
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv t
Posted on Feb 02, 2009
dave1645
  • 834 Answers
SOURCE: I have a 32 inch Emerson tv..model # LC320EM8AN
t-con board is failing have a tech replace it
Posted on Sep 20, 2009
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
  • 8457 Answers
SOURCE: i have a 19 inch
More than the tv power supply board have problems in this tv,don't know yet.But the whinning sound,the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.First must see how it turn out.
Posted on Dec 08, 2010
SD Tech
  • 14553 Answers
SOURCE: my emerson tv won't turn on
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.6_2_2012_12_46_56_am.jpg6_2_2012_12_47_12_am.jpg
Posted on Jun 02, 2012
Emerson tv zoom on model LC320EM3FA is zoomed out how do I fix
Check and adjust the setting that is built into the set. Read your manual.
Mar 22, 2017 | Emerson Televison & Video
Emerson Model LC320EM3FA TV will not turn on?
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Aug 25, 2015 | Emerson Eeon LC320EM3F 32" LCD TV...
How do I change the channel on my Emerson LC320EM3FA 32" flat screen TV? I've tried the auto programming that does not work. When I press the channel button on the TV, it just changes the source...
Has it detected any channels? Are you connected to Cable TV wire or antenna? Has it worked before? Without it detecting channels, all it can do is change inputs.
Sep 08, 2013 | Televison & Video
No sound from my Emerson tv
try a dvd to see if sound via the audio/video jacks and also look in set menu to see is speakers are turned OFF or not, the sound if works with a dvd means it is a hookup or similar issue and the audio circuit in the set is good. Also if set has headphone jack see if that works.
Jul 19, 2013 | Emerson LC320EM9 32 HDTV LCD TV
Emerson tv....won't turn on...stand by light won't go off
Not making it on or out of standby---first place to look is the power supply for signs of damage or puffed up filter caps there.
Dec 10, 2012 | Emerson SLC195EM8 LCD TV
It won't turn on, the red light flashes
That means that its no good and needs to be replaced
Aug 02, 2012 | Emerson LC320EM8 32 in. LCD TV
My tv won't turn on
If the screen is damaged/shattered you are done. Not worth the cost of the part or labor.
If something else use the "make a comment button" on this page to let me know.
Mar 26, 2012 | Emerson LC320EM9 32 in. LCD HDTV
I have a 19 inch emerson lcd tv that has no picture and as u plug it in the tv makes a whinning sound but as soon as u unplug it the sound goes away
Dec 08, 2010 | Emerson LD195EM8 19 in. LCD TV
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
Electro Med Services...
