Question about Proform Exercise & Fitness
My treadmill has just stopped working. The console lights up but when I hit START the belt may only move an inch or not at all. I've taken the hood off and looked at the reed switch but I'm not sure if I'm looking at the magnet or not. This is a ProForm 995 model PFTL99911.0. What I believe to be the magnet is light colored and recessed into the pulley itself. Is this right? If that's not a magnet then I suspect the magnet has fallen off but when I turn the pulley I can't see any other spot where a magnet has been or where it would go. I tried adjusting the reed switch very close to the spot I think is the magnet but I had the same results. Thanks.
  • Tony Feraci
    Tony Feraci Oct 18, 2013
    I checked the reed switch for continuity today and found that it was okay. So I pulled the circuit board and found that the resistor at R37 was burned and half of it was missing. Does anyone know where I can find out the value of R37 so I can resolder a new one on the board? The model number of the speed controller is MC2100LTS-30
  • ernesto cuadra
    ernesto cuadra Oct 19, 2013
    Normailly the value of resistor is printed in c.board indicating value example 1k ( 1000 kilohmios) or 1.5 etc. You can measure the resistance with the Multimeter or DVOM, and replace and resolder on the board. However if the value NOT appear the only way if you have some schematic diagram. You need to cantact for factory supplier for diagram schematic. By that way you need to know was the reason why the resistor was burn? Normally is to due to some short circuit in some another component like resistro, capacitor or IC. God bless you
    Top Expert:
  • Proform Master
  • 12,223 Answers
See the video and fix it. God bless you
Posted on Oct 16, 2013
  • Tony Feraci
4 Suggested Answers
SOURCE: I have a proform j8li treadmill, all 4 led lights
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
Posted on Feb 09, 2010
SOURCE: Proform 730i powers on but will not move when I input speed.
I have the same treadmill with the same problem statement. Here is how I fixed it:....Open the lower shroud that covers the motor. You must remove 4 or 5 screws. Taped to the inside of the shroud should be a document with a calibration procedure on one side and electrical specifications on the other. It will tell you how to run the calibrations. You need to hold the stop button and the + speed button as you insert the safety key. This will put you into calibration mode. My treadmill started working again after I ran the incline calibration routine. Hope this helps.
Posted on Oct 31, 2009
bwinton
  • 83 Answers
SOURCE: Treadmill Incline Works, belt does not move
Check the drive belt. It may be loose or broken. If the belt is loose, then to tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down.
Posted on Apr 30, 2010
Will not turn on. flashing blue light
If the console only reads zeros or the controls do not function properly, try adjusting the reed switch. You will need a Phillips screwdriver to remove the motor hood and adjust the reed switch. Unplug the power cord, remove the motor hood and locate the reed switch, which is on the left side of the belt pulley. Rotate the pulley until a small magnet comes into view next to the reed switch. Loosen, but do not remove, the screw on the switch and move the switch with your hand until the gap between the switch and the magnet is 1/8 inch. Tighten the screw and replace the motor hood. The Controls Are Not Working on NordicTrack Treadmill LIVESTRONG COM
Feb 09, 2015 | Nordic Track Nordictrack C2500 Treadmill...
Jazfit Running Machine
reset the machine, follow this steps and fix it. God bless you
However RUN the software calibration for easy diagnostic goes under the HOOD motor and follow the steps.
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 06, 2013 | Exercise & Fitness
My Nordictrack X9i treadmill console says it is operating at speed, however the track is not moving. Occasionally the belt will move for just a moment then it stops.
do you hear the motor running but the belt is not? if it is the belt need tightened or the drive belt may have broken. remove the motor hood to inspect
Aug 23, 2012 | NordicTrack Exercise & Fitness
What could it mean if the treadmill just stops, but the board is still lit up? The belt won't move even when I turn the treadmill off and turn it back on. The numbers on the board light up, but...
Dear Sir:
I will help you, inmediately.:
Try it with this step:
When machine is Stopped with various months, the dust+ corrosion in the electronic system can be affected.do it the following :
    • 1
Someconsoles require batteries. Check to see if this is the problem. If the consoledoes not use batteries, move on to Step 2.
    • 2
Removethe key from the console.
    • 3
Unplug the power cord.
    • 4
Removethe screws from the console hood and remove the hood.
    • 5
Turnthe pulley until the reed switch and magnet are aligned with a 1/8-inch gapbetween reed switch and pulley.
    • 6
Replace the hood.
    • 7
Plugin the power cord.
    • 8
Reinsertthe key into the console.
    • 9
Runthe treadmill to check for a correct speed reading. This may take a fewminutes. Check this, and contact me, if you need some additional help. blessing , sincerely. E.CUADRA MANAGUA, NICARAGUA. C.A.
Sep 13, 2011 | Reebok Exercise & Fitness
Walking surface will only move very slowly. The belt seems tight enough, tried to tighten 1/4 turn, still not moving properly. Treadmill is a Weslo Cadence 450, bought a few years ago. Thanks
lift the sides of the w/belt the hieght should be 2-3 inches. if more to loose,tighten it up. still have a issue take hood off and check the motor belt. if you find a bunch of black dust. your belt is worn or on its way out.PS you can find the belt on the web.
Mar 09, 2011 | Cadence Exercise & Fitness
There is no display light anymore.
Some consoles require batteries. Check to see if this is the problem. If the console does not use batteries, move on to Step 2.
    • 2
Remove the key from the console.
    • 3
    • 4
Remove the screws from the console hood and remove the hood.
    • 5
Turn the pulley until the reed switch and magnet are aligned with a 1/8-inch gap between reed switch and pulley.
    • 6
Replace the hood.
    • 7
Plug in the power cord.
    • 8
Reinsert the key into the console.
    • 9
Run the treadmill to check for a correct speed reading. This may take a few minutes.
Feb 19, 2011 | Proform XP Weight Loss 620 Treadmill
NordicTrack T5.3 belt stopped working. It's only 1 month old. Console lights up. Incline works. But belt isn't moving
HI, its seems like the belt on the motor has either slipped off, or you just need to tighten it. best way to find out is to take off the front pannel showing the motor. then stand on the treadmill. start it and you will see the problem.
Nov 21, 2010 | Nordic Track Exercise & Fitness
Exercise & Fitness Logo
148 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
