Question about Kenmore Heating & Cooling
Air conditioner won t turn off
Screen says "LL"
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
1997 Cadillac Deville can I still drive the car if it says very low refrigerant
If you are talking about refrigerant for your air conditioner than yes you just won't have an air cond. If you are talking about refrigerant for your motor than NO you'll blow the engine
Mar 04, 2012 | 1997 Cadillac DeVille
HI, My Kenmore Air Conditioner Model# 76129 - turns on, makes a sound like it is going to work but the fan does not move. Thanks
When a fan malfunctions, the problem is usually loose or dirty blades. If the fan won't operate or if it's noisy, cleaning and tightening will usually fix it. Here's how to repair a room air conditioner's fan:
What You'll Need
You'll want to have these tools on hand to repair a room air conditioner's fan:
  • Vacuum
  • Soft cloth
  • Screwdriver or Allen wrench
  • Long-blade screwdriver
  • Wrench 20-weight nondetergent motor oil
  • Volt-ohmmeter or multimeter
Step 1: Open cabinet and locate fan.
Step 2: Clean away any debris with vacuum and soft cloth.
Step 3: Check fan blade on motor shaft for looseness. Blade is fastened to shaft with setscrew at hub of blade.
Tighten setscrew with screwdriver or Allen wrench. If air conditioner has round vent fan, tighten fan on motor shaft by inserting long-blade screwdriver through port in fan.
Fan is installed in its h­ousing with bolts, and vibration can loosen these fasteners. Then tighten them with wrench.
Step 4: If fan has oil ports, apply several drops of 20-weight nondetergent motor oil (not all-purpose oil) to each port at beginning of cooling season.
Step 5: If you suspect fan motor is faulty, test it with VOM set to RX1 scale. Disconnect terminal wires from terminals, and clip probes of VOM to wires.
If meter reads between about 3 and 30 ohms, motor is functioning properly. If meter reads either zero or an extremely high number, replace motor.
To remove the fan motor, remove the fan, the power wires, and several mounting bolts. Install the new motor with the reverse procedure .bobicehouse_59.jpg
Aug 13, 2011 | Kenmore 76129 Air Conditioner
When ever I turn the air condition on. this symbol (HL) appear on the small screen, and it won't open What does that mean? Thank u
I think what you are seeing is "FL", rather than HL. FL indicates that the water collection bucket is FULL & needs to be drained. Sometimes. the LED letters on the screen can be hard ti read.
Hope this helped you and thanks for choosing FixYa.
Aug 10, 2011 | DeLonghi Pinguino PAC T100eco Portable Air...
Does not blow hot air on heat
tURN THE THERMOSTAT TO FAN ON TO SEE IF IT,LL START, IF IT DOES, THE SPIN THE SQUIRELL CAGE BLOWER WHEEL WITH A STICK TO SEE IF IT,L TAKE OFF, IF DO THEN ITS THE CAPICATOR. TRY TO SEND 120V TO THE FAN MOTOR TO SEE IF IT,LL START IF DOES THEN THE C. BOARD IS THE PROBLEM.
Dec 02, 2009 | Ruud UBHC Air Conditioner
Turned off a/c remote < now it won t turn back
It sounds like the remote sensor pc board is bad, you need to replace the sensor board.
Nov 03, 2009 | Fujitsu 24C1 Air Conditioner
Looking for btu on airtemp imperial ll model
This information can usually be found on a small plate welded or glued onto the side/rear of your A/C units along with the model & serial #s. Although it would be a highly illogical place to put this plate, you may also want to check the bottom but if you turn the unit upside down, do not turn it on for 24 hours, as the gas & oils will be displaced & you can kill off the compressor by doing so.
Jun 15, 2009 | Airtemp B3Q06F2A Air Conditioner
Heating & Cooling Logo
24 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
