Question about Tools & Hardware - Others
Bostitch model phd 60
How do you unjam the phd60
Where can i get parts for n 60 nailer
Bostitch was purchased by Dewalt and parts are available from your local Dewalt service center or here:
http://servicenet.dewalt.com/
Good luck.
Jul 16, 2014 | Stanley Piston Driver Assy Bostitch N60fn...
Spring to stapler fell out
Hello, Go to this website for support phone numbers and too download manuals for this product. Bostitch Office Products Staplers Pencil Sharpeners Hole Punchers Tools...
Mar 03, 2014 | Stanley Black & Decker Bostitch 20SUITE...
Error code 007 340
Hello!
This issue relates to an error with the PHD (Photoconductive) Unit. To resolve this error please try the following steps:
1. Turn the printer off.
2. Wait 10 seconds.
3. Turn the printer on.
4. Determine if the issue still occurs.
5. If 007-340 or 007-341 Restart Printer Error recurs please remove the PHD Unit and remove any packaging.
To Remove PHD Unit:-> Remove the Paper Tray
-> Open the front cover.
-> Put a piece of paper on the transfer belt to protect it from scratches and from light damage. Do not cover the left and right of the belt guards with the paper.
-> Rotate the four stoppers of the PHD counter-clockwise 90 degrees to release the locks
-> Remove the PHD unit toward you by pulling it by the left and right handles.
-> Lift up the PHD unit from the printer. Be careful to avoid scratching the transfer belt.
-> Remove the packing tape by pulling straight out
Reinsert the PHD.
-> Close the front cover.
6. If error recurs with the PHD Unit re-seated please try another PHD from a working 2130CN Laser Printer (if available).
7. If issue recurs after trying another PHD or no PHD Unit is available, please call Dell Technical Support to advise.
Oct 28, 2013 | Office Equipment & Supplies
I have jammed a bostitch t5 staple gun and would like to know how to unjam it
if you take the pins out that hold the front off it will allow you to get at the jammed staple but be careful how every thing comes apart it will not work if shims and washers are not replaced right
Mar 14, 2011 | Aerobie Arrow Staplebrad Gun T50pbn
The nailer is jammed but it is not in the shaft, how can I unjam this gun?
Clearing the jam will require some disassembly. See the link below for additional information about parts and disassembly diagrams for Bostitch guns. Enter the model number when asked.
Dan
Link: http://www.fixya.com/support/r5812776-bostitch_nailgun_dis_assembly_assembly
Feb 25, 2011 | Stanley Bostitch SB1664FN 16 Gauge...
Where can I download a manual for Bostitch T5 Staple Gun
If you want to know how to load the staples, lift the wee flap at the end with the inscription " lift to insert staples".....
Jan 23, 2010 | Stanley Hand Tools
Bostitch nail gun number SB-21n1 is jammed and need manual to know how to unjam it or a solution online. Was using it in the staple mode and it jammed after about 5 staples. Was using bostitch staples.
Hello. Begin by disconnecting the air hose. That way you can not get hurt while removing the jam. Get a pair of needle nosed pliers and remove each of the jammed staples. They will pull out I assure you. Then Use a little WD-40 or compressor oil to lubricate the working mechanism at the firing head. IF you must loosen up the mechanism to remove all of the staple parts be sure to use the correct size allen wrench. I am providing link to a free manual for your gun in case you don't have one: http://bostitch.com/catalog_images/web_pdf/107674.pdf
Jan 12, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
18 ga. Bostitch nailer that has a small brad jammed in it.
check your hex wrenches they could be standard when they need to be metric.
Sep 23, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
I have an old Bostitch SN80 Stick Nail gun that has a broken striker resulted from a jammed nail. Is there replacement parts for it or recommend a service repair center in the Greater Area North of Boston,...
I order parts from several companies for Bostitch nailers. First however make sure of the model number of the gun. Bostitch nailers had the model stamped onto the lower part of the body just barely visable when new. They had a framer with the model designation N80S. Max has a model # sn80 which looks just like the bostitch but their colors are red and silver instead of yellow. The best place for parts for outdated guns is: http://www.foxborotool.com/parts.htm. Email them with your needs and they will inform you of prices/shipping. Driver is easy to install. Other places to order bostitch is WWW.toolpartsdirect.com and of course www.bostitch.com. At the bostitch site look for support, then service parts, then press down arrow for model numbers. Good luck with your repair and email if you have questions.
Apr 27, 2009 | Stanley Bostitch N80s Nailer -rebuild...
Tools & Hardware - Others Logo
50 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
