Question about Proform Pro Form 710 E Elliptical
Not accurate on the distance is reed switch to blame?
    Top Expert:
  • Proform Master
  • 12,223 Answers
No RUN the software calibration for easy diagnostic and fix it. Go under the HOOD cover motor and follow the steps or ready your owner manual.
God bless you
Posted on Oct 16, 2013
Are laser distance meters really accurate?
They are accurate to a point, it can be very difficult to get an accurate distance reading because of terrain and if there are obstacles in the way like trees.
Jan 22, 2014 | Measuring Tools & Sensors
I bought a second hand Proform 14.0 CE elliptical. The incline is stuck at about 20 degrees. The incline ramp moves slightly while trying to calibrate but remains about 20 degrees. The display shows that...
FOLLOW this steps and fix it. God bless you
Clean the heart rate monitoring pads if the console is not displaying your heart rate when you grip the pads. Use a damp cloth and a mild soap to clean the pads. Do not use alcohol or any other abrasive cleaners that may damage the equipment.
    • 2
Calibrate the ramp if the elliptical is not functioning properly. Press and hold the "Target Toning Workouts" button on the console until the calibration mode appears on the display. Press the "Target Toning Workouts" button once. The elliptical will display additional directions. Use the "One Step Power Ramp" increase and decrease buttons to raise and lower the ramp.
    • 3
Adjust the reed switch by removing the access cover, which sits over the wheel of the elliptical at the back of the machine. The access cover can be removed with a flat-head screwdriver. Unplug the machine. The reed switch provides information to the console for display. Rotate the pulley until the pulley magnet, which is under the belt, lines up with the reed switch. The reed switch has a wire running into it. Loosen the screw to the reed switch and adjust the distance closer or farther from the pulley magnet. Tighten the screw. Plug in the machine and rotate the pulley. If the console still is not displaying correctly, repeat adjusting the reed switch distance either closer or father from the pulley magnet.
    • 4
Adjust the drive belt if the pedals slip while in use. Unplug the elliptical. Lift the latch on the underside of the left pedal arm and slip it off. Use a screwdriver to remove the arm sleeve and pry open the disc panel. Loosen the pivot screw located on the left side. The belt tighten screw is below the pivot screw. Tighten the belt tightening screw until the belt is tight. Tighten the pivot screw. Replace the disc and arm to the elliptical
Oct 24, 2013 | Exercise & Fitness
95t black screen
Dear Sir:
Wacht this video:
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1 Ensurethat the treadmill is plugged into a grounded outlet using the correct surgesuppressor. Use a UL 1449 suppressor listed as a transient voltage surgesuppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure theservices of an electrician if the outlet is not grounded, or move the Proformtreadmill near a grounded outlet. Do not use an extension cord. o 2 Insertthe safety key fully into the display. Treadmills with keys are designed not toturn on without the safety key in place. o 3 Findthe circuit breaker on the front of the frame and make sure it is not tripped.The circuit breaker is a vertical switch on the 540S and a horizontal switch onthe 540 Interactive Trainer. Press it to the "Reset" position, whichwill be labeled.2. ReedSwitch
o 1 Unplugthe treadmill and remove the safety key. o 2 Movethe upright base of the treadmill down with the help of another person and liftthe uprights so that you can get to the underside of the console. Use aPhillips screwdriver with at least a 5-inch shaft to remove the screws. Thereare five hood screws on the 540 Interactive trainer and four screws on the540S. o 3 Removethe motor hood to get to the small reed switch by pivoting the hood off theframe. Find the reed switch and magnet, which are on the left side of thepulley for both models. o 4 Turnthe pulley with your hand until the reed switch aligns with the magnet. Thereshould be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inchby loosening the reed switch screw and sliding it to the correct distance. Tightenthe screw. o 5 Reversethe directions to put the hood back on and the treadmill upright in theoriginal position.Sincerely. God bless you.
E.CUADRA
Oct 28, 2011 | Life Fitness 95Te Treadmill
I have a Pro-Form 400 CT Treadmill, The console light flickers and gets dim. Can I repair this?
Dear Sir:
I will try help you, please use the patience, carefully, and basic tools
1. Power
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
With this you will fix. See the Videos:
http://www.youtube.com/watch?v=jH3ctwTvdVo&feature=related
If you need further assistance, pleae reach me, sincerely. God bless you.
E.CUADRA
MANAGUA,NICARAGUA.
Oct 26, 2011 | Exercise & Fitness
Schwinn 5450p treadmill once unplugged & plug back in, panel is black & it buzzes
Dear Sir:
Thank you by you request, I will help you inmediately.
A) POWER
B). ReedSwitch
o 1 Unplugthe treadmill and remove the safety key. o 2 Movethe upright base of the treadmill down with the help of another person and liftthe uprights so that you can get to the underside of the console. Use aPhillips screwdriver with at least a 5-inch shaft to remove the screws. Thereare five hood screws on the 540 Interactive trainer and four screws on the540S. o 3 Removethe motor hood to get to the small reed switch by pivoting the hood off theframe. Find the reed switch and magnet, which are on the left side of thepulley for both models. o 4 Turnthe pulley with your hand until the reed switch aligns with the magnet. Thereshould be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inchby loosening the reed switch screw and sliding it to the correct distance. Tightenthe screw. o 5 Reversethe directions to put the hood back on and the treadmill upright in theoriginal position.C). OpticSensor
o 1 Unplugthe treadmill, take out the key and remove the hood cover. o 2 Locatethe optic disc and optic sensors. The optic disc is the only circular disc setbetween two optic sensors. o 3 Spinthe disc with your hand. It must spin without hitting either of the sensors.Loosen the adjustment bolts that hold the switches in place with the includedAllen wrench and adjust them to ensure they do not interfere with the discs'ability to spin. Tighten the bolts and replace the hood.
Thank you in advance, sincerely. God bless you.
If you need further assistance, please contact me.
E.CUADRA Managua, Nicaragua.C.A.
Sep 28, 2011 | Exercise & Fitness
Just was given the exp2000 from a family member, machine is plugged in and when powered on, it immediately flashes all lights then it goes black. ALSO, we just noticed the key is missing. Would that effect...
1) Find the key.
2) Follow this:
    • 1
    • 2
    • 3
2. Reed Switch
o 1
o 2
o 3
o 4
o 5
Jul 24, 2011 | Nordic Track NordicTrack Treadmill, A2550
Hi, nordictrack c2000 has been working ok until today. The belt still goes round and the music is playing, but the screen has gone blank. Everything else is working except nothing is showing on the...
Do the following and see the video:
    • 2
    • 3
2. Reed Switch
o 1
o 2
o 3
o 4
o 5
Check to the Opticar sensor : if have it.
Jun 17, 2011 | Nordic Track NordicTrack Treadmill, A2550
I have a nordic trac a2050, that is only working on 1, and 7. The speed down button is working but nothing else. Any ideas?
    • 2
    • 3
2. Reed Switch
o 1
o 2
o 3
o 4
o 5
Check the Optical sensor: if have it. very important!
http://www.youtube.com/watch?v=E-q-uS4t6so Watch this video.
Jun 12, 2011 | Nordic Track NordicTrack Treadmill, A2550
My NordicTrack A2050 no longer displays anything - it's about 7 years old. I ran on it, powered off, then my husband went to use it and the console wouldn't go on. We hit the 'reset'...
Watch this video and Step:
    • 2
    • 3
2. Reed Switch
o 1
o 2
o 3
o 4
o 5
Chech: Optical Sensor if have it.
May 18, 2011 | Nordic Track NordicTrack Treadmill, A2550
LS code - manual says reed adjustment but no indication what the reed is?
A reed switch or in some cases a speed sensor is locate by the front roller/pulley it could cylindrical or square looking.First you need to unplug the unit, then remove motor shroud inspect the reed switch to pulley distance ( no more than 3 credit card thickness) also inspect the pulley to see if the magnet is still attached to it. make the necessary adjustment. plug in the unit start it up. If it give you the same code then replace reed switch!
Mar 12, 2010 | Exercise & Fitness
Proform Pro Form 710 E Elliptical Logo
46 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
