Hi .. My laptop can not save bios settings .. i
Hi .. My laptop can not save bios settings .. i tried many times to change the boot order but nothing happened
    Scholar:
  • 66 Answers
U will need a new battery located on the motherboard
Posted on Oct 15, 2013
Testimonial: "I have changed it but the problem is still existed ."
  • 4 more comments
  • philip irving Oct 15, 2013
    what are u trying to change it from?
    did the cdrom or drive u are trying to change it too come installed with the computer from the factory?
    if not u maybe unable to change the sequence as the drivers for the drives need to load in order to be recognised first.
  • mohamed mostafa
    mohamed mostafa Oct 15, 2013
    No .. the problem is that bios can not save any settings .. even after changing the battery .. is there any other suggestions...
  • mohamed mostafa
  • mohamed mostafa
    CD works well and no problem in it
IB4G2008
  • 3587 Answers
SOURCE: laptop
hmmm..yes..sounds like your bios is fried..
you have the recovery disk anywhere? or a operating system disk?
Posted on Jun 01, 2008
  • 177 Answers
SOURCE: IBM Thinkpad T21 doesn't boot from CD-rom
Check the following:
1 make sure that the cdrom is okay. if not sure then try cleaning the cdrom lense which can be found in the cd tray,
2 make sure that the cd disc you are trying is a bootable one
Posted on Nov 26, 2008
gnkanang
  • 63 Answers
SOURCE: Operating system not found
hi
Why cannot you change the boot order? you use the page up and page down keys
Posted on Mar 25, 2009
darkdragons
  • 835 Answers
SOURCE: ACER 3100 does not boot
have u tried booting the computer with just the power supply hooked up and your battery out? iv'e had the same exact lab top and the battery went bad and the computer wouldnt do anything at all like your talking about. Even if i had the power supply hooked up and the battery. Remove the battery, and try booting it up.
Posted on May 23, 2009
  • 13433 Answers
SOURCE: Acer Aspire wont boot up
if it doesn't save the bios settinsg, then most likely the memory battery is empty or disconnected. replace the memory battery and try again.
Posted on Jun 07, 2009
Can't change boot order
so that meant you changed it , then clicked save
, then powered off ,then back on then went back to the same place in bios and it is wrong , now, and you are confused
well well YOUR COIN CELL< CMOS RTC battery is dead.
end saga.
but if above was saved, ok, 2nd look and it did not boot in that order and you for got to hit the say the huge space bar
at boot time , over and over the CD or DVD can not not ever boot due to the laws of EL Torito (intel/MS and HP rules)
on my server here, it shows, hit a key to boot to DVD
or to stick usb.. clear as day but other HP PC may not prompt you and sure that is bad play.
to save the BIOS you must use the right key to do that
it tells you what to do. exiting BIOS.
but if the Battery dies, the NVRAM is now dead and can not store BIOS settings nor the the time of day (RTC)
facts. all.
Nov 15, 2017 | HP Pavilion a6750f PC PC Desktop
How to change boot up menu to cd rom
when your laptop sets up press F10 that will take you to your BIOS ...next go to "ADVANCED" Next go to BOOT OPTIONS...NEXT go to BOOT ORDER.... To change the order of your boot, use the + and - keys, after you get the cd-rom first in order, hit F10....go over to the "FILE" and save changes and exit. Your laptop will restart on its own ! to change the setting back just reverse the boot order ! :)
Jan 26, 2013 | HP Compaq Presario 2100 Laptop
Boots only to bios settings, then blank screen after save and exit. will not take a cd boot.
Hello, since it can boot to bios setting, then have you try configuring the boot order,the cd drive should come first,after that your hard disc, if the hard drive comes before the cd rom then it would not recognise it. Change the settings and Save this settings, then try to boot from the cd again, if this does not work then i am rest assured that your hard drive has a problem,and you need to find solution to it by getting a new one. cheers Regards
Dec 01, 2010 | Acer Aspire One Netbook 8.9" Notebook
Want to re-format MSI Notebook S420. Screen continuously shows windows 'loading' but never boots. I have the recovery CD but because the computer never actually starts, I'm not sure what to do with it!MSI
Hello megan_van
While your laptop is on, eject the optical drive and insert the recovery CD. Turn off your laptop via the power button, and turn it back on. The recovery CD should boot. Follow the on-screen instructions to do a clean install.
If the recovery CD doesn't boot, try holding down the C key after turning on your laptop. If it still doesn't boot, you will have to change the boot order in BIOS. Don't worry, this is easier than it sounds! Follow these instructions:
1. Turn on your laptop, and look for a message that says something like PRESS (USUALLY F2, F8, DEL, ETC.) TO ENTER SETUP / BIOS. Hit that key before the Windows logo appears.
2. After hitting the relevant key, you'll be taken to the BIOS setup utility. All BIOS utilities have different appearances, but it is basically a set of menus containing different settings for your laptops hardware. Somewhere on the screen (usually the bottom), is a set of instructions for navigation your way around the BIOS. Follow these instructions to navigate your way to the option for changing the boot order.
N.B. Since every BIOS setup utility is different, the specifics on where the boot order options are located varies from computer to computer. The menu option or configuration item might be called boot options, boot, boot order, etc. The boot order option may even be located in a general menu like advanced options, advanced BIOS features, other options, etc.
3. Once you've located it, use the navigational controls to place the optical drive above the hard drive (usually the +/- keys). To be certain that the recovery CD boots, it's probably best to move the optical drive to the top of this list.
4. Within the navigational controls, there is usually an option to SAVE & EXIT. Press this key. If there isn't, look for a menu option with the heading EXIT. A SETUP CONFIRMATION box will now usually appear asking you to confrm the changes you've made to the BIOS before exiting.
N.B. The SETUP CONFIRMATION box can sometimes be worded cryptically. Read the message carefully to be sure that you're saving your changes instead of exiting WITHOUT saving your changes!
Your computer should now restart automatically, and the recovery CD should now boot.
Hope this helps. If you require further assistance, please don't hesitate to ask.
ajblaj
Apr 28, 2010 | MSI MEGABOOK M510C Notebook
How to boot laptop from usb flash disk
When u just turn on your laptop go to bios settings.....in bios settings change the boot priority to USB flashdrive....save and restart before you restart connect your flash drive to ur laptop......it will ask boot from flash drive press any key....n contiune...hope this helps
Mar 11, 2010 | Computers & Internet
Switching on my new hi grade laptop it read sis191 pxe bootroom v1.3 use bev/bbs pxe-e61 ; media test failure , check cable pxe-mof ; exiting sis191 pxe bootroom
Hi, You have to change the boot order in the system BIOS. i think it is set to try to boot from the network first before it tries to boot from the Hard Drive
You will have to change it to boot from hard drive first.
I'm not 100% but try it.
I hope I have helped you, if you need more help, let me know.
Regards - Anthony
Feb 08, 2010 | Computers & Internet
Only booting after pressing f12 and select boot devise
You must change the boot sequence from your BIOS.
To do this, when your computer starts press F1 or F2 until you enter the bios setup menu. Usually on Toshiba is F1 or Esc key.
Now that you are in the BIOS, you must locate the boot order section. Just go through every page until you see something like Boot Device, Boot Order, Boot Management, Boot Sequence, etc. (its different for each computer)
There, change the boot order to move the Hard Disk or DVD ROM in the top two items in the list.
Save your settings and exit the BIOS.
Your computer will restart and it should boot up normally.
Feb 02, 2010 | Toshiba Satellite Pro A200-EZ2204X...
I recently had a huge virus attack on my laptop and there is still this worm that my system picks up but not my anti virus i need to format my laptop but it does not seem to want to boot from the cd what...
Take a can of air and blow some air onto the laser gently to make sure no dust or dirt is affecting it.
Then go into the BIOS and make sure the cd-rom is the first boot device. Then put your operating system cd into the drive and "press any key" when that message comes up so the system can boot up off of the cd.
If after setting the cd-rom as the 1st boot device you can't get the laptop to boot up off of the OS cd then that means the cd-rom is bad and would need to be replaced. When you boot up off of the cd-rom your in DOS and any viruses or worms wouldn't affect it.
Jan 15, 2010 | Lenovo 3000 N500 Notebook
Bios does not save any changes that are made toshiba sat.
Changes to Boot Order only last as long as the next boot, you have to press F12 every time to alter boot sequence.
Oct 06, 2009 | Computers & Internet
After the initial BIOS checkup, this error came up Realtek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.13 PXE-E61: Media Test Failure, check cable PXE-MOF: Exiting PXE ROM what is this code and...
It looks like your machine is trying to use the network boot function, go into the bios and change the boot order so that your hard drive is the first boot device...
Feb 24, 2009 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
