Washer overfills - Washing Machines
    Sergeant:
    Champion:
  • 257 Answers
Overfill is cause mainly by pressure switch, check the pressure switch by measuring the connectivity of the switch when blowing to the hose tube (for old models top load only). For newer models the switch is an electronic part and normally can not test it.
Posted on Oct 15, 2013
Washer overfills & excess comes out from underneath
what is your model number then we can get started then okay
Feb 11, 2013 | GE WBSR3140DW Top Load Washer
Hi. My Whirlpool Duet Sport washer stopped mid-cycle and is flashing F-. I can't open the door. Help!
The pump on your washer is apparently not working. It should have pumped the water out when the FL was displayed. You should schedule service and let a technician diagnose and repair the washer.
Flood Condition F L "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lock condition in order for "FL" to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
Mar 21, 2011 | Whirlpool Washing Machines
What is the lf code on the cabrio washer?
FL Flood Condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Mar 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Fl code on kenmore calypso cannot clear
this is the fl code on a whirlpool calypso which is probably the same since kenmore is just a name,, whirlpool built the machine if u didnt know kenmore doesnt build anything they just put their name on things... (FL is a flood conditon.) FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
The washer will flash the code FL what dose this mean??? thanks for the help model 21062
fl flashes if any overfill condition occurs.this condition occurs when excessive water in the tub causes the overfill switch to trip.the control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for fl to be displayed.with an overfill condition ,the beeper repeats a warning every 10 seconds with no time-out.the pump is cycled in drain mode for 30 seconds on 30 seconds off untill the overfill switch resets or power is discontinued to the unit.press stop/cancel to clear the display.
Jan 08, 2010 | Kenmore 24032\24036 Top Load Washer
FL alert
Sep 19, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
MY WASHER IS BEEP AND DISPLAY FL
FL means flood condition
Solution: "FL" flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for "FL" to be displayed
Jul 16, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
What does FL mean when it comes on washer ?
Flood condition "FL"
***If there was not an Overfill condition and, the SUDs were not present when this alarm was initiated, thsi will confirm a faulty Overfill switch and, it should be replaced.
Jul 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer will overfill on small load and large
If this happens only on small load cycle , then it can be a faulty timer board.
however check also the water level switch, when there is overfilling this part is always the first suspect.
May 21, 2009 | Kenmore Elite 21082
Kenmore 90 series washer overfills
your pressure switch may be bad or your hose that goes from your tub to your switch may be clogged with gunk
Mar 07, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
