Question about Lennox Healthy Climate HCWB3-12A Humidifier with Automatic Control
I have a Lennox icomfort thermostat control. It was working fine until about 1 day ago and now it has lost the wi-fi connection and I can't re-establish the connection. We haven't had any changes to our computer or wi-fi so not sure why it suddenly was lost. I have unplugged the router as well as re-entering the wi-fi information in the thermostat. Any other suggestions?
  • 66 Answers
There is no problem with the Stat. Lennox probably had a upgrade going on turn the switch off on the furnace and the Stat will reboot
Posted on Nov 08, 2013
Does a y2081 lennox thermostat have a batteryin it
Yes it has 3 AAA batteries.
Pull it straight off the wall. Look at the back of the thermostat and replace the three batteries.
Link to manual..
http://www.lennox.com/pdfs/manuals/Lennox_Elite_Touchscreen_Manual.pdf
Sep 10, 2014 | Lennox Y2081 ComfortSense 7000 Thermostat...
No water flow through solenoid
The water flow through the humidifier is limited/controlled by an orifice. This small opening can easily clog. After disassembly use a small wire to clear the debris trapped in the small hole,
Hope this helps?
May 18, 2017 | Lennox Healthy Climate HCWB3-17A...
I hear no water draining from my heathy soluions lennox humidifier just put in a new filter
None leaking? Try removing the cover, and manually cycling on the controler switch? Does the solenoid click on, next to the humidifier (the unit with the water line running through it, with wires coming out of it)? If it does click on, is water running down the water pad? It doesn't necessarily drain water when it's working correctly. All of the water SHOULD be getting evaporated into the air return duct.
If it's clicking on, but no water is running out, you should check the water supply saddle valve and make sure it wasn't turned off during servicing.
If it's not clicking on, you should test that you are getting voltage (12v-18v DC) to the solenoid. If you're not, check all wiring connections and make sure they're tight. If you still don't get power, you have either a problem with your control unit/humidistat, your DC power supply, or the control board on your furnace.
Jan 06, 2013 | Humidifiers
The date - February 23, 2010 - 6 days ago, I purchased a Sunbeam Humidifier from my local Walmart - Lake Geneva, WI. I really thought I had made a wise purchase - very quite, and was raising the humidity...
Im not going to recomend a humidifier because I need one myself and have not went shopping yet.
I would like to opinionate an explination on the white haze.
The humidifier is putting moisture in the air -water is much much heavier than the air - water is much much heavier than dust particles also.
therefore my theory is that the moisture is combining with the dust or whatever is already in the air and then eventually settling. perhaps if this is correct you may want to do some checking around in your home or furnace ducking or even furnace filter. The dust could even be coming from a little pin hole in your clothes dryer exhaust hose.
Mar 01, 2010 | Sunbeam Ultrasonic Humidifier
What controls how much water flows into an Aprilaire 550? It was fine until a couple of days ago. I replaced filter, but it still appears to be too strong. It not only runs out the drain tube but is...
In the water line where it connects to the solenoid is an orifice. You can install a smaller plastic orifice or you can install a manual feed valve to where you can control the flow.
Feb 12, 2010 | Aprilaire 550 Humidifier
HOW DO I CONNECT TO 24 VAC FOR THE HUMIDIFIER TO
you can hook it to R and W on the board but you should really use a current sensing realy on the blower so it wont come on until the fan is running and you should also have a humidistat
Oct 04, 2009 | Honeywell Power Humidifier: Furnace...
We have a Sunbeam Cool Mist Ultrasonic Humidifier that we bought just over 2 months ago. Up until a couple of days ago, it was producing mist and running just fine. I cleaned it with the brush and got the...
I have this same problem. And cool mist humidifiers DO produce mist. I have had my humidifier for a while now (6 years) and have never had any problems. But after the most recent cleaning, it worked at first, but now seems to not be working anymore... Am also wondering if there is anything I can do to remedy the situation?
Mar 17, 2009 | Sunbeam 701 Humidifier
No mist
i would try cleaning the coils for the heat portion. if they are to scally that could be one reason why it's not making any mist. but if it looks pretty clean or if you have cleaned it and it's still not making any mist then it's something internal. now if your under warranty still that's a good thing. you can always call the manufacturer and they can replace theunit for you under warranty . if you have any other questions please let me know.
Feb 26, 2009 | Holmes Products HM500-UC 1 Gallon...
Lennox Healthy Climate HCWB3-12A Humidifier with Automatic Control Logo
315 people viewed this question
Top Lennox Humidifiers Experts
Paul Carew
Dennis
Are you a Lennox Humidifier Expert? Answer questions, earn points and help others
