Question about Lennox iComfort Wi-Fi
My lennox icomfort system suddenly lost wi-fi connection and I can't get it re-established.
    Scholar:
  • 111 Answers
Here is a link in detail from the Lennox website, hope this helps.
https://www.myicomfort.com/Support.aspx
Posted on Oct 17, 2013
  • 422 Answers
Try delete/forget the wifi password, then reenter
Posted on Oct 16, 2013
My honeywell HFD-015C air purifier wont turn on
Hello, this is Ava with Think Crucial.
You may check to make sure that the power cord is correctly connected to the outlet. Test the outlet is functioning properly using another appliance or lamp. Also, check the fuse or circuit breaker. The outlet may be overloaded if other appliances are also in use. Establish and correct the cause of the overload. If none of these works, then there is something wrong with your purifier unit and contact the store where you purchase it or Honeywell for replacement. It is advised not attempt to repair the unit yourself.
You can purchase a wide variety of high-quality Honeywell replacement parts for your Honeywell air purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
May 31, 2014 | Honeywell 17000 Air Purifier
My Honeywell 5-in-1 True HEPA Tower Air Purifier with UV Allergen Remover wont turn on.
Ava B.
Oct 25, 2013 | Ecoquest Fresh Air Air Purifier
All of a sudden my purifer is no longer working I have notice the ceiling aboe were my purifer sits the ceiling is getting dark so I shut it off , it just not seem to clean the air anly longer my serial...
These units are manufactured by Alpine Air Products. Some years ago, they were sold through Network Marketing Reps.
You can contact Alpine Air Products directly at 888-675-2616, Monday - Friday (9am - 5pm PST).
That will be your best bet.
Feb 22, 2011 | Ecoquest Fresh Air Air Purifier
I replaced a Lennox DSL-450LX heat pump thermostat with a Honeywell RTH3100C. Everything works except the gas does not ignite when set to emergency heat. The Lennox was wired as follows: W = white wire Y1...
Hi, If indeed you do have a heat pump, there wouldn't be any gas involved as a heat pump runs on freon with a reversing valve and heat strips for aux and emerg. heat. For gas electric operation thermostat terminals are rc to rh with factory jumper. Red wire to either.W to W for Heat, Y to Y for cooling G to G for Fan. If you have a blue, you wont need it unless this is a commercial stat useing a common for the Led lights on the stat. The unit will get its 24volts through R terminal in combination with y,w,and,g. Cant be a heat-pump if you have a gas furnace.Wrong t-stat. You need a gas /elect stat. And on a 24volt programmable t-stat, the batterys are used for the program only.If the batterys die, than you will loose the program on most residential stats. On commercial stats with the common in play, when batters die the stat defaults back to the factory settings.If you had a Lennox heat-pump stat on a gas/elect unit, you need to change it. Someone was using what they had on hand. Let me know if this has helped you.I will be here if you need me. Sincerely,
Shastalaker7
Nov 17, 2009 | Air Purifiers
I have cleaned my unit but the red light stays on
Likely so these units usually put out ozone into the air in your home which is a known lung irritant. If you truly have indoor air quality issues the only way to properly attack it is through three steps
source control - what's causing it(uv lights to kill it usually)
ventilation - bring in fresh outdoor air and exhaust stale indoor air(ERVs and HRVs depending on your climate some dealers won't sell these if they don't offer it to you they are dumb find someone who does they are Recovery Ventilators)
filtration - a whole home filtration system (look to dealers who carry Lennox who is the only company with a 100% ozone free product line and the highest filtration rates available on the market "MERV 16" filters or Trane is ok as well as Carrier systems)
Sep 19, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Have missed placed my manual need to know how to clean. Now that I have taken it apart I cannot get it back together! Help!
These units usually put out ozone into the air in your home which is a known lung irritant. Sometimes they will call it an ionizer or something like that. If you truly have indoor air quality issues the only way to properly attack it is through three steps
You can look up the Lennox Merv 16 filter it was rated #1 in Consumer Reports december 2007 as the best whole home air filter above the trane clean effects and others. can be bought and installed for around 400 bucks to 1000 dependeing on how hard it is and ask about the pure air system if you want higher levels.
Sep 17, 2009 | Bionaire Air Purifiers
Aran Aranizer need parts, company apear to be gone
www.royalairpurifiers.com this is a link to the new company.
Steve established a new company after Ted's death
May 07, 2009 | Aranizer SS-6 Air Purifier
The blue light on my ionic breeze is blinking.
The ionizers were recalled by Sharper Image due to a lawsuit that they lost forcing the company into chapter 11.
There is a thread on this website with further details.
Sep 13, 2008 | Sharper Image Professional Plus Ionic...
Lennox iComfort Wi-Fi Logo
123 people viewed this question
Top Lennox Air Purifiers Experts
Are you a Lennox Air Purifier Expert? Answer questions, earn points and help others
