Question about Toro Powerclear 221qe Electric Start Snowblower 38584
Toro power clear 180 snowblower leaking oil - Toro Powerclear 221qe Electric Start Snowblower 38584
5 Suggested Answers
  • 3 Answers
SOURCE: I have a toro 421 snowblower i filled it up today
it sounds like you had water in the crank case.
Stop running it immediately and drain all the oil. Then make sure the crank case is empty of oil and clean, and refill with fresh oil. After you fill it back up with oil, run it a minute and check again for any milky/foamy oil. If it is clean, check it again after several minutes. If it stays clean, you should be good. If it is milky again, take it for professional service, as you probably have a damaged gasket somewhere.
Posted on Dec 29, 2010
  • 31 Answers
SOURCE: cannot start Toro 1800 snowblower (electric)
Can you pull start it? If so,you may need a new starter gear,about $30,they're plastic & wear out.
Posted on Jan 12, 2011
Terry Corrow
  • 10875 Answers
SOURCE: What type of engine oil should I get for my 526 Toro snowblower
10w30
Posted on Jun 18, 2015
  • 44260 Answers
SOURCE: What type of gas and do I add oil to run A Toro Snowblower ccr 3650 65 hp?
there is no such snowblower made . 65 horse power is bigger than a small auto
Posted on Nov 13, 2015
I put a mixture of oil gas in my 621 R/621 toro snowblower?
Hi Jerome:
Shouldn't be too bad.
You could disconnect the fuel line at the carb and drain the tank.
Drain and flush the carb. Reconnect the fuel line and fill with fresh gas.
If it won't start, pull the spark plug and clean/dry it with a propane torch, or replace it.
Odds are it will be fine.
Cheers.
Jan 18, 2016 | Toro Power Clear 621 R Snowblower - 38451
Nov 12, 2015 | Toro Garden
Toro power clear 418 won't start
does it have good gas in it , clean it out if it is 2+2 mix put new mix most small snowblower are 2 stroke which takes gas oil mix , make sure you clean plug and are getting spark
Feb 18, 2014 | Toro Power Clear 418 ZE - Single Stage...
Toro snowblower troubleshooting
adjust the cable to accelator so it revs higher ,
Oct 27, 2013 | Toro Power Clear 621 R Snowblower - 38451
Oil leak toro recycler 6.5hp lawn mower
Sounds like the bushing is bad where the crank shaft comes out.
May 19, 2013 | Toro Garden
Toro Powerclear 221qe Electric Start Snowblower 38584 Logo
54 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
