Question about American Audio VMS4
Descargar el firmware de american audio vms4 edition 2
I have vms4 decks, when i play a tune on my right deck i get serious crackling noise out of my speakers and headphones...any advice please guys?
Have you tried isolating the problem, like switching cables from the left side that is not making noise? Also check connections,
I say this all the time and use all the time.... electronics spray contact cleaner, usually takes care of crackling noises
really hope this helps?
Mar 04, 2015 | American Audio VMS4
En el pa korg 500 de error aparece os lectura de archivos Que Se Puede HACER
Carlos Hi
despues de formatear el equipo todo tiene que volver como recibistes el pa 500 nuevo de fabrica
Mar 28, 2014 | Korg Pa800 Synthesizer
Http://music.yamaha.com/registration
soy usuario de un teclado yamaha y queria saber si me pueden enviar las partituras de iniciacion al teclado. gracias mi nombre es Pedro Guardia Berrueco. Mi direccion de E.MAIL: pguardia2@gmail.com. el modelo es psr-E223-YPT-220
Jun 05, 2012 | Music
I bought American DJ discolights with T20f control. I do have American Audio mixer and cd player CDI 300. 2 powered Mackie 450 speakers. How can I connect the stuff?
I can only give you some ground rules to follow: Connect ALL of the audio equipment to a single receptacle or power conditioner. This may mean running an extension cord back from where the speakers plug in to the mixer. Use BALANCED lines, either XLR or TRS to connect the speakers to the mixer. Power the lights separately. To give anymore suggestions would require a diagram of how your venue is laid out and the location of power, etc.
May 10, 2011 | American DJ T20f Chase Control Pack W/foot...
The Crossfader does not work. I just bought it. I don't think it's broken even though everything else works.
Exactly the same thing happened to me think they send them out like it so you get the info fader upgrade I took out the two screws popped the fader out it was cruded up so I sprayed contact cleaner in to it.Just to clarify you have it set up right if your using it just with software you need the in on chan 2 out on chan 3 on the front and make sure the curve is set right
Mar 28, 2011 | American DJ VMS4 Digital DJ Work Station
On powering up, the lexicons LCD display Audition light flashes for about 6-7 secs, then "21" appears then"UP". After this none of the buttons/Diald work-it just freezes. I have been...
hola tengo el mismo problema, me han dicho que actualizando el firmware de la lexicon mx200 se soluciona pero resulta que mi pc no reconoce el dispositivo via USB para actualizarlo, alguna solucion?? muchas gracias
Mar 18, 2011 | Lexicon Mx200 Reverb Delay 1u Effects...
Como para independisar el pedal derecho de la bateria ied04 y preciso el manual en español
Here is link:http://www.ionaudio.com/stuff/contentmgr/files/0/4af50da567710d08b72b6e0a34e84fa6/file/ied04_quickstart_guide_v2.pdf
Nov 15, 2010 | ION Audio iED04 Desktop Electronic Drum...
Lexicon Alpha got phantom?
The Lexicon Alpha does NOT have phantom power. The mic input expects a standard mic or a "self-powered" condensor mic. This means that you will neex external phantom power. There are power units available that use 9V batteries for this.
Dan
Sep 09, 2010 | Lexicon Alpha Personal Recording Studio
El transistor de poder de mi amplificador line 6 spider ii de 30 watths se quemo, quisiera saber el modelo del transistor para poder cambiarlo
If you want to know what the part number of the power amp in your unit is, it will be either a TDA2030 or TDA2050 which ia a 5 terminal audio amp of 14Watt or 32 Watt respectively.
Aug 11, 2010 | Line 6 Spider Iii 30
American Audio VMS4 Logo
41 people viewed this question
Top American Audio Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you an American Audio Music Expert? Answer questions, earn points and help others
