Question about Nintendo Wii Console
No TV Connectivity
My Wii turns on but I can't a picture on the TV. I have plugged it into 3 different AV jacks on the TV and no luck as well as tried it on another TV and still no luck. Why would the AV cable stop working as it is only 6 months old.
  • Anonymous Apr 24, 2009
    Same problem. Any help in fixing it?
  • 3 Answers
Because it is time to get a new wii
Posted on Apr 24, 2009
Have sound but no picture
Hi
First thing to go is try a different television and a different video cable if still no picture is displayed on television (screen is blank) You seem to have a problem with the video output from your nintendo wii.
NO PICTURE
1 Turn your television to the correct video input channel. For many televisions, you can press the "Input" button until you see the Wii start up screen.
2 Ensure the power cord is securely plugged into the DC jack on the Wii and the opposite end is plugged into a working electrical outlet. Press the "Power" button on the Wii and wait for the indicator light to turn blue.
3 Secure all of the Wii component cables to the "Video In" jacks on the television. In addition, make sure the opposite end of the wire is fully plugged into the Wii.
Dec 30, 2011 | Nintendo Wii Console
I just bought a Samsung UN22D5000 and I was trying to plug my Nintendo Wii into the tv. I was the Wii's three AV jacks plugged into the correct jacks from the tv and the tv on the only AV source but...
the hdtv you bought is not the right kind for avs and component cables.
yes, i know its a pice of **** now that i explained it. if you still can return
the tv get a different one like a panasonic or a sony anykind exept samsugcuz they r *******
Jul 25, 2011 | Samsung 22 UN22D5000 22 LCD TV
Trying to hook up a dvd and wii with direct tv and can"t get sound out of wii! HELP Can you show me where to plug cords in?
Your TV has two sets of AV inputs. One on the side and one at the back. The Wii has a 3RCA cable ( Yellow / Red & White ) . Connect these jacks to the corresponding color sockets on the side input of your TV. Select that input on the TV and your Wii sound and picture should come on.
For the DVD player you have to get a 5 RCA component cable. This cable will have 5 colored jacks, connect the White & Red to the Audio in of the TV and then connect the Red/Blue/Green jacks to the component video input of the TV.Do the same at the DVD's end also. Setect that source on the TV and you should hear the DVD sound and picture.bobhifi_31.jpg
Apr 03, 2011 | RCA L32HD41 LCD TV
I have a 32" flatscreen
Different video signals use different connections ...and we are speaking ONLY the video(NOT including the audio connections)
  • Composite Video (typically colored Yellow) uses 1 RCA connection on your TV
  • Svideo (uses 1 svideo connector on your TV) a circular connector with 4 pins in it
  • Component Video (typically colored Red/Green/Blue) uses 3 RCA connections on your TV
These are the common analog video signals....You cannot mix and match these and plug a composite (Sometimes called AV in menus) into component etc
If both your sources (wii/DVD) you want to use a component signal to your TV (which BTW is the best quality of the 3 I listed) you will need 2 component inputs on your TV
OR
run it through a high end receiver (that will act as your switcher)
OR
buy a small stand alone switcher, something like: http://www.amazon.com/4X1-HD-Component-Av-Selector/dp/B000BVIBGI/ref=pd_sim_sbs_e_4
settle for a lower quality DVD signal and use the Composite video out (yellow jack) into the Composite Video In on the TV and use the component for wii
I hope this helps,
Magoo
Mar 10, 2011 | LG 32LG30 32 in. LCD HDTV
I've plugged in the red, white, and yellow cables to my TV, and I'm getting sound but no picture. I've plugged in the cables the same way I successfully do for my Wii, but still get no picture. PLEASE...
There is probably a short in your av jacks somewhere, try going to a pawn shop or resale shop and getting some used av jacks off of another N64.
Nov 21, 2010 | Nintendo 64 Console
Wii help
Hello :
1:Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console.
2:
Insert the RCA plugs on the Wii AV Cable into the input connectors on the TV. Plug the colored connectors into the following inputs:
Yellow = Video Input
White = Audio Input Left (or Mono)
Red = Audio Input Right
3:Once the cables are inserted and the Wii is powered on, you must find the Input Select for your TV to view the game (it is likely not going to be seen on Channel 3 or 4). Typically this is found by pressing the TV/Video button on the Television's front panel or remote control. If you have more than one input channel, keep pressing TV/Video until you see the display from the Wii.
If you do not have a TV/Video button, then the input could be labeled something different. Some other common input selects to look for on the TV or remote are: Input, Input Select, EXT, AUX, or a channel such as 00 or 99.
I hope this will help .
Mar 23, 2010 | Nintendo Wii Console
I have a new LG SL90 television. I also have a
If you do not have a scart socket available on the tv you need to get a wii component cable that contains the six input jacks. HD tv's tend to have these inputs on the back, you have the normal red, white and yellow jacks plus another red green and blue you'll need to plug in from the component cable. If you have an AV input with just red, white and yellow you can remove the scart adapter from the normal wii av cable and plug the separate jacks into that too.
Dec 31, 2009 | Video Game Consoles & Games
Setting up my wii with my trutech tv
The Wii comes with standard AV jacks. Look for the female plug ends on your television that match the colors of the Wii's AV jacks, red, yellow, and white. Plug them in. Turn on TV and Wii. Use the input function of the TV to select the AV input (usually says "game", "video", or "input"). Play Wii.
Dec 16, 2009 | Televison & Video
No picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Mar 19, 2009 | Yamaha RX-V800 Receiver
Connecting my WII
Connecting a Wii is simple, to connect first Plug your Wii into a wall power outlet, the plug the AV or three pronged jack into the corresponding colors in the back of the TV, Next plug in the Wii sensor bar to the back of the Wii Console and mount the sensor bar on top of the Television. Turn the power on to your Wii and connect your Wii-motes. Enjoy!
Feb 16, 2008 | Video Game Consoles & Games
Nintendo Wii Console Logo
118 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
