Question about Bryant 462AJC021BA Air Conditioner
Fan runs but condesor not running
This has been going on since nov. I have a home warranty on this and they came out change run capasitor, voltage circut board, compressor run booster. then found leak in evaporator,changed evaportor. the unit runs for about 1 hour then cuts off. the inside fan runs but the condesor stops working. if i wait several hours the same thing happens. the service repair man said pressures are just fine but not sure what the problem is.
  • 3 Answers
1. First refill the gas. Gas seems to be overcharged than the recommended value. If the gas is OK
Than,
2. There is an overload in the compressor, when it takes more then recommended amperes of current overload shuts the compressor.
Than need to change the compressor.
Posted on Apr 24, 2009
What would cause of the Air Conditioner to stop working when there is power to the house?
Check voltage at fan motor if no voltage check cap if no voltage check power supply if you have power then change the capasitor its your cheapest and most likely problem if not change fan motor. Before you do any of that your contactor is where your voltage comes in make sure the contactor is made or on in the center of thecontactor there is a button or a plastic cover over the center push the contactor in if all comes on check your low voltagethe yellow wires on the sside of contactor if you have power there change contactor
Jul 20, 2014 | Heating & Cooling
Behringer xenyx 1222fx mixer capasitor
check the capacitor and its value and type. i havent see the equipment but knows about capacitors etc
it usually comes in values like 0.01 2.0022 and so on and higher value like 1 mfd to couple of thousand mfd.you shouls use the same value and the voltage for the replacement one has to be same or more in voltage since higher voltage is no harm but lower voltage will explode or burn in electrical appliances it is used as filters to block spark in the carbon or starting capacitor thich helps to run the motor if it is built to run with a starting capacitor like the one used in water pumps or electrical ceiling fans.
Aug 29, 2012 | Cars & Trucks
Reverse rotatin on fan motor aire flo air conditoning model #20402077insol knew capasitor 3 tipe capasitor capasitor /hern/fan/c/
When the capacitor goes bad it can cause the fan motor to run backwards, the capacitor needs replaced.
Sep 24, 2011 | Carrier 38CKC036 Air Conditioner
I recently rebuilt the front end of a 2000 camry 2.2liter, we replaced the radiator, a/c condesor and the a/c fan. But it seem both fans only run when the a/c is on and neither run when its off. Please...
it sounds like your temp sensor switch is bad both fans will run with ac on it needs to cool radiator and condenser with it off the temp sencer switch takes over hope this helps good luck bob
Apr 24, 2011 | 2000 Toyota Camry
Motor wont start but runs without the belt on
replace the new capasitor,the capasitor is placing near the motor,unplug the unit before remove it and be carefull to touch the pin of the capasitor coz of high voltage,check the micro farad of capasitor and buy a new one,,but sometime the motor also problem if the motor have water mark is means replace the motor of new one,but ask the price of new one if is expensive try to buy a new one with 1warranty compare the motor you buy is only 1month warranty.
Dec 24, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My GE fridge GSS25JFMD: freezer seems to be working but the fridge compartment is worm, I don't see any cold air flow from the top. Condesor on thr back is very hot and cooling fan doesn't turn on. I...
The control to the fan comes from the main unit and it runs all the time,. So check out the wiring for the voltage to appear on the fan terminals , there can be break of contact in joints of wire connectors.
Once the fan works the fault must clear off with the cold air blowing.
Sep 19, 2010 | GE Refrigerators
1997 Hyundai Elantra: Does the smaller radiator fan run all the time or only when a/c is on?
If you look one of the fans will be behind the radiator and the other will be behind the A/C condesor. The A/C condesor fan should run as long as the A/C is on. The radiator fan will cycle on and off as the temperature sensor tells it too.
Hope this helps.
Aug 26, 2010 | 1997 Hyundai Elantra
Center wall between freezer and refrigerator is hot along the edge in front.
firrst thing you do is check for dirt or clear condesor use a vaccuum and clean condensor blow out any debris you should see a change almost instantly as long as fan is working dirt build up is most likely problem especialy in summer weather
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My picture is really snowy
Capasitors on the power suply are failing or they have a cold solder joint. Take the back cover off and run a fan on the power suply to see if this problem stops. If it does the run smaller fans to track down the bad capasitor. There durt cheap to replace!
Jan 22, 2008 | Televison & Video
Bryant 462AJC021BA Air Conditioner Logo
144 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
