My samsung HLS6168WX/XAA tv keeps turning off after a few minutes. it makes a weird noise than then shuts off. then the 3 lights continually blink. I've replaced the lam, cleaned out the dust and tried using a fan behind the tv. the picture is perfect when the is tv is on. please help
5 Suggested Answers
SOURCE: Tv shuts itself off
Look for the computer processor inside the TV. It needs to be cleaned. A can of compressed air will work. The processor is overheating and causing the tv to shut off. Look for the small fan that is supposed to keep the processor cool then remove the dust.
Posted on Jun 09, 2009
SOURCE: blinking lights on HLT5075SX/XAA samsung
Manual says you need to replace the lamp: When do I need to replace it?
• It should be replaced when the screen becomes darker, less clear or when all three LEDs on the front (STAND BY/TEMP, LAMP, and
TIMER) are flashing
imgadgetman
Posted on Apr 22, 2010
SOURCE: Samsung hln617w dlp tv won't turn on. Red temp
Had similar problem. Thought it was the lamp. Examined old lamp but it appeared to be good. Ordered a new one anyway. Changed the lamp but the TV screen would not come on. It would make the usual noise as it was going to come on normally but it would cycle 3 times & then turn off. The LED lights in the front panel would indicate a defective lamp. Then read about the ballast. Changed the ballast & still same problem. Tried starting the TV without the lamp installed & noticed that the color wheel did not spin. Removed old color wheel & discovered it was broken. This appears to be the cause of all of my problems. I wish I new earlier of the test-turn on the TV without the lamp being installed & check to see if the color wheel is spinning. Would have save money on the lamp & ballast.
Posted on May 03, 2010
MNfisherman
  • 11896 Answers
SOURCE: TV wont turn on
a bad power supply is most likely cause of this. Other possible cause is bad main circuit board.
Testimonial: "Thank you so much! I will diffently look into this... I'm gonna keep my fingers crossed!! ;)"
Samsung DLP HLN5065WX/XAA
that's from a thermal switch, to keep the innards cool, post use. Seems to me that you might just check to see that all vents are open and clear of debris, for starters.
May 07, 2008 | Televison & Video
Why is my Samsung RF26XAERS refrigerator repetitively chiming, and how can I fix it?
NOISE? from the fridge inside? or from the outside compressor? In overstressed compressor or low freon level will make weird noises? a bad fan in freezer will? Even seen bad ice makers make weird noises? if the ice making is hindered by obstructions?
Aug 20, 2014 | Samsung RF26XAERS 26 Cu. ft. French Door...
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Samsung HLS5087WX/XAA DPL shuts down after 30 - 60 seconds, 3 blinking lights
I beleive from what you have told me that most likely it is just a lamp issue, there are a lot of so called original equipment lamps and counterfit lamps on the market that will barely give you 1000 hours run time. When it comes to Television lamps cheeper is not better. Make certain to buy an original Samsung lamp, you should get about 3500 to 4000 hours from it. If you need further assistance or have questions please reply to continue.
Jul 27, 2012 | Samsung Televison & Video
I have a Samsung 42 inch projection tv that will only stay on for a few minutes. When it shuts off the front on/off button flashes. It is a model HLS4666WX/XAA version PB02.
Google your make and model and add flash codes to the end. The blinking light is a self diagnostic tool for service. Count the number of flashes and look it up on the website that comes up.
Sep 04, 2011 | Samsung Televison & Video
Samsung lns4041dx/xaa tv takes a long time to turn on the red LED light blinks 3 times then disappears - then LED light comes on again repeats the process for about 7 - 10 minutes then the TV turns on. ...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 31, 2017 | Televison & Video
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
