Question about Ovens
Where is the exhaust fan located for a Baxter Model M800 Oven? And, can it be replaced with a larger fan?
  • Neal Dominick
    Neal Dominick Oct 17, 2013
    The M800 is a rotating rack oven and appears to have been constructed circa 1980's. Thus, any assistance or information provided will be greatly appreciated. The oven does have an 8" dia. exhaust duct that routes exhaust to a roof vent. Thus, I'm presuming the EF is within the "hood section" of the oven. Please help.
My oven is loosing temperature
To me it sounds like the heating element is starting to go, I would suggest that you replace that and see how it go there after.
Feb 10, 2012 | Ovens
I have a problem with a Baxter OV300g Oven. The Automatic Ignition System keeps Flashing 1-flash Air flow problem, can you help me with this. Thank you.
Check to see if your draft inducer (exhaust fan) is running, if it is then you could have a dirty/bad air switch, the component with the small black hose running to it and the two wires on the face. To check an air switch using a multi-meter set it to 40 VAC and place a lead on each terminal, if you are getting a voltage reading over 1 volt, replace the air switch, if you have zero volts, the air switch is closed and working. Aside from a bad exhaust motor or air switch there could be many things causing that error.
Jul 30, 2011 | Baxter OV300E Stainless Steel Electric...
Wich is the power supply 120v, 208 1 phasse or 208v 3 phase.
Most Baxter BXA ovens have separate power supplies, usually 120v for the controls and lights, a 120v output on a circuit breaker for the roof fan, and a 208VAC 3 phase supply for your convection motor. Older Baxter ovens may have a 3 phase service disconnect inside the electrical/burner compartment, if I recall correctly the BXA models do not and the only way to shut it off is via the 3 pole breaker at the service panel.
Feb 04, 2011 | Baxter BXA2G Stainless Steel Gas Single...
Water coming out oven no steam and it will not get to tempeture
If your oven isn't reaching temperature you will not get steam. Turn the oven on and verify that the oven is calling for heat by looking in the temperature window next to the arrow that says "heat" or "on," if the set temperature is 5 degrees higher than the actual temperature there should be a small red dot next to the arrow. Then observe the burner, does the exhaust fan come on, can you see the ignitor glowing, does the burner light, does it stay lit or go out after 4 seconds? You could have a dirty flame sensor, the small rod with a wire attached to it at the top of the burner, remove the flame sensor and clean it with a cloth, wire brush, or emory cloth.
Jan 02, 2011 | Baxter OV300E Stainless Steel Electric...
I have a Baxter oven OV210G, When the door is open the rack will not stop or lower. The micro switches all work and relays seem to work but I can't find the MR3 cantactor and don't if that is the problem...
When you open the door check to see if your burner and circulation fan remain on, if they do you have an issue with your door switch.
Also if your rotation micro-switch was bad you would get a buzzer every 1 second because the oven would think the carrier isn't rotating.
It's hard to troubleshoot beyond that without seeing the oven, its possible you could have a bad relay on your control board. In this case I would call an authorized service provider to have to check the oven out.
Dec 07, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Need to set clock for daylight time on baxter oven ov300e
With the oven on hold the time up or down arrows until the time begins to change.
Nov 07, 2010 | Baxter OV300E Stainless Steel Electric...
Were is located the thermostate
The thermostat is solid state, it is incorporated into the control board. You can however locate the temperature probe which goes into the left side of the back of the control board and goes into the top of the oven under a cover near the air pressure switch and high limit thermostat. To locate follow the small aluminum tube coming from your exhaust stack, that will lead you to the air switch which is next to where the temperature probe enters the heat exchanger compartment.
Oct 07, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Serial Number location
EITHER TOP LEFT CORNER OF OVEN< or UNDER PANAL take off the one screw panel opens right upo like door, Right there!!
Jul 12, 2010 | Baxter OV300E Stainless Steel Electric...
When we turn the switch on, the light inside the oven goes on, but the touch pad does not come on, it comes on by itself after a while, or will shut off in the middle of cooking.
Control board defective. Before replacing the control board make sure that your incoming water pressure is no higher than 20 psi and that your door gaskets and fan seal is intact. Torn gaskets or a worn fan seal will allow steam to enter the burner compartment and damage your control board.
Sep 12, 2009 | Baxter OV300E Stainless Steel Electric...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
