Question about Husqvarna Fuel Cap Fits 145bt 145bf 155bt 165bt Blower 55017 Lk
145bt leaks gas - Husqvarna Fuel Cap Fits 145bt 145bf 155bt 165bt Blower 55017 Lk
Came down stairs water heater off and pan filled with water
Copy following link for troubleshooting leaking water heater.
http://waterheatertimer.org/Leaking-water-heater.html
You posted question under propane gas heater.
Propane is heavier and air, and this type gas water heater should not be installed in basement (below grade) since gas leak can fill basement with explosive gas.
Water leak does not cause gas leak, so water leak is separate problem.
Recommended for propane safety: install gas detector close to floor near gas water heater
Regular Natural Gas heater, install gas detector higher on wall since NG is lighter than air and will rise.
Aug 04, 2012 | Whirlpool 40-Gallon 6-Year Gas Water...
I have a Pinguino PAC 190 floor model that blinks PF what does that mean?
PF- error code means shor of gas/gas leak. It's not advisable to charge gas without finding out the leak.
To find out leak, remove all gas and then charge Nitrogen pressure up-to 300 PSI and then with soap solution or leak detector element you can find the leak. Arrest the leak by brazing/welding, Again pressurize with nitrogen to confirm no more leak. And then vacumize and do gas charging.
Dec 14, 2010 | DeLonghi Heating & Cooling
My 145bt blower wont stay running. And we also have trouble starting it. What do we check first? Has plenty of fuel. Husqvana brand backpack style.
Your first inclination should be looking towards the carburetor clean and rebuild it. Good Luck...
Nov 18, 2010 | Garden
What is the gas to oil ratio for the husqvarna 145 bt
50:1
http://ubermanuals.com/product/husqvarna-145bt-9074
Oct 25, 2010 | Homelite 'Yard Broom' Leaf Blower
Gas smell when oven is on and heating.
This sounds like a gas leak at the gas control valve for the oven, probably somewhere just past the control valve. If the leak was before the valve, you would either hear or smell gas leaking all the time.
The line could simply be loose at the fitting or the gas valve could be faulty. You could also have a leak somewhere at or before the oven burner assembly.
At any rate, this condition can be dangerous. The oven gas leak (any gas leak) should be diagnosed by a competent technician and the cause(s) of the gas leak determined as soon as possible and corrected.
Jan 13, 2010 | GE Profile JGSP48 Gas Kitchen Range
Husqvarna 145bt my gas line has come loose from the gas tank?
Hello etatum1634:
This File should Help.
The Following is a Basic Instruction File I made for Replacing the Fuel Lines and the Filter on Chain Saws and Trimmers. Any Input is Appreciated.
>>The Fuel Line is Pushed and Pulled (I Use Long Needle Nose Pliers) Through the Small Hole Until the Hose is Out the Fill Hole about a 1/2".
>>You can Also Use a Coat Hanger with a Small J at the End to Hook the Filter in the Tank and Pull the Filter and Hose (if Detached from the Carburetor) Out the Tank Fill Hole Enough to Replace the Filter.
>>Then Attach the Filter and Pull the Hose Back Until the Filter Lays at the Bottom of the Tank Just Below the Fill Hole (or so it is in the Bottom of the Tank and will Rest in the Fuel Mix when Turned at Common Angles the Unit May be Turned to During Operation.
>>**Hint: Use Plenty of Spray Lubrication at the Small Hole as you are Feeding in the Hose. It Slides Easier.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Apr 24, 2009 | Homelite 'Yard Broom' Leaf Blower
Gas leak in my GE profile JGP336
Contact your local gas company and turn off the gas to the unit.
May 01, 2017 | GE 30 in.Profile JGP940 Gas Cooktop
Gas leaking from carb
You have a stuck float in the carb.
Jan 11, 2009 | 2006 Husqvarna TE 250
Husqvarna 145BT gas blower with a gas leak. this is at random some times it leaks from the bottom right down my lower back. Some times it doesn't leak at all. Not to sure where leak is coming from.
I own the 145BT.
Mine will leak when one of the two tubes (one black and one yellow in the picture) that come out of the gas tank pull out. I find this is usually when someone hits them when priming the carburetor, just before starting it. I just push either the black or yellow tube back into the black rubber gasket on top of the fuel tank. The gasket is pretty tight so it sometimes takes a bit of effort.
More than once I had quite a bit of gas on my clothes by not making sure they were pushed in completely, before putting it on my back to start blowing.
The tubes should probably be a bit longer -or may have shrank a bit over time.
Nov 05, 2008 | Homelite 'Yard Broom' Leaf Blower
Husky 350 leaking gas from white plug in gas tank
I have a rancher 55 and it was leaking gas, i replaced the gas cap. That solved the problem.
Sep 30, 2008 | Garden
Husqvarna Fuel Cap Fits 145bt 145bf 155bt 165bt Blower 55017 Lk Logo
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
