Question about Dryers
Maytag lde5005ace The drum spins but but won't automatically stop and there is no heat. What is wrong?
    Novelist:
    Scholar:
  • 100 Answers
There is a NO WRINKLE mode that will not let the dryer stop until the door is opened. Try using the dryer with this mode not included. It is a great mode offered, but it can also be irritating..
kindly,
Jim
Posted on Oct 20, 2013
TheMobilian
  • 8220 Answers
SOURCE: maytag performa runs no heat how do I access the heating element?
Well if it runs then the fuse is ok so what you need to do is pop the top and check the high limit thermostst and heating element located at the rear of the machine. The top on most of these machines comes up easilty if you use a putty knife or five in one. Be sure to disconect the power source. a12fee1.jpg
Posted on Jan 19, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag Atlantis dryer drum not
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Oct 28, 2010
  • 254 Answers
SOURCE: In my Maytag dryer model
This sounds like the drum's drive belt broke. But also ensure there isn't a problem with the drive motor. Do you still hear a motor running when you turn it on? If so, you'll need to replace the drive belt.
I hope this helps! :)
Posted on Dec 15, 2010
hunter19_46m
  • 7482 Answers
SOURCE: how do i replace the
Hi idbond928...
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vasoline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
This is a FREE answer, Please take time to rate me
Posted on Jun 02, 2011
  • 22 Answers
SOURCE: my maytag epic z dryer won't spin
Check the thermostat of your dryer first. If this does not work out, then please visit Clothes Dryer Element.
Posted on Oct 25, 2012
Model lde8414ace maytag dryer
There is something causing the drive motor to bog down. This means the fan isnt spinning fast enough and the whole unit is overheating. Check for anything around the edges of the drum, coins keys etc. The squeal is the belt from the drum being stuck. See how hard it is to turn by hand.
Jul 08, 2013 | Dryers
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
I just replaced a broken belt on a Maytag dryer Model LDE5005ACE and now have no power. Checked breakers and power...no problems there. I did break the door sensor, but since it is just an open/close...
the door sw is probably your problem then. it needs to be closed to operate but should open with door to stop dryer. also check if belt switch, it is not pressed.
May 02, 2009 | Maytag Dryers
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave ww.washermd.com
Dec 16, 2008 | Maytag Dryers
Dryer not spinning
ok this sounds simple
if the dryer stopped spining there are 4 things to look at
1 the belt for dryer if this snapped the drum will stop spining
2 the dryer wheels these ware down and break off this is what helps keep dryer in a spin straight
3 this is the crucial one the motor siezed up from lack of appliance oil not being added to a regular maintenance
4 the guages has stopped working but i doubt this if it still keeps a timer going round this would not be it you dont have to run dryer to test guages just set guage to a time and see if it rotates with the time on it
the belt you can check your self by pulling down the dryer pan that will show bottom of dryer with belt if its a belt simple maytag can come out and do a replacement and maintenance on the spot
i hope this helped seeing im not there to actually see in person whats actually wrong
May 17, 2008 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
56 people viewed this question
Top Dryers Experts
