Question about Ducane 30400042 (LP)
Convert gas grill natural
Actually I have a Ducaine 30400043 NG grill and would like to know exactly what parts need to be exchanged to convert it to LP. Ducaine says there is NO conversion kits. Could I buy a 42 LP 5 burner gas valve and use it in place of the NG valve.
    Scholar:
    New Friend:
  • 80 Answers
Ducane will not make these available anymore because the ducane family no longer owns the company and the models since 2007 are all made in china with poor quality controls. conversions are simple but the parts will not come through ducane or weber. replace the orifice in the tip of every control valve and replace the regulator. that is the only difference in fuel types.
Posted on Nov 07, 2013
3 Suggested Answers
SOURCE: how to convert from lp to ng
Yes,
I converted a Sam's Club Members Mark grille last year and just did some research on the internet and found a numbered drill size chart that gave me the correct drill size to use on each burner(side,main and rear)for the proper BTU supply for the size or BTU rating for your burner. I drilled them, All has worked well! I know Ducane will tell you not to do that, but I think it is a legal issue. If you have a problem, they don't to get a letter from your lawyer.
Posted on May 13, 2008
redbeard00
  • 957 Answers
SOURCE: Can I convert my MDBQ-30 NG grill to LP Gas
yesL contact your local propain provider and/or plumbing supply Co. They need to see the valve and they will let you if they can convert it or not. If not they will sell you an L.P. style valve.
Posted on Apr 25, 2009
How do I convert from liquid propane to natural gas
You need parts from the manufacturer. The gas orifices are different sizes between natural gas and LP gas. If you try natural gas with an LP gas orifice, you will not get much flame. If you use LP gas with a natural gas orifice, you will burn off your eyebrows and possibly other things.
Dec 19, 2013 | Capital Cooking Titanium X CCE26XRBI (NG)...
Parts gl38lkec
call me. converting a barbecue is simple; the kind of job a tech will get while still in training. The LP hole is smaller than the NG becuse of mass and air-mixture in NG so the orifices have to be plugged and re-drilled or replaced with new LP orifices.
Nov 07, 2013 | Sunbeam Grill Series 550
Can I convert a NG Vermont Castings BBQ to Propane. moving and new house has no NG available. Model SCS 5005.
Unfortunately, Peter, for safety reasons, VC grills are not approved to be converted from one gas type to another. Each grill is manufactured, tested and approved for it's specific gas type. Converting it from LP to Natural Gas places all the liability on you, if something should go wrong as a result of the conversion. Further, you would notice a significant change in the heating ability and the lower flame height, when set on high. The reason for this, is that LP Gas burns cleaner and hotter than Natural Gas in an outdoor environment.
I know you would be happy not having to refill the tank, but I think you would really disappointed in the performance of the grill, if converted to Natural Gas.
I hope this helps you and Happy Grilling!! Thanks for choosing FixYa.
Sep 15, 2011 | Weber Grilling
Want to convert my Capt N Cook barbeque from propane to gas. Have the gas line already to hook up to barbeque but need to know what parts I need to replace and add to accomplish this Thanks
You need Natural Gas Burner orifices and perhaps, a new manifold.Also, a 12' long rubber quick disconnect hose (that's a Code Requirement) and all the necessary fittings. Contact your local BBQ Galore for the parts you need.
May 15, 2011 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
I need to convert my Weber Genesis Silver B grill from Natural gas(NG) to Propane (LP). It is as simple as replacing the NG manifold and valve assemble with the NG one BUT Weber wont sell it to me...
I would contact a propane distributor, They should be able to locate the part. I don't know where your at but the one in my area (Central Oregon is Ed Staub and Sons )
Nov 22, 2010 | Weber Genesis Silver B Grill
I need to convert a weber nat. gas grill to propane and i can not find the kit, can you help?
OK - you may not like this answer, but it is what is is :^)
Its common to find kits that convert propane to natural gas (NG) but not the other way around. This is because NG has less energy per square foot than propane, therefore, the holes in your NG grill controls and burners will be bigger to move more gas and get the BTU's you need.
When you convert from propane to NG, you can simply drill the holes bigger and remove the regulator. But the reverse is not practical because you can't make the holes in a NG grill smaller without buying all new burners and control knobs. I guess that's the bottom line - your "kit" is simply to replace the burners and controls with propane-specific parts. You might be better off to just buy a new grill by the time you go through all that. If you have a Weber, their web site has all the manuals and part numbers you would need.
Keep in mind that propane tanks are under higher pressure and you MUST have a regulator. I've heard of some people that simply slap a regulator on their NG grill, but you will not get even burning or proper performance (again because the holes will be too big). In my opinion, it's simply not worth the danger to you or your family.
Aug 07, 2010 | Weber Genesis Silver B Grill
I am looking to convert from natural gas to propen gas for weber s-620
Weber does not sell conversion kits due to liability reasons. Every part of the grill needs to be changed to convert. Cheaper to buy new grill, I have tried to piece together a parts list to convert, it is cheaper to buy new grill by the time you purchase all parts needed.
Mar 30, 2010 | Weber S-420 (NG)
Converting Weber from LP to Natural Gas
On the weber model you need to purchase the natural gas model. It will cost you alot more to buy all parts needed to convert. Weber doesnt want you to convert do to safety reasons. This is why they will only tell you you can't convert. Buy the right grill and save yourself a headache.
Jan 19, 2010 | Weber S-420 (NG)
Conversion kit for Weber Summit LP to Natural Gas
Hi, you can purchase your kit at amazon, click here and take a look: Amazon com weber grill conversion kit to natural gas. I hope this was helpful. Cheers
May 31, 2009 | Weber S-420 (NG)
Ducane 30400042 (LP) Logo
134 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
