Question about JVC HD-56G886 56" Rear Projection HDTV
Red light blinking rapidly...no picture
I have an HD-56G866 the just developed this issue: No picture while watching TV. Blue power light stayed on, no noises other than what was playing through the receiver. Can't hear the cooling fan like I normally do when I get up to check the TV. Turn TV off, turn it back on. Blue power light goes off after a few seconds and red light blinks rapidly. Nothing turning on (no cooling fan as normal). No picture. No abnormal smells coming from TV (doesn't smell like anything electrical burned up). Thanks
  • New2HDTV Feb 14, 2008
    I just bought a reconditioned JVC HD-56G866 with the same problem. Is this a recurring problem for JVC? I need to return this thing soon if it is a lemon.
    Problem Solver:
Gentlemen, I have seen people with this problem and it requires the replacement of the light engine, search AVS Forum, for more information. Understand it is not cheap, hope you have ext warn.
Posted on Feb 20, 2008
SOURCE:
How do I remove the speaker box from my JVC HD 56G866 tv?
UNPLUG THE TV. then remove the back & you should be able to see up to the speakers.
Jul 23, 2014 | JVC HD-52G886 52" Rear Projection HDTV
My viore 32'' hd lcd lc32vh70 has sound but no picture just blue screen
Is this problem occurring while watching any channel or while playing any DVD?
Oct 30, 2012 | Toymax Viore 42 in. Plasma TV
Hey i just bought a new sony bravia hd lcd internet tv. and ever since like a month ago the screen would go blank and the volume would go out. the screen would only go out for a few seconds but its enough...
Tv it is having a problems,it is developing a power surges to their eclectronic boards.If this tv have this problems like 2 or 3 times black out in a couple hours of tv watching?Yes.This is a brand new tv?Yes,it should be return to the place where it was bought right away to exchange it for another tv,because this problems,will develope in to a bigger problems.The tv Tuner signal board,will evenually will dies completey.After tv life in usage for awhile more.Ur tv evenually get power only, indication LED power light up only,but no tv incomming broadcasting picture to tv at all.
Apr 17, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Phillips 55" rear projection HD ready --power button lights up, but no picture or sound--just a clicking noise. Also, we can no longer adjust the blue convergence. The adjustment screen comes up, but we...
Got our tv in 2004 and we're having the exact same problem. When the blue convergence started going a couple months ago my husband researched the heck out of it and decided it would cost less to just replace the tv with a newer, nicer model rather than repair it. And now, as of last night, we are having the same power issue where the power button goes on, but won't stay on. It just clicks on and off and no sound or picture. Did you ever get yours fixed, or did you end up replacing?
Oct 15, 2010 | Philips 55PP9352 55" Projection Television
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
It seems that my westignhouse hd lcd tv gets too hot and starts showing blue patches ; mostly where it should be white.
have the same prob! Seems to get too hot then the pictures goes to hell and colors are jumbled up everywhere on the screen! turn it off for a while and let it cool down then it plays fine til it gets too hot again! i put a fan in the back of the tv and turn it on while i watch and it stays on with no probs! its DEFINTIELY a heat issue
May 17, 2009 | Westinghouse SK-32H240S Television
TV Not turning on , but blue power light is on
look in the back, see if the lamp is actually lit. If it is probably not a tv problem. If you can pull up the menu then you probably are on the wrong input. Are the fans running when you turn it on? IF fans are running might be lamp, if nothing is seen through the back.
Apr 29, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Our 52" widescreen LCD TV just quit working.
This set uses a lamp ( not picture tubes ) The part # is TS-CL110U. Almost certainly it is bad. They are easily obtainable and you can easily change it yourself.
Apr 09, 2009 | JVC HD-52G787 52" Projection Television
Picture goes blank but audio on
If you are using component cables to connect your HD box to TV. Make sure your connections are tight. You should make the colors match up. Green, Red, Blue. Check on both TV and HD box. Make sure HD pox is powered on. Make sure to select TV input to Component 1 or whichever you are using. If this doesn't work you may need to call and have COX refresh the HD box. This can be done over the phone. This will make sure you are receiving and sending the proper signal level. Good luck
Oct 05, 2008 | Vizio L30WGU 30 in. HD-Ready LCD...
JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
Dec 19, 2006 | JVC PD-42WX84 42 in. HD-Ready Plasma...
JVC HD-56G886 56" Rear Projection HDTV Logo
377 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
