Compaq q1859 monitor
I JUST bought a Windows 7 Dell computer and DESPITE adjusting the suggested whatever to NEVER TO SLEEP, my monitor is CONSTANTLY going to sleep while I am playing a game on it; with my XP Pro Dell computer, this issue NEVER arose. How do I STOP my monitor from going to sleep?
    Scholar:
  • 106 Answers
Hmmm, sleep/suspend mode is only supposed to happen when it doesn't sense any movement from the mouse, it also shouldn't suspend if you are in full-screen either. So if you are playing a game that shouldn't happen at all... as a test you should put the "turn off the display" to "never" and see if it still happens.
I have this happen when watching Netflix, if I don't move the mouse my TV will go into suspend mode, even though I am in full screen... I think my issue however is related to the fact that I am using HDMI to connect to my TV from my computer... I have not solved this issue yet!
Posted on Oct 16, 2013
Testimonial: "Both my monitor and computer have already been set up with the NEVER sleep mode as I earlier stated."
hughv
  • 196 Answers
SOURCE: Dell E-1705 Motherboard Replacement
Start by checking ControlPanel/System/Hardware/Device Manager. Look for yellow marks that indicate devices not installed properly. This is usually a driver issue, and Dell should have given you a disk with the drivers you need.
Are you getting any error messages?
Posted on Oct 24, 2007
chiplevel
  • 656 Answers
SOURCE: KT4AV XP STARTUP PROBLEMS
check the power to ur hard disk it might not be connected properly
Posted on Nov 30, 2007
SOURCE: Compaq Presario SG3430IL Desktop PC display does not work with windows xp sp2 and vista
Kindly get me the drivers as i have installed xp in my compaq system. and i want drivers for that
Posted on Sep 24, 2008
SOURCE: my pc fails to go to "sleep mode".
Remove USB's or turn off media sharing.
Posted on Apr 05, 2009
SOURCE: computer wont turn off completely, nor sleep or hybernate
I had this same problem, I ended up fixing it by disabling the USB mouse support. Go figure?
Posted on Jan 12, 2010
My Dell Inspiron notebook keep turning display off and then go to sleep later.
Go into the Windows Control panel, then to power settings. There you can adjust the settings for the monitor sleep behavior, as well as computer sleep and hibernation.
There are seperate settings for while plugged into power and while on battery.
If you have trouble, just let me know which operating system (XP, Vista, Win7, etc) you are running and I will give you step by step instructions.
Hope this helps you,
-Ben
Sep 20, 2011 | Dell E193FP 19" LCD Monitor
Compaq q1859 monitor is pixeling
adjust resolution to 1366 x 768 will be good
Mar 31, 2011 | Computers & Internet
My Dell monitor goes to sleep right after windows xp starts to load and it won't come on after that. my computer is still running but the monitor is a sleep. I have hit f8 and f12 with nothing happening....
Go into safe mode
Under settings, control panel, power options set "turn off monitor to never
reboot
I think this is not a sleep problem but the incorrect monitor settings were set. This will cause the screen to go black when the OS comes up. Boot in safe mode and change the display settings
to 640x480
OR
in safe mode, delete your monitor. When you reboot it will load a default monitor and you should be OK
Oct 13, 2010 | Dell XPS 410 PC Desktop
Monitor wont come out of sleep mode
One possiblility will be the failing power supply due to bad caps (leaking/bulging tops). You can take a look inside first before making the decison to buy a new one or not.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
May 16, 2010 | HP Q1859 18 inch Monitor
Monitor keeps going into sleep mode and it won't turn on so i can use it.
Monitors go to SLEEP mode when there is no computer signal coming into them. As soon as a computer signal reaches the monitor, it will automatically wake up and show the images in the screen.
Mar 27, 2010 | HP Compaq FP5315 15" LCD Monitor
Monitor goes into sleep mode after a few seconds
This is normaly cause by incorrect power management settings.
check power management setting in both windows and your computers bios
you will not need to worry about the power management settings of the bios when an operating system such as windows is loaded.
Loch Hiam
Az.
Sep 18, 2008 | HP Pavilion a620n (PC028A) PC Desktop
Wont work with new computer
Since this was a new out of the box computer, Safe Mode was not allowed. In order to change monitor settings (resolution), I had to use another monitor, in this case a newer CRT. With the CRT, the computer booted up, no problem. Once booted, I turned down the monitor resolution and saved. Now when the Princeton LCD was plugged in and the computer restarted, everything works fine. Now the resolution could be set to limits of the monitor.
Aug 19, 2008 | Princeton Digital VL173 Monitor
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
