Question about PANDIGITAL PANSCN09 Handheld Wand Scanner w/Feeder Doc Station & 2GB
I bought a refurbished PANSCN09 and am having problems with the scanner scanning by itself. It works fine on the dock, but acts like the batteries are not connecting securely. It turns on and might scan once sometimes and then gives a battery low and shuts off. Sometimes it turns on and immediately turns off. Any suggestions?
  • pdelventhal Oct 18, 2013
    This scanner works fine when setting on the dock. When I try to use the scanner by itself is when the problems start. It seems to be connected to a battery problem, but the batteries are well seated and have a visual good connection. It seems like there is a short circuit of some kind.
2 Suggested Answers
  • 652 Answers
SOURCE: I have a Pandigital scanner model panscn09 that will not scan photos. I don't know what to check
check this
Posted on Dec 23, 2016
Panscn10rd manual
Not enough information . Is it a usb type cable that recharges the wand ?
What voltage is your electricity supply this is extremely important as I blew up a printer I purchased on the internet as US uses 110v and Aus uses 240V AC. I found Amazon has a product that might be what you are looking for but find out what AC voltage and country it runs on before even thinking about purchasing it.
http://www.amazon.com/UpBright%C2%AE-Pandigital-PANSCN08-PANSCN09-PANSCN10/dp/B00IB3A99K
Apr 23, 2014 | PANDIGITAL PANSCN09 Handheld Wand Scanner...
My Wasp wws-800 works while in the docking station but not when removed, suspect li-ion battery but have not been able to find a replacement. Any ideas
your wws800 should have come with two batteries. One goes in the reception base and one goes in the scanner itself. You should allow for four to 6 hours to fully charge. When charged, scan the setup barcode on the bottom of the reception base and then the BASE code. This will allow your scanner to create a connection with the base. Give it 5 secs or so, you should hear three beeps.
Jul 20, 2011 | Wasp WWS800 Handheld
Printer and copier work fine- scanner says USB not connected.
I had this same problem and it is fixable, but not the way you would probably like, though you can still scan with the printer. You just have to open the Paint program and click from scanner or camera, and then choose your printer and click scan preview, and then scan, it works just fine but its a little time consuming.
Jun 01, 2009 | HP Photosmart C4280 All-in-One InkJet...
MES60VK Gigabeat - Dead
There is a switch on the bottom left side of the dock connector of the player. Flick the switch to the right and it should work. The switch is the battery cutoff switch. It is there so it will charge only. I have no idea why Toshiba though this was a good idea, but they put it there.
Nov 08, 2008 | Toshiba gigabeat MES60VK Digital Media...
CasioEX-S880 will not charge.
Hey ITDude,
You do need to charge the camera by putting it in the camera dock and the ac cord should be plugged into the camera dock. It is possible that the battery has gone bad so you could try getting a new battery. If neither of these options work I would have the camera looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 18, 2008 | Cameras
Camera no longer connects to camera dock?
Oh i had the SAME problem...the wiring in the camera itself probably is wrecked...take it back to where you got it and see if they have the same camera still in stock and if they do DONT tell them you dropped it tell them it just stopped working,,
Nov 03, 2007 | Kodak EasyShare CX6230 Digital Camera
Scanner blocks when scanning a bar-code
the metrologic scanner you are talking about has a barcode in the maual under the keyboard wedge section it is called stand alone keyboard this will cure your problem when you scan it. the reason being it fools the scanner into thinking there is a keyboard connected. hope this helps Pete
Aug 16, 2007 | Metrologic Instruments 9520 Voyager
Will not scan
With the power off & the machine unplugged, remove the scan glass & move the scanner a few inches from "home" position. Plug in & turn on machine. Does the scanner return to home position? If not, you either have a bad scanner motor or scanner cable. I'll look for you to post the results of the scanner drive test.
Jun 19, 2007 | Canon PC-1080F Copier
PANDIGITAL PANSCN09 Handheld Wand Scanner w/Feeder Doc Station & 2GB Logo
44 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
David Payne
David Payne
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
