Question about Briggs & Stratton Measuring Tools & Sensors
Go devil engine
I just purchased a used 23 hp b&S go devil. Its a 2008. Supposedly not used much however I am being to have my doubts. Right now it starts easy but only runs about half speed wide open. When I get the motor into low water it seems to run better. Any thoughts where I should start looking for the problem.
  • 32 Answers
SOURCE: 22 hp Briggs Intek will not run at full speed without choke on
sounds like you sucked up dirt in the carb needs to be taken off and cleaned
Posted on Jul 20, 2009
SOURCE: have a 20hp vanguard on a go-devil long tail
These engines seem to have problems maintaining the correct valve lash settings. try taking the valve covers off and checking the valve/pushrod clearance.on tdc compression stroke it should be .001-.003 clearance. then check exhaust stroke tdc on exhaust stroke. clearance should be same on the other valve then. hope this cures your problem.
Posted on Dec 27, 2009
SOURCE: 20 hp intec runs wide open
24 hp briggs. replaced cam, exhaust lobe was unhardened. now it doesnt fire on that cylinder. plug is wet. spark tester shows spark,please help.
Posted on Apr 02, 2010
  • 221 Answers
SOURCE: Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
Posted on May 17, 2010
SOURCE: 20 hp b&s runs wide open
sounds like the gov. fell out in to the oil pan. if you remove the gov. springs and let the gov. arm move up. it will fall out. no book will till you that. if that happend you will have remove the motor and pull the oil sump pan. and put it back to gether make sure you keep the motor up side down. untill you reajust the gov.
Posted on Jun 19, 2010
Dirt devil featherlite vaccum were does the extra hose go?
Hi, it's Jeremy from Crucial Vacuum.
Attached is a copy of the user's manual for the Dirt Devil Featherlite Bagless Vacuum M085845. You can find a diagram of your vacuum on page 11 depicting where each part is located. The 2 hoses for your vacuum are listed as numbers 22 and 23.
http://dirtdevil.com/file/898/
You can purchase direct your replacement Dirt Devil parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/dirt-devil.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 04, 2014 | Dirt Devil Featherlite Bagless Vacuum...
Have a 23 Vanguard on a mud boat and when engine damp from dew or fog, engine turns over but will not start. When engine dries, starts right up.
Your coil may be getting damp or wet..try using a plastic bag over the coil..or use some spray that will keep the damness out..good luck..
Jan 04, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
I have a 23 hp Briggs vanguard engine-V Twin Model 380447/type 76-E1 code 4241. The engine is less than two mowing seasons. The engine will not turn over properly and I have used another start I have and...
It will probally be your valve setting might be off so pull the valve covers off and try setting your valve lash
Heres the factory settings
.006 on Intake
.008 on Exhaust
Sep 05, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Husqvarna 48' 24 hp 2008 riding mower.Engine stops when mower deck is engauged
check under the deck and see if you have something wrapped around the blades and locking them up. Make sure you can turn the blades by hand. I had this happen with some barbed wire on my mower last summer. hope this helps you
Oct 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
TURNING RIGHT ENGINE WANT TO CUT OUT
sounds like the operator presence control switch needs adjusting.
Under seat.
Apr 01, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
2008 Toyota Avalon Battery Problem
I doubt this is a smart key problem, the key uses a chip and its own battery. Something in the car is causing a drain, a light is staying on possibly. Trunk light, glove box light, under hood light... maybe you have a portable GPS unit plugging into the auxilary port? Just a thought. This is not a common problem that has been reported by Avalon owners as of yet.
Sep 02, 2008 | 2008 Toyota Avalon
Measuring Tools & Sensors Logo
55 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
