Question about Canon Rebel XT / EOS 350D Digital Camera
10 sec timer on shutter! Want it off
No instant shutter when I click. It counts down from ten on the screen.  can't find where/how to shut the timer off and get INSTANT pix. thanks
  • 29 Answers
Check your manual how to disable the self timer.
For the 350d its changed by pressing the timer button, indicated with a clock-like symbol (above the arrow buttons).
While pressing that button turn the dial next to the shutterbutton.
In the LCD display the indicator will change between single shot, continuous shooting and self timer.
Posted on Apr 30, 2009
How do u use the rc6 for instint photos not two second. What do you set on the camera. 5D mark ll
don't set for 2 sec, set the camera to 10 sec self timer and click the remote, should work instantly with every click. just remember to set for regular shooting if not using the remote. can be very annoying to wait 10 sec for a shot, unless you want to be in one?
Jul 04, 2011 | Canon RC6 Wireless Remote RC 6
Compressor UP6 25 125, runs all the time but is only under load for a short time, should it shut down between loads?
This unit will shut down if unloaded for a set period of time. Usually 5 to 10 minutes. This time could be longer if some one has changed it from the factory setting. There is a timer in the control box that starts counting down when the unit unloads. If it stays unloaded long enough for the timer to count down the unit will stop until the air pressure drops to the low set point on the pressure switch. It will then start up. If the unit loads before the counter counts down the timer starts from the beginning when it unloads again. This cycle continues until you manually shut it down or you stop using air long enough for the timer to reach Zero and shut down.
Apr 22, 2011 | Ingersoll Rand UP6-25-125 120 Gallon...
I have the timer set for 10 sec, how do I make it work?
Once you have the self-timer set, start it by pressing the shutter release button as usual. The camera will focus, meter the exposure, then delay for ten seconds before firing the shutter.
Mar 21, 2011 | Konica Minolta DiMAGE Z6 Digital Camera
Round soft key OXO Timer I need to change the clock time their model # is 1061978
Operating functions:
To set the clock, press and hold the clock/timer button for three seconds. A clock icon will appear on the left side of the screen. Input the time using the numerical buttons and then click the clock/timer button to save the time.
To set the timer, press and release the clock/timer button so that the display shows all zeroes. Enter the desired time using the keypad. Press start/stop to start the countdown. The countdown may be paused by pressing the stop/start button and resumed by pressing the same button again.
When countdown is complete, timer will beep continuously for thirty seconds and display will flash. Timer will then beep every ten seconds for ten minutes until the stop/start button is pressed.
This timer will also time up to time activities. To start count up, press clear/memory so timer reads all zeroes. Press stop/start and a plus sign will appear on the right side of the screen as the timer begins counting up.
Sep 18, 2010 | Microwave Ovens
AEG single oven - clock runs for 12 hrs , buzzes and goes back to 12 o'clock - if set timer and check time remaining, it buzzes and jumps to clock setting loosing time remaining. Buzzer sounds ''hoarse''.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
Jul 17, 2010 | AEG B2100-4 Electric Single Oven
Is there a timer on this camera?
Yes there is .......page 47 of the manual shows you how .... its an option on the drive mode in the startup menus.
http://safemanuals.com/user-guide-instructions-owner-manual/KONICA%20MINOLTA/DIMAGE%20Z1-_E
Self-timer
Used for self-portraits, the self-timer will delay the release of the shutter for approximately ten seconds after the shutter-release button is pressed. The self-timer is set on section 1 of the recording menus (p. 44).
With the camera on a tripod, compose the picture so the subject is within the focus frames. Press the shutter-release button partway down to lock the exposure and focus (1). Press the shutter-release button all the way down to begin the countdown (2).
Because focus and exposure are determined when the shutter-release button is pressed, do not stand in front of the camera when taking a self-timer image. Always confirm the focus with the focus signals before beginning the countdown
(p. 25).
The self-timer is counted down on the monitor. During the countdown, the self-timer lamp on the front of the camera (3) will start to blink and is accompanied by an audio signal. A few seconds before the exposure, the self-timer lamp will blink rapidly. The lamp will glow steadily just before the shutter fires.
To stop the countdown, slide the zoom lever to the left or right. The self-timer drive mode is reset to single-frame advance after the exposure. The audio signal can be turned off in section 2 of the setup
menu (p. 83).
Mar 03, 2010 | Konica Minolta DiMAGE Z1 Digital Camera
Describe how to use the self timer on the samsung S830 digital camera
Make sure you're in a recording mode other than VOICE.
Press the Self-Timer button (right button) until the display shows the desired mode. Your choices are 10-second mode (the camera takes a picture ten seconds after you press the shutter button), 2-second mode (the camera takes a picture two seconds after you press the shutter button), and Double-self-timer (the camera takes a picture ten seconds after you press the shutter button, then takes another two seconds later).
You can cancel the self-timer mode by pressing the Self-Timer button again.
The 10-second mode allows you to run back for a group picture. The 2-second mode is useful when you want to take a picture without fear of camera shake; simply place the camera on a steady support such as a tripod. The Double mode increases the chances of getting a picture with everybody's eyes open.
Jan 11, 2010 | Samsung S830 Digital Camera
Self timer
1. Press the Func/Set button
2. On the left side of the LCD, scroll down to Drive Mode icon (usually a square, third item down)
3. Use right arrow key to select clockface with 2 (2 sec delay) or 10 (10 sec delay)
4. Press the Func/Set button
Now whenever you press the shutter button, the camera will delay 2 or 10 seconds before a picture is taken. Use the same steps to go back to normal (square icon) drive mode.
May 01, 2008 | Canon PowerShot A710 IS Digital Camera
Timer Help
I was just playing with this myself...
Hit the "FUNC" button and scroll (if necessary) to "Drive Mode"
Scroll right/left to select 10-second, 2-second, or custom timer setting. If custom, hit the "Set" button then select the timer delay and number of shots to take.
Leave the FUNC display on the screen when you hit the shutter release. It begins counting down when you hit the shutter button, so make sure you've got it pointed where you want it (preferably on a tripod, though any stable surface will do in a pinch).
Nov 22, 2007 | Canon PowerShot A510 Digital Camera
Tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Aug 29, 2007 | Philips Magnavox 27MS343S 27" TV
Canon Rebel XT / EOS 350D Digital Camera Logo
267 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
